Old August 2nd, 2010, 07:11   #1
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Default 19464 - Camshaft Position Sensor (G40): Signal Out of Range P3008 - 000
Well, one of the things I did was the timing belt on my car this weekend. I turned the car over several time by hand before starting and I "thought" I had the cam locking pin in but I might not have. I attempted to start and got the code 19464 - Camshaft Position Sensor (G40): Signal Out of Range
P3008 - 00. I have searched and found that it mainly rings a code from a broken timing belt which isn't my case or the timing belt is out of range on the camshaft. I followed one set of instructions to put the pulley counterclockwise all the way, snug a bolt, then put the belt over the cam (after is on the crank of course). Once the belt is over the tensioner and cam sprocket/pulley then loosen the cam bolts and put the belt over the water pump and then put the idler pulley on.
I must have gotten the belt a tooth off or something. I might not have gotten the lock in all the way as it was very hard to tell if it was in or not. Is there a way to adjust the camshaft without having to pull everything beyond the slotted holes on the cam sprocket? If not and I have to redo the procedure is there any place that can get me just the torque to yield bolts I need because the nearest dealer is 150 miles away to get the bolts? Any help would be great on this. I am going to tackle it yet tonight to see if I can find how much off it is.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old August 2nd, 2010, 12:41   #2
Dimitri16V
Dimitri16V's Avatar
you are probably off more than 1 tooth . are the bolts centered on the slots ?
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old August 2nd, 2010, 14:13   #3
coalminer16
TDI(s): Golf 2004
No, they are now almost clockwise all the way.
Old August 2nd, 2010, 21:24   #4
coalminer16
TDI(s): Golf 2004
Problem solved. Belt was two teeth off. I didn't know how much the cam shaft lock was suppose to go in but it wasn't in the correct spot the whole time. I was able to correct the timing belt without removing the motor mount.
Page generated in 0.12608 seconds with 9 queries
[Output: 63.42 Kb. compressed to 56.46 Kb. by saving 6.96 Kb. (10.97%)]
