Old August 1st, 2010, 06:46   #1
Little Pickle
Little Pickle's Avatar
Default N75 upgrade
Hi folks!
As it appears I have been having low boost problems for years and finally have found the cause! My 1z was taken from a 96 Golf and installed into a pocket size Seat Arosa (sig pic).
I cleaned my N75 valve with WD40 and the difference was night and day! The thing is crazy quick now. To give you an idea Audi RS4s cant get near me.
Anyway, my question is should I just change my N75 for the original or is there a better option? Maybe one from a MK4 or an after market one?
Any advice on this will be great.
Seat Arosa 1z TDI. BB K03 Hybrid Turbo, 2.5 downpipe, PD lift pump, Custom re-map, PP520, Green cone airfilter, EGR delete, De-cat & boxes, FMIC from a Renault Master, Sparco Milanos, KW Variant 3 coilovers, 288mm Brakes, 320+NM, 150ish bhp.
Little Pickle is offline   Reply With Quote
Old August 1st, 2010, 07:38   #2
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
No upgrade; just change it for an original one.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old August 1st, 2010, 14:14   #3
Little Pickle
Ok thanks Tony!
Old August 1st, 2010, 14:27   #4
BolaB4V
BolaB4V's Avatar
Fuel Economy: mid 40's to over 50 hwy..
Thinking of doing something with the N75 valve, not that Ive got problems ,but think that would be a fairly quick procedure to see if there's more power in there being overlooking. I know its pretty old. Never checked it and have put 56-7k on it since Ive owned it.
BolaB4V is offline   Reply With Quote
Old August 1st, 2010, 15:50   #5
TonyJetta
The wastegate actuator can be adjusted, but without a tune, it's hard to get more boost, reliably. The cheapest big bang for the buck, is nozzle upgrades.
Tony
Old August 1st, 2010, 16:11   #6
bryguy
bryguy's Avatar
TDI(s): 2002 Jetta
Fuel Economy: 45-47
Agreed, just put .216mm nozzles in my '02 Jetta and the thing is a rocket. HUGE increase in power! Car is otherwise relatively stock. It is really fun to drive now!
bryguy is offline   Reply With Quote
Page generated in 0.12989 seconds with 9 queries
[Output: 71.80 Kb. compressed to 62.50 Kb. by saving 9.30 Kb. (12.95%)]
