Old July 16th, 2010, 11:43   #1
buddman
Default Engine Splash Shield
I just bought a 06 Jetta TDI from a ligitimate mitsubishi dealer (so I thought) that said they did a complete 150 point inspection. Lot of things hidden were broken or missing, one of the things was the Engine Splash Shield or baffle. I went back to the dealer now for the 3rd time and asked about it, he told me that it did not come with it and it really was not a essential to the performance or safety of the car.
A friend of mine that knows more about cars than I even though he does not have a VW, said it is important for several reasons. 1. it deflects rocks and debris from puncturing or damaging a vital engine part, 2. Gas milage is effects due to all the air flow under the car is disrupted and 3. it ties the fenders and front body parts together,( must be why i get a vibration or rattle noise from the the front fender) not to mention this is part of the car and came with it from the factory. I trust my friend but wanted some other opinions before going back to Mitsubishi to raise hell.
PS. I found many other missing or broken parts hidden that they should of caught in the inspection. yes, I am really mad at myself as I did get ripped off on the price and on my trade in...... I dealt with 2 sales managers, a salesman, finance manager and the owner, They got me with the kill him with kindness close..... never been hit with that one before....
Bruce
buddman is offline   Reply With Quote
Old July 16th, 2010, 11:54   #2
BobnOH
Fuel Economy: 50/45/35
forget the stupid plastic belly pan, get a metal one installed
Old July 16th, 2010, 12:26   #3
icecap
Fuel Economy: 37 MPG Highway
Bruce
Get a metal skid plate since the oil pan on these cars has 4" of ground clearance and is paper thin die cast aluminum. Many have found this vulnerability the hard way and it cost them an engine. I have both the original plastic skid plate which does a great job of sealing up the engine compartment from road grime and a metal plate over the top to protect the underbelly. I've lost about another 3/4" of ground clearance but the metal plate can absborb quite an impact without damaging anything and by itself unless you get an original VW optional steel plate wont seal up the engine compartment as well as the factory plastic one does. I see you're in California so winter road salt and rainforest deluges should'nt be an issue needing a better road seal.
2006.5 TDI Jetta 5Spd. Black /Anthracite Pkg1
Have VCDS Hex + Can USB and many A5 & BRM Tools
icecap is offline   Reply With Quote
Old July 16th, 2010, 12:27   #4
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I would want at least one on it. I have a metal Panzer plate on my TDI, but the plastic was ok at keeping it clean and deflected most stuff. They also help keep the engine area a little cleaner. I would guess it helps keep the engine a little warmer in the winter.
That said, I would not worry too much about it, but if something happened to mine, I would replace it.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old July 16th, 2010, 12:50   #5
Aquaticmind
Aquaticmind's Avatar
Location: Wheeling, WV via Athens Georgia via, Bainbridge Is. Wa, via Carbondale IL, via Asheville NC
Fuel Economy: good
Go metal.. panzer plate here.
2003 Wagen, 2" lift, auto front springs, panzer plate, pp520 injectors, RCII+, ASR
Aquaticmind is offline   Reply With Quote
Old July 16th, 2010, 13:15   #6
MayorDJQ
You bought a VW from a Mitsubishi dealer....why would you expect them to know what is or is not original, missing, or necessary on a VW?
Their "150 Point Inspection" is worthless. Did you take it to an independent shop to have it looked at? Or maybe a nearby VW dealer?
MayorDJQ is offline   Reply With Quote
Old July 16th, 2010, 13:51   #7
BobnOH
Originally Posted by MayorDJQ View Post
...........Their "150 Point Inspection" is worthless. Did you take it to an independent shop to have it looked at? Or maybe a nearby VW dealer?
150 point inspection? I would laugh in their face.
Still, I would expect a 2006 sold at market value to have all it's parts and pieces.
Old July 16th, 2010, 14:24   #8
MayorDJQ
Very true, but the profit margin gets smaller and smaller when a used car need repairs. That's why they're claiming the splash guard is not necessary: they don't want to pay for it.
Old July 16th, 2010, 14:57   #9
procupine14
When selling a used car, most dealers won't fix anything that isn't necessary for the car to be safe or run/drive properly (properly being an operative word here). So who knows exactly what their 150 point inspection entails. I'm sure I can find 150 points on a car that are critical for a car to function and be safe.
procupine14 is offline   Reply With Quote
Old July 16th, 2010, 15:45   #10
Joe_Meehan
Joe_Meehan's Avatar
You might expect it, and I would want it to be so, but I believe in most locations, used cars are by nature "As Is"
Joe Meehan
Old July 16th, 2010, 17:53   #11
Franko6
I have a great example belt from someone who has no shielding under his car. It's the serpentine belt for an AHU.
There are 8 rock holes punched through the belt and a tear about 1" long.
So, even if you have a metal skid plate, you still need side shields.
Also, one of my Kansas clients showed up in March for a clutch. He lives down a dirt road (actually MUD, in March!). He has a panzer plate but no side shields. In order to start his clutch job, I took a shovel and dug out about 200 lbs of mud piled up on his skid plate and in his engine. That is the LAST TIME I'll so that...
I installed the side shields before reinstalling his panzer plate.
As a plug for DieselGeek.com, his 'Full Metal Jacket' sideshields work very well and really keep the engine bay safe and clean. the 'Full Metal Jacket' shields a much less inclined to break and crack as the OEM ones do.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old July 16th, 2010, 19:01   #12
buddman
Thanks, appreciate the input.
I think I'll see what they say and if no luck on the shield, I'll check out the diesel Geeks full metal jacket.
I know it was sold as is, I did bring the car back the very next day with other problems.
1. Back lower fender cover inside broken bracket, held toghether with sheet rock screw. Bumper Cover popped off by the time I got home.
2. Cracked right side of top engine Cover, not secured flopping around.
3. Trunk wont close without slamming it 5 or 6 times.
4. Lighter and 12 volt sockets out, when you replace fuse they blow instantly (found no pennies or debris in sockets).
5. Battery Clamp and bolt hold down missing, sides and top cover also missing.
6. Seat lumbar support broke.
7. Engine splash shield missing.
As of today this is all I know about. Also they did tell me that the timing belt would not be due until 90 to 100k, just found out it is now 80k on the 06', I bought the car with 70k.
Most of these problems should of been picked up on the inspection. They sold me the car at the KBB excellent shape price. If you ask any dealer in the US as to why pay more at a dealer instead of buying from a private party, they will all tell you the same thing. "We go through the car give it a 150 point inspection and make sure the car is in excellent shape and meets all standards, you never know what problems you'll find on buying from a private party" made good sence to me, so that is what I expected. Oh well.... I guess I just need to lick my wounds, and hope the car has no other issues that are more serious.
Thanks for the help.....
Bruce
Old July 16th, 2010, 22:25   #13
fossill
TDI(s): Golf
It's all buyer beware when it comes to used car buying. Those 150 point inspections more often than not are just "pencil whipped" up.
fossill is offline   Reply With Quote
Old July 17th, 2010, 06:36   #14
troopertripp
troopertripp's Avatar
Fuel Economy: 45-48 combined
Metal Skid Plate!
Post the name and address of the dealership just incase someone on here get a wild hair!
2000 Jetta GLS TDI Dark Blue 277,000(Mine)
2005 Mini Cooper Purple Haze 38,500(Hers) Cute!
2002 Jetta GLS 2.0 Silver 135,000 (Daughters)
1998 Cabrio 158,000 (Daughters)
troopertripp is offline   Reply With Quote
Old July 17th, 2010, 10:17   #15
rapidoxidationman
Fuel Economy: 32mpg with Yak rak, 40 w/o
Default Next time you buy a car
DO YOUR OWN 150 point inspection... BEFORE you buy it. There's gotta be a form somewhere on the internet.
Not to be a smarta$$, but "never trust the dealer".
k1 Jetta Automatic (120K and counting)
'03 Chevy K2500 6.6L DMax (130K and counting)
'88 Toyota Tercel SR5 4WD wagon (280K and counting)
rapidoxidationman is offline   Reply With Quote
Page generated in 0.17716 seconds with 9 queries
[Output: 125.35 Kb. compressed to 104.25 Kb. by saving 21.10 Kb. (16.83%)]
