Old July 29th, 2010, 22:36   #1
Stibz
Stibz's Avatar
Default 2009 Check Engine Light - P048C
First check engine light happened today. The car was just started, and the light came on within a minute. No issues regarding driveability, she ran perfect on the 2 hour trip home with the light on. Here's what I pulled with VAGCOM when I got home;
001164 - Sensor for Exhaust Flap: Implausible Signal
P048C - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 4
Mileage: 107180 km
Time Indication: 0
Date: 2000.00.00
Time: 19:58:16
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 13.07 V
Lambda: 3.2 %
Lambda: -9.5 %
Bin. Bits: 10011110
Voltage: 1.140 V
After reading several threads about it, and realizing that this part is not covered under the emissions 100k coverage, I'm just gonna keep on truckin...
What fails, the spring mechanism for the butterfly valve or the sensor that controls it? Does anybody know if the bentley or other shop manual provides a testing procedure? TIA
2009 Jetta TDI DSG, Build Date 08/08 - 180,000 miles, Diesel Dubs DP and Malone Stage 2, never at a dealer.
2000 Jetta TDI - 414,000 miles. (SOLD)
1973 Datsun 240z turbo, 1986 Mercedes-Benz 190e 2.3-16v running on Megasquirt, 2000 Toyota 4runner with a 2" OME lift
Stibz is offline   Reply With Quote
Old July 29th, 2010, 22:39   #2
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Are you sure it isn't covered?
Seeing as the flap is part of the EGR system, I think it should be.
Fixmy59bug is offline   Reply With Quote
Old July 29th, 2010, 22:52   #3
Stibz
Stibz's Avatar
I'm going to call VW of North America tomorrow to find out for sure...but from what I read, it seems that the extended emissions system warranty only covers "major" components like the DPF and converters. It's total bullsh*t if it's true...but I've sadly come to expect that from VW.
Old July 29th, 2010, 23:25   #4
JSWTDI09
JSWTDI09's Avatar
I have read that if you take it to the dealer they just replace the entire exhaust flap assembly for hundreds of dollars. Some people have successfully removed the assembly and cleaned it out and it works perfectly again. If it turns out that it is not covered by warranty, I would suggest trying this first. Are there any gurus near you?
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old July 30th, 2010, 07:06   #5
Stibz
Stibz's Avatar
It makes sense that it may be a mechanical failure because the spring and connecting parts are exposed to the elements.
I'll definitely try cleaning it first. I won't have a chance to look at it for a week or two, but it'll be fine. I'm also going to try and see if there's a way to wrap it, or at least partially cover it from road salt, grime, etc....
Old July 30th, 2010, 09:44   #6
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
http://forums.tdiclub.com/search.php?searchid=5304241
09 JSW, Build date 04/09
E brillera' per sempre, la stella di Firenze...
Claudio is offline   Reply With Quote
Old July 30th, 2010, 13:49   #7
Stibz
Stibz's Avatar
Originally Posted by Claudio View Post
Link not working? What did you search?
Old July 30th, 2010, 14:24   #8
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
the error code that you are having
Old July 30th, 2010, 14:26   #9
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
Here you go
http://forums.tdiclub.com/showthread...ighlight=P048C
Old July 30th, 2010, 14:42   #10
MayorDJQ
What 100k warranty are you talking about? Emissions components are covered by Federal Law for 8years/80k miles.
MayorDJQ is offline   Reply With Quote
Old July 30th, 2010, 16:33   #11
Stibz
Stibz's Avatar
Thanks for the links, read through those today.
Sorry, thought it was 100k. In any case, I'm going to take a better look at in a week or two. I'd rather not deal with VW on whether or not it's under warranty on a relatively minor issue. Also, they have no records on the car since i've done all maintenance since new, so i'm sure they would come up with some argument...even though I have my own records.
Old July 30th, 2010, 16:39   #12
JSWTDI09
JSWTDI09's Avatar
I believe that the most common problem is not dirt on the outside of the exhaust flap assy (that would be too easy). IIRC, you must remove it and clean out the inside where soot (or carbon) builds up and "gums up" the works. I doubt that road grime and salt is the problem. Sorry, I wasn't clearer on this in the beginning.
Have Fun!
Don
Old July 30th, 2010, 17:29   #13
pawel
pawel's Avatar
excuse my ignorance, but doesn't this flap do something during a regen?
Hella HID projector headlights, HID projector fog lights, highline ECM, Euro light switch, Euro LED tail lights with amber turn signals, rear fog light, Euro side mirrors, LED side markers, LED interior lights.
pawel is offline   Reply With Quote
Old July 30th, 2010, 18:45   #14
MayorDJQ
Yes. It also restricts/redirects exhaust flow to help regulate and increase EGTs in the DPF.
Old July 30th, 2010, 20:46   #15
VarmintSlayer
VarmintSlayer's Avatar
Thought i just read the exhaust flap is used for nox cat regeneration, so it won't be regenerated if it is defective.
The dpf regen shuts down the egr process to help increase exhaust temps.
So the flap won't be doing anything.
Edit: page 55&63 common rail self study guide
2009 Jetta TDI 6spd manual 320,000 kms
2001 Jetta GLS TDI auto r.i.p.
VarmintSlayer is offline   Reply With Quote
Page generated in 0.16306 seconds with 9 queries
[Output: 125.56 Kb. compressed to 103.27 Kb. by saving 22.29 Kb. (17.75%)]
