Old January 18th, 2017, 21:05   #181
2012a3tdi
TDI(s): Audia3 2012
If intake is mostly for the bling, why are there so many players in the game? Everyone makes an after market filter and boasts of modest to outrageous increases in flow, which translates into power at the wheels.
2012a3tdi is offline   Reply With Quote
Old January 18th, 2017, 21:23   #182
turbobrick240
turbobrick240's Avatar
Probably because people want bling. Also, people buy those magnetic fuel line junk- so plenty of uninformed consumers out there. And lastly, it's an easy mod that any gorilla with a crescent wrench can do and feel proud about. (until they find out they wasted their money)
Old January 18th, 2017, 23:38   #183
hajes
it has got more flow if installed properly...but flow and filtration is always a compromise.
it is like marketing hype of outdoor companies. Gore-Tex cannot breathe and be water/wind proof.
You have to pick one that suits your vision.
hajes is offline   Reply With Quote
Old January 19th, 2017, 00:15   #184
turbovan+tdi
turbovan+tdi's Avatar
Why, because they sell, which makes the company money, which is the goal.
If the stock airbox isn't being used, lets say the air box is rated at 1000 cfm and the engine only uses 500 cfm, then installing a high flow air filter that flows more than 500 cfm, you won't gain squat, unless the system is designed poorly.
Diesels get all the air they need, they need fuel to make power, so if the air/fuel ratio is fine, adding more air won't make any more power.
Old February 12th, 2017, 13:31   #185
Teddyh
I had a K&N cold air intake on my previous vehicle (Ford Focus SVT) no matter how careful I was to oil it lightly I found that the oil always made it to the MAF sensor whichh resulted in diminished performance. I was also haunted by a howling due to air inlet design. It looked cool and made the car sound better but as far as performance if it made any it was not noticable, if anything I remember the lack of performance when it skunked my MAF. It cost me about 300 bucks and I always felt it was the most wasteful mod I ever did. I should also point out that every couple weeks it would pop off my motor because the clamp was either too tight or too loose. The problem was if it was too loose it fell off, too tight and the plastic would collapse so the retention ring wouldn't holdd. Nothing like stalling in rush hour traffic because of a upgrade. Seriously save your money for something better.
Teddyh is offline   Reply With Quote
Old July 7th, 2017, 13:31   #186
New Mickey
The user formerly known as mickey
TDI(s): 2015 Passat
Because bling is the point, for kids.
New Mickey is offline   Reply With Quote
Old July 7th, 2017, 13:34   #187
New Mickey
TDI(s): 2015 Passat
If a "cold air intake" is an intake at the front of the engine compartment designed to breathe cool outside air then my 2015 Passat already has a "cold air intake". Can't see the point of messing with it.
I'd love to see an independent, side-by-side comparison of a stock intake and filter vs. any aftermarket stuff. People I trust have reported none, or at best negligible improvements in dyno power with aftermarket intakes unless they've also boosted the engine's power output to enormous levels.
-mickey
p.s. Been there, done that, back in the day. I never noticed any difference. I tried hard to convince myself I did, having spent silly money, but it doesn't make a difference.
Old August 11th, 2017, 15:31   #188
kevinstephen
I agree with you sir. Aside from that, people nowadays take advantage of there stuff that can be built easily. They try to so the same stuff but on poor quality but sell it on premium prices.
__________________________
Towing Springfield VA
kevinstephen is offline   Reply With Quote
Old December 11th, 2017, 07:01   #189
Mongler98
*magnetic fuel line junk"? People will buy anything lol
I do put a small magnet on my oil filter when i brake in an engine but thats just for when i take the filter apart to inspect the engines health
Old December 11th, 2017, 08:26   #190
pdq import repair
Fuel Economy: 38.5
If it were that easy to make power, don't you think the factory would have considered it? A chrome vacuum cleaner tube and a cheap K&N instead of engineering, what's not to love?
Seriously, I have seem many many cars, mostly ricers mind you, that have lots of dust showing in the intake tract, and a bad MAF. In some cases the engines have been dusted bad enough to have compression and misfire issues.
At a Bosch service school once someone brought up K&N, and the instructor commented that as far as MAFs go, it means "kill it now"
pdq import repair is offline   Reply With Quote
Old March 9th, 2018, 10:33   #191
damac
TDI(s): none
i have an alh mtdi motor in my mk2 golf and right now i have an old jaguar air filter can somebody sold me on here just sitting with its front inlet hole open right behind the headlight on passenger side.
is it possible i am messing with performance and egt's right now?
should i try and mimic the stock alh setup and other cars and somehow make a tube that goes from the filter can to the front of the car in an open area like the intercooler?
i guess i was worried about junk and water ingestion. i once tried this on another car with a level straight open pipe and got enough water in during a rough rain to get past the air filter and bog car down which was scary.
damac is offline   Reply With Quote
Old December 26th, 2018, 23:02   #192
Cree182
I was watching mighty car mods and have talked to a few mechanics. They all say that any oil based filter is bad for almost any engine. Even a tuner I was getting a previous car tuned advised against oil based filters.
Cree182 is offline   Reply With Quote
Old January 10th, 2019, 05:29   #193
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Pushing 2.8 2.9 bar through stock air filter and housing. You dont need any racing filter
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Page generated in 0.13957 seconds with 9 queries
[Output: 111.69 Kb. compressed to 93.89 Kb. by saving 17.80 Kb. (15.94%)]
