Old July 31st, 2010, 13:00   #1
Paulrd277
TDI(s): none
Question Having trouble with my TDI - Is it the Turbo?
I have a 2001 TDI Jetta automatic with 100k miles on it. I just had the timing belt, battery and oil changed. The only problem I am having now is I'm not really getting any power when I put the throttle down. When I push the gas all the way, the revs go high but it doesn't really go anywhere. It also has trouble up hills as well. Also, it wont change gears when I get to 4000 rpms unless I let off the gas. Someone told me the turbo isn't working because I'm not getting any power, is this true? I don't think It's my tranny because it goes into drive and reverse with no problem. My check engine light isn't on either. If anyone knows or has had this problem in the past, please let me know. Any information would help!
Paulrd277 is offline   Reply With Quote
Old July 31st, 2010, 13:28   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Who changed the timing belt, battery and oil?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old July 31st, 2010, 13:34   #3
njphil
I had a somewhat similar problem at around 35k miles. wouldn't shift from 3rd to 4th , 4th to 5th, etc (and merging into traffic was a safety issue) till i let off the accelarator a bit, and really jerky shifting. I was getting serviced at a dealer back then and they said fuel filter was causing it. It affected fuel pressure (not sure exactly how, fuel pump i guess) and cause the trans to act like it was.
But I have a dsg tranny.
'06 Jetta TDI DSG Reflexsive Silver pkg#1 - 188k+ miles
njphil is offline   Reply With Quote
Old July 31st, 2010, 15:20   #4
Paulrd277
TDI(s): none
Well, I just took it out again and there was a loud hissing sound whenever I accelerated. After the engine got warm it went away, but now the check engine light is on :-/ Maybe there's a hose leak?
I changed the oil and battery myself and had the timing belt done by a local garage.
Old August 1st, 2010, 15:23   #5
TornadoRed
TornadoRed's Avatar
There is almost certainly nothing wrong with your turbo. But the local mechanic may have dislodged a vacuum hose or failed to tighten the clamp to the intercooler properly -- there are a number of things he could have done wrong.
Unless your local mechanic is a TDI expert, you might have his work checked by someone who is... there are a number of them in New England.
'03 Golf with 698k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old August 1st, 2010, 17:59   #6
Paulrd277
TDI(s): none
Im so glad it's not the turbo! Thanks for your reply, Im going to try to find a TDI mechanic around here.
Thanks again!
Old August 2nd, 2010, 12:33   #7
Paulrd277
TDI(s): none
How do I find a local TDI mechanic around here?
Old August 2nd, 2010, 12:47   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
you can try the link in my signature
Old December 18th, 2011, 05:21   #9
mariahexp
Unhappy
I purchased a 2004 Jetta wagon TDI with automatic/triptronic transmission and 83,000 miles. Had professional 3rd party inspection which found no problems and had it shipped to me. Car arrived with engine light on, no power to climb hills, and major problems in shifting smoothly when just getting going after sitting for a few hours or overnight. Actuator on turbo was bad which was big investment to fix but now it has power when needed. Unfortunately, it is still having trouble shifting from 1st/2nd then 2nd/3rd till car is very very warm. Then it shifts smoothly and has plenty of turbo boost to get up WV hills.
Don't have a local expert close by so I've driven 4 hours each way to Athens, OH to have belts changed/diagnose turbo actuator problem, then to go back once part was in to replace actuator.
So, did the fuel filter address your problem shifting? Do I possibly need a new thermostat so it warms up more quickly? New transmission (I hope not)? Transmission flush (I don't know if that even happens)?
I don't know a lot about cars. I want my car to drive without revving up to 4000 rpms before shifting. I got screwed by a Florida dealership and now am just trying to get this great fuel efficient car to run how it should since the dealership wasn't honest about its problems.
Mariah
mariahexp is offline   Reply With Quote
Old December 18th, 2011, 09:50   #10
timk519
TDI(s): 2012 TDI JSW
My thought would be that the clutch is slipping and on it's way out.
Current: 1999.5 Jetta TDI GLS
Past rides: 2 TD Jetta's, 1 TD Rabbit, 2 Diesel Rabbits, Datsun Hustler PU, Chevy Blazer 4x4
timk519 is offline   Reply With Quote
Old December 19th, 2011, 15:30   #11
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
First of all this thread is from July 2010. The original poster had an automatic (with a boost leak)
Mariahexp should search "cold, shift, N92, 09A"
runonbeer is offline   Reply With Quote
Page generated in 0.14027 seconds with 9 queries
[Output: 99.77 Kb. compressed to 84.20 Kb. by saving 15.58 Kb. (15.61%)]
