Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Quebec
Quebec Quebec, Canada Section. This area is for people in Quebec who wish to discuss things more local to them.
Old June 29th, 2010, 08:29   #16
Blades
Originally Posted by Blades View Post
J'ai un excellent multimetre qqpart. Je vais voir pour l'apporter.
Je devrais être un homme libre de toute occupation professionnelle dans ... 1h30 !
J'ai encore une job la .....
'92 Cabriolet Full ABA, CE1 digi-2, MFA, 178000km
'92 Gold 1.6D, en cure de rajeunissement, 267000km
'01 Jetta GLS TDI, 323000km, SMF VR6 clutch kit, 0.216, MR Tuning custom triple program chip
Blades is offline   Reply With Quote
Old June 29th, 2010, 08:47   #17
budweiser182
budweiser182's Avatar
je vais briller par mon absence ce soir!!!
budweiser182 is offline   Reply With Quote
Old June 29th, 2010, 09:07   #18
makita
makita's Avatar
Pour ceux qui aiment ca, un bon café expresso:
http://homepages.cae.wisc.edu/~rutland/research.dir/NOx_water/2000-01-2938.pdf
"The diesel Beetle was time tested on the Nürburgring in 1951 and achieved 0-100 km/h (0-60 mph) in a faily good one minute"
makita is offline   Reply With Quote
Old June 29th, 2010, 09:09   #19
Blades
Tu veux pas passer ta frustration professionel ?
Old June 29th, 2010, 09:12   #20
XaV_T
XaV_T's Avatar
Send a message via MSN to XaV_T
Hon...!
Jetta MK3 coupe TDI PD150, GTB2056VL, FMIC, PD220 nozzles, MAF cancel, MRTuning chip, 02M DRW 6-speed ... soon GTB2260VK
Jetta 1985 TDI AHU, GTB1756VK, 11mm OEM pump, MK4 ECU, .205x6 nozzles (en construction)
Originally Posted by cog View Post
last time i saw a crack that big i had visited the wrong website
XaV_T is offline   Reply With Quote
Old June 29th, 2010, 09:39   #21
Blades
Originally Posted by XaV_T View Post
Hon...!
Semaine de 3 jours, ma prendre le cash du 1er !
Old June 29th, 2010, 09:50   #22
Rammstein
Fuel Economy: l/100 km: 5.53/4.77/4.15; USmpg: 42.5/49.6/56.7; IMPmpg: 51/59.6/68.1 AVERAGE RANGE PER TANK:2007.9 KM; 1247.65 MILES
Je devrais y être.
Rammstein
Efficient and different by choice!
Originally Posted by Sorin
The only guy that's really into big HP and speed is Rammstein
Originally Posted by Cabok
Pis si tu es bien gentil, il va aller au Club Price pour t'acheter une palette ou deux de torque...
Rammstein is offline   Reply With Quote
Old June 29th, 2010, 10:50   #23
budweiser182
et personnelle (mk2)
Old June 29th, 2010, 10:55   #24
XaV_T
XaV_T's Avatar
Il refuse de rouler?
Old June 29th, 2010, 11:05   #25
Blades
Il cherche un turbo !
Old June 29th, 2010, 11:24   #26
XaV_T
XaV_T's Avatar
VNT20 amoché...
Un 2260, s'tu trop gros?
Old June 29th, 2010, 11:37   #27
budweiser182
VNT20 amoché...
si c'est pas bolts on sur mon manifold, downpipe, arrivé et retour d'huile, j'en veux pas.
Old June 29th, 2010, 12:14   #28
XaV_T
XaV_T's Avatar
Dommage...
Veux tu que je t'aide à en trouver un autre VNT20? Au cas où je mettrais la patte sur un pas cher.
Il doit être quand même roulable ton 20!
Old June 29th, 2010, 12:18   #29
dieseleux
Théoricien
dieseleux's Avatar
TDI(s): Jetta TDI 98
Fuel Economy: 4.42L/100km
Je les pas entendus mais celon la description... il tombe debalancer quand il travaille, il en sort un son pas tres plaisant!
Il lui faudrais une job de redressisement et de balance pour dir le remettre sur la route.
Dieseleux
Jetta 98 AHU, 515,000km, Door Hinge Mod, GTB2056VL, 0.216um, 11mm/DE143 MK4 OEM Pump, Custom Chip for VNT on AHU ecu, HID Carelo headlight, Trunk Bed Mod.
Best tank:1311.5km (814.92miles) with 53.687L (14.1826us gal) for 4.086L/100km (57.56us mpg)
And Jetta GLS 2002 ALH stock...
GTB1756VK in my hand, ready to install on ALH!
dieseleux is offline   Reply With Quote
Old June 29th, 2010, 12:25   #30
Blades
J'ai encore ma job parce qu'il a pas reussi a trouver meilleur pour plus cheap.
Meme le russe qu'ils ont mis a l'essai hier a dit non assez vite !
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.13813 seconds with 9 queries
[Output: 125.25 Kb. compressed to 102.95 Kb. by saving 22.30 Kb. (17.81%)]
