Old July 10th, 2010, 06:05   #1
mirzasila's Avatar
TDI(s): Jetta 2001
Default n95 airbag igniter problem
Hello to everyone,
recently my car throw airbag code (0588 - n95 airbag igniter driver side, resistance to high intermittent).
Strange thing is that when I clear code in VAG-COM and its cold outside everything is OK, but when its hot weather (temperatures above 20 degrees Celsius) error code returns.
Today again I connected VAG COM(it was hot outside). In the measuring block 001 for Driver side igniter value was unstable. For example 3 sec its "correct" and than 3 sec its "too high" and I didn't touch anything(steering wheel, connectors etc)
First I was thinking that the problem is in some of the connectors or clockspring but now it is more likely that my airbag is faulty. What do you gays think?
Jetta TDI 2001
mirzasila is offline   Reply With Quote
Old July 19th, 2012, 12:49   #2
Fuel Economy: 43/41/40
Mine did the same exact thing in measuring blocks, group 1.
JB05 is offline   Reply With Quote
Page generated in 0.12717 seconds with 9 queries
[Output: 47.25 Kb. compressed to 43.29 Kb. by saving 3.96 Kb. (8.38%)]
