Old July 25th, 2010, 16:59   #1
ldgratetdi
TDI(s): None :(
Fuel Economy: 51/48/35
Default 2001 TDI Jetta Injector Pump Bad?
OK, Friday I go to lunch, and it takes several seconds to get my 2001 5 speed with 260K miles started. She finally starts. I go to leave to go home, same thing. On the way home she seems a bit sluggish but nothing else unusual. When I get home I break out the Vag Com and I find: 17656 - Start of Injection Timing Regulation: Control Deviation. I check the timing and it is down around 10. I left it at 50 when I changed the timing belt at around 230K miles. Checked the bolts on the pump, nothing has slipped, now I am getting concerned. So I loosten the bolts and get the timing back at 50. Now it is even harder to start, and more sluggish. I can't seem to figure out how to post the trend, but I take it for a ride with group 4 up, and the actual timing is not following the request.
The fuel temp also seems a bit high, but I am guessing that wouldn't keep the pump from adjusting at all. Power is now off significanly. Anything else I ought to check before I try to find a rebuilt pump?
ldgratetdi is offline   Reply With Quote
Old July 25th, 2010, 18:43   #2
ldgratetdi
TDI(s): None :(
Found the notes on checking the case pressure relief valve, mine had moved about 2mm, I had hoped this might be it, no avial. I had to prime it to get it to restart, but still no luck. Any thoughs would be appreciated.
Old August 2nd, 2010, 21:15   #3
ldgratetdi
TDI(s): None :(
Status update, spent a bunch of time reading on the site. After bumping in the pump, it turns out things are somewhat better, but not great. When warm, it is a bit hard to start, and the timing is still consistently not correct. I have read about the seal change procedure, but since this appears to be a timing problem I am concerned if that will do any good. It is still drivable, fuel economy is terrible (she has drank a quarter tank in 250 miles). Just wondering if you have any thoughs on replacing the seals vs installing a rebuild IP. Any thoughts would be appreciated.
Old August 2nd, 2010, 22:13   #4
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
How about the fuel filter? And your last fill-up?
runonbeer is offline   Reply With Quote
Old August 3rd, 2010, 12:55   #5
ldgratetdi
TDI(s): None :(
Filter has about 20k on it, but I can easly pull fuel up into the pump using a mity-vac. I don't think it's a supply issue. It will run wide open throttle for long periods of time. As for the fuel, would that cause the injection timing to not follow the desired? It stays about 2degrees off at idle, and gets worse when the engine stutters or if you accellerate. Power is definitely off.
There doesn't appear to be any leaks, so I am assuming replacing seals wouldn't help anything. My concern is taking here down for a few days while I send it off to DFIS vs trying to find a new/rebuilt IP somewhere if all that is bad are the seals.
Old August 3rd, 2010, 13:06   #6
BobnOH
Fuel Economy: 50/45/35
17656/P1248/004680 - Start of Injection Timing Regulation: Control Deviation
Possible Symptoms
  • Loss of Power at high Engine Speeds
  • Engine difficult to Start
Possible Causes
  • Start of Injection Timing Regulation not OK
  • Injection Pump Control Range blocked/dirty (e.g. by Metal Particles)
  • Engine has stalled / ran out of Fuel recently
  • Wiring/Connectors from/to Injection Valve (N108) faulty
Possible Solutions
  • Check/Adjust Injection Start
  • Check Fuel Supply
  • Check/Replace Fuse(s)
  • Check/Repair Wiring/Connectors from/to Injection Valve (N108)
Special Notes
Old March 15th, 2013, 14:50   #7
Zampano77
TDI(s): 2001 Jetta
Fuel Economy: 45
Default ADVICE NEEDED: 2001 TDI ALH will not start any longer, just coughs every 3 seconds,
Adding to this thread. My 2001 TDI was having problems restarting after shutdown and the engine is up to operating temp. If you stop the engine, run into the store and try to restart it coughs once then spins and spins but no combustion. It did this for a couple of days and then it would not start even cold. Had to get to school so gave it a single sniff of starting fluid and she started and ran fine into school but after stopping the engine to drop off some books, she would not restart and will not start cold now, just coughs like she wants to start at the beginning but then just turns over with a few little coughs, very little, but will not run. Have made sure the fuel return is not leaking air, bled and primed the system via cracking the injectors at the head and all squirt fuel out well but still no start.
Took off valve cover, rechecked crank/ cam/ IP timing using TDIC forum stickyand all is lined up. TB replaced at 100K and looks good, new fuel filter. Not sure what to do, any ideas appreciated. Car has 160,000 miles with no real problems other than I had to drill the check valve out this winter as it would stall/ die while driving and not restart, the drilled check valve seemed to solve that. No VAGCOM codes other than faulty glowplug ( which has been there for years) and a ABS sensor.
If you have ideas, I am all ears and hands.
Thanks,
Johnny
Zampano77 is offline   Reply With Quote
Old March 15th, 2013, 18:43   #8
nukejet
Fuel Economy: 46 mpg
My did the same thing today but I had a guy look at it and he read a code that lead him to the fuel injection pump metering. He said he has ran into this before and will verify with the pump re-builder that they address this issue before he buys mine. I can find out the code on Monday to let you know more.
At first I had the symptoms of a slipping clutch but that was just the engine going into limp mode so no damage is done due to improper fuel delivery. My check engine light never came on also.
The Mechanic that gave me this diagnosis so far seems very competent after another mechanic told me that it was simply a turbo that was not working and I needed to go elsewhere.
Any questions let me know,
Reid
nukejet is offline   Reply With Quote
Old March 15th, 2013, 19:51   #9
dogdots
dogdots's Avatar
TDI(s): None
Thanks,
Johnny
Is the ASV sticking closed?
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old March 15th, 2013, 20:06   #10
akafred
my car was only running for 2-3 seconds it was the crank speed sensor, you can check for rpm in vcds while cranking, no rpm, probably sensor, also asv will cause this and imobolizer.
Thanks,
Johnny
akafred is offline   Reply With Quote
Old March 15th, 2013, 20:30   #11
Zampano77
TDI(s): 2001 Jetta
Fuel Economy: 45
Guys,
Thanks Nukejet, Dogdots, Akafred for the input, will check ASV, crank sensor and immobilizer tomorrow. Nukejet, I will let you know if I need your solution if these do not work.
Thanks again,
Johnny
Old March 16th, 2013, 18:45   #12
79_Limited
TDI(s): 2003 Jetta
Just throwing this out there...my injection pump "failed" recently. Dealer wanted $2k + for a new pump. I thought that was crazy.
Had it towed to my local guru. $200 and new pump seals it runs like a champ.
This may not be your problem but at least rule it out.
Current
2013 Beetle TDI auto
2013 GTI
Sold 2003 Jetta TDI auto 2008 VW New Beetle 1988 Porsche 911
79_Limited is offline   Reply With Quote
Old August 14th, 2013, 19:07   #13
Zampano77
TDI(s): 2001 Jetta
Fuel Economy: 45
Default Really late final reply
It was air getting into the system prior the IP. Replaces all soft lines, problem solved.
Thanks all.
Johnny
Page generated in 0.15385 seconds with 9 queries
[Output: 110.94 Kb. compressed to 93.01 Kb. by saving 17.94 Kb. (16.17%)]
