Old August 7th, 2010, 12:03   #1
giovanni2
Default P2100 Fault Code
Today my 2001PD Wagon threw this code. Found on this site that it is "Throttle Actuator Control Motor Circuit/Open"
Can anyone tell me what that means and what I should be doing?
Was able to clear it with my Scan Guage and it went away for now.
giovanni2 is offline   Reply With Quote
Old August 7th, 2010, 12:52   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
what was the actual code?
you can check rosstech for desription and diagnosis
http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old August 7th, 2010, 17:58   #3
giovanni2
The Scan Guage said P2100.
When I did a search I found it to be "Throttle Actuator Control Motor Circuit/Open"
Not quite sure what to do or where to find it!!
Just checked the RossTech site....
there is no mention of a P2100 fault code.
What to do now??
Old August 7th, 2010, 18:05   #4
JASONP
JASONP's Avatar
If you can find someone locally with VCDS it will give you a more accurate code, SGII somtimes repprts generic OBDII codes.
Old August 7th, 2010, 18:11   #5
JASONP
JASONP's Avatar
ok I googled the description and found this
http://uk-mkivs.net/forums/p/214068/1382801.aspx
sound slike the intake flap which I believe on the PD's is electrically operated
Old August 10th, 2010, 12:14   #6
giovanni2
Just wondering if this is something I can handle myself.
Sounds to me that there is a flap and a motor that needs to be replaced?
Old August 10th, 2010, 18:40   #7
JASONP
JASONP's Avatar
not sure if the motor is separate from the flap, but either should be a breeze to swap out
Old August 11th, 2010, 07:20   #8
giovanni2
Thanks JasonP....
If you can point me in the right direction for the right part and/or the proper procedure, that would be great. A search does not give me a picture of the part itself, so a I am a bit confused as to exactly where to find it.
Have you performed this on a vehicle before?
Page generated in 0.13175 seconds with 9 queries
[Output: 80.20 Kb. compressed to 68.30 Kb. by saving 11.89 Kb. (14.83%)]
