Old August 31st, 2010, 16:02   #31
blackened
Ok. I guess based on previous experience with ram air set up from gm such as the ws6 trans am with a ram air hood feeding into the ram air box. I know that traditional ram air doesn't do anything special until highway speeds, with its benefit directly related to vehicle speed. Seeing as how tdi's are popular with people driving many highway miles it seemed like a reasonable intake solution. Would the intercooler negate the positive affects of a "ram air" style set up?
blackened is offline   Reply With Quote
Old August 31st, 2010, 16:25   #32
Ben Dur
Ben Dur's Avatar
a turbo negates it almost entirely
that being said, vw's setup is essentially a ram...
not the most efficient one ive seen, but still
Ben Dur is offline   Reply With Quote
Old September 3rd, 2010, 17:26   #33
ChippedNotBroken
Fuel Economy: 50,45
Took a while but I found the post that I referenced earlier ...
http://forums.tdiclub.com/showpost.p...73&postcount=9
1999.5 Green Jetta MrChill'd and Wild Bill'd then it got the Whitbread build, Bleached 'n Nick'd and idi'd, RC'd, RyanP'd then fine'ly Jasonified.
Youtube video of smoke
Youtube video of vacuum restriction
Errors of opinion may be tolerated where reason is left free to combat it. TJ
ChippedNotBroken is offline   Reply With Quote
Old September 11th, 2010, 06:17   #34
T_D_I_POWER
T_D_I_POWER's Avatar
Originally Posted by Ben Dur
today the skis cleared up just enough for me to pull my little green TDI up to the garage to swap my crap cone filter with my stock air box......
finally i installed the stock air box
By leaving big opening as shown, the engine will breathe warm-hot air generated from the surrounding engine compartment.
The solutions are:
-Close the opening
-Close off the surrounding AFB area to block warm-hot air
-Route a round duct which directs cold air to the opening
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old September 11th, 2010, 14:54   #35
Jtroy
TDI(s): 1998 Jetta
Originally Posted by Drivbiwire View Post
That's the dirt let thru after just 501 miles of driving on a NEW FACTORY OILED K&N
For a more fair and complete comparison from "Bob Is the Oil Guy" site see the following link:
http://www.bobistheoilguy.com/airfilter/airtest3.htm.
Why not let the members read Bob's actual report and make their own decisions? Though Bob's tests show that filters can differ in their ability to stop particles, it's not as extreme as comparing a completely clean after-filter patch to an unused filter patch.
I've been researching to determine if I should purchase a K&N filter (for my gas-drinker, not my TDI) and, after reading Bob's original article and looking at his photos, I found this particular photo to be misleading.
Jtroy is offline   Reply With Quote
Old September 11th, 2010, 15:51   #36
Plus 3 Golfer
Plus 3 Golfer's Avatar
I've been researching to determine if I should purchase a K&N filter and, after reading Bob's original article and looking at his photos, I found this particular photo to be misleading.
Actually, why not read this report which does a little more than capture dirt on some gauze.
Plus 3 Golfer is offline   Reply With Quote
Old September 14th, 2010, 19:15   #37
ChippedNotBroken
Fuel Economy: 50,45
For those interested:
http://www.finditparts.com/products/donaldson-d080020
Like OCtdi, putting the battery (Optima yellowtop D31a) in the trunk to make room
Old September 14th, 2010, 21:48   #38
Drivbiwire
Zehntes Jahr der Veteran
Look at the specs, the TDI filter has lower restriction at 300 CFM than the Donaldson at 176 cfm....Not sure if thats an upgrade.
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old September 19th, 2010, 18:11   #39
ChippedNotBroken
Fuel Economy: 50,45
My understanding is that the filter is designed for moderate dusty driving and that removing the dust collector (a major restriction at the entrance to the filter) you will no longer be at 176 cfm. If you look at the consctruction of the filter it can absorb a lot of junk before you see any restriction from a dirty filter.
Old October 3rd, 2010, 07:24   #40
Gil
Fuel Economy: 38 and 38 :o(
Too bad this thread doesn't deal with the PDs system which is quite different.
The air box has 2 chambers.
The bypass valve is located on the engine side of the air box drawing hot clean air into the air cleaners smaller chamber.
The PD has no snow screen (a few may have one).
The filter element has the now popular winter filter acting as a snow screen.
The main difference in the systems is the bypass valve. The PDs main chamber may plug up and then air is sucked into the smaller chamber. This is a better design than earlier TDIs IMHO.
02 auto TDI wagon, .185s and RC2
04 PD TDI standard shift, RC1+
Gil is offline   Reply With Quote
Old November 21st, 2010, 06:25   #41
Gil
The only problem that I have with the newer design is that the engine will only draw air through one side of the air filter element.
Now IF the main side of the filter gets restricted, that means that the bypass valve may open and let hot air into the system defeating the cold air intake from the front of the car.
I have modified my 04s airbox by punching a few large holes in the divider making full use of the element ( did this a number of years ago ). Then a few weeks ago I got the idea to plug that bypass valve to make sure that no hot air will ever find its way into the engine. Now the system is about the same as my 02 TDI.
After this new change the car seems to be quicker and run better under all driving conditions.
Old November 21st, 2010, 06:37   #42
Drivbiwire
I have been installing CAT restriction meters on all my customers cars, the new generation air box with dual chambers pulls about 7" WC at full power, the limit is 25"WC at full power. I am sure that you can still get 80,000 miles or four years from the new style elements and boxes from the accrual of restriction I have seen.
Old November 21st, 2010, 07:39   #43
ChippedNotBroken
Fuel Economy: 50,45
While pulling about 40# of boost at 5000 RPM the vacuum gauge on my air filter did not budge. I took a video while it was on the rollers, I will try to figure out how to post it when I have time after my dad goes back to florida.
Old December 24th, 2010, 15:31   #44
emantman
Fuel Economy: ~43 hwy ~38 cty
Default 2009 TDI Sedan at Altitude
I was posting on another thread, but this seems like a more appropriate place.
I have a 2009 Jetta TDI Sedan in Colorado. I live at ~6000ft altitude. I have been told (and I absolutely believe) that engines (diesel, gas,etc..) lose ~10% power for every 4000ft of altitude. This is because the air is much less dense, and there's much less oxygen. That means I'm running at ~86% actual power than the engine should actually be producing.
I drove my TDI to La Bufadora, near Ensenada in Baja Mexico for the whole week of labor day 2009, and I know my TDI had WAY more power at sea level. I come back to Colorado and it's just not as powerful.
I want to install the new AFE power air intake system (one of the first aftermarket products for the 2009 TDI) to increase the air flow (which supposedly increases horsepower, etc...), but another post (by a veteran tdiclub member) recommended that:
"Don't do it. The factory intake already draws cold air, flows more than adequately, and will actually do more harm than good in the long run."
So I want to know how it would hurt my car if I increase the air flow (and hence oxygen) when I'm always at a high altitude (99.9% of the time)?
Please any suggestions, comments, thoughts, etc... would be much appreciated! I love my TDI!
emantman is offline   Reply With Quote
Old December 24th, 2010, 17:21   #45
GoFaster
Moderator at Large
The aftermarket air intake system will make 0 difference to your car. Zip, zero, zilch.
The stock air intake is already a low-restriction cold-air intake. Open the hood ... see that little grid of openings in the plastic next to the latch? That's the engine air intake. It leads to a large-diameter duct into the air filter housing, and that leads to a generously-sized duct to the turbo inlet which is about as straight as they can make it. You can't eliminate restriction that is not there to begin with. You can't lower the temperature below the temperature of the air coming in the front of the car. The engine doesn't care whether the intake ducts are the original parts, or have a fancy brand name on them. A lot of those aftermarket air intakes use aftermarket-style air filters, which in many cases don't filter as well as stock-style air filters. All of this, and considerable other supporting information, has already been posted or linked to in this thread.
Leave well enough alone.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Page generated in 0.16105 seconds with 9 queries
[Output: 136.74 Kb. compressed to 115.07 Kb. by saving 21.68 Kb. (15.85%)]
