Brake Switches
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
I got the following error. My brake pedal has 2 switches and 3 wire plugs
During the conversion I keep the original brake switch that active only the brake lights. When I passed the TDI wiring I putted the blue switch and connected it. The wire plug that connects to the brake light switch of the TDI wiring is unplugged. I think this the reason for the error since the ECU only receives the signal from one switch.
1- Would like to know if I can connect the wire from the TDI brake light to the wire of the original brake light to stop the error and be able to add the cruise control feature.
2- I also would like to know how to setup the length for the blue switch that connects to the T80/9 on the ECU.
João
João
