Old August 3rd, 2010, 11:11   #1
LadiesMan217
LadiesMan217's Avatar
TDI(s): 2005 GLS TDI
Fuel Economy: 33mpg city
Question Bad Temp Sensor?
Hey volks, my CEL came on this morning. The code scanner came back with P0128. Now i just had my t stat replaced about 3 mo ago by "vwjettadsl". The temp gauge seems to work fine. From what ive found on the forum it seems that it could point to a bad temp sensor which i believe i read somewhere on here to be rather faulty. Could anyone shed some light on what i should do about this?
2005 Jetta GLS TDI: Reflex Silver, Black Velour, 15%tint Front, 5% Back, Gator Tuned, Ventectomy, Magnaflow High flow Cat, Aero Turbine Muffler, AFE Cold Air Intake, Philips Xtreme Power Headlights, 215/60/15 Goodyear Eagle Gt's
LadiesMan217 is offline   Reply With Quote
Old August 3rd, 2010, 17:18   #2
Jeff Heyerman
Well I just went through this. If you have VCDS drive around with someone monitoring the group 00. The coolant "temp" is on that line. It goes from a high to low value as coolant gets hot. At operating temperature it should be about "74" (74 what I have no idea). Mine was fine most of the time, but then jumped erratically on occasion (3 times in 20 minute drive). Also monitor group 01, which gives coolant temp in C - should be just shy of 90C
When you get home, check coolant temp with a meat thermometer (open cap slowly). Should be 87C or so. If coolant is too cool, then prob code is from t-stat not working properly. But much more likely sensor is bad.
The one I just replaced in our 2002 was a black one - apparently notorious for failing. Also for replacement buy from VW, apparently aftermarket ones also let out the ghost quite quickly.
Cheers.
Jeff
Jeff Heyerman is offline   Reply With Quote
Old August 6th, 2010, 20:03   #3
LadiesMan217
Cheers.
Jeff
Thanks, unfortunatly i dont have the VCDS. I may just have to try the meat thermo method sometime. Could a bad sensor affect mpg? So far after i cleared the code it hasnt come back. Im definately thinking its a bad sensor. Will id parts have replacements?
Old August 13th, 2010, 18:11   #4
LadiesMan217
Exclamation
Well so far the code hasnt come back but i just filled up today and its only 30 mpg. I havent been that low since winter. Should i just replace it? Is there a how to on here about it and where's the best/cheapest place to purchase one from? thanks guy
Old August 13th, 2010, 19:56   #5
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Some preferred sources:
1stvwparts.com - Auburn Wa VW.
idparts.com
worldimpex.com
boraparts.com
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old August 13th, 2010, 22:11   #6
LadiesMan217
idparts.com
worldimpex.com
boraparts.com
Tony
Great, thanks. I found an old how-to by "tkindler" so i'll pick up the green sensor and take a crack at it. One question though, my temp gauge has always been stable, if the sensor was really bad wouldnt it be all over the place?
Old August 14th, 2010, 06:34   #7
TonyJetta
I'm pretty sure the '05 is like my '06, in that there are 2 temp sensors. I had a similar issue and had to replace the one near the thermostat.
Tony
Old August 14th, 2010, 07:02   #8
LadiesMan217
Tony
Mine is the a4 design from early 05, before the design change..
Old August 14th, 2010, 18:03   #9
TonyJetta
If it's a PD, then it's likely similar...2 temps sensors. One at the back of the head, PITA to replace, and one at the lower radiator hose, where it goes into the thermostat, easy to replace. The one in the lower radiator hose is the one I had to replace.
Tony
Page generated in 0.11950 seconds with 9 queries
[Output: 95.07 Kb. compressed to 81.41 Kb. by saving 13.65 Kb. (14.36%)]
