Old June 22nd, 2010, 22:47   #1
Whitbread
Whitbread's Avatar
TDI(s): Several
Default B4V VNT17/22 Conversion How To
I was recently approached by a gentlemen with a squeaky clean passat who wanted to convert to VNT. Well, I started on it later yesterday and after today, here's where I'm at.
This is the biggest obstacle. Trying to a fit a 17/22 just wasn't going to happen with the stock cast alum bracket. Some 1/4" steel was called into duty.
.400" spacer needed to make everything line up all nice.
The engine mount also needed some massaging to clear the actuator under engine movement.
Hmmmm, that's not a K03
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old June 22nd, 2010, 22:48   #2
Whitbread
Whitbread's Avatar
TDI(s): Several
Reserved for picture use.
Vacuum ball mounted. Used some 3/4"x1/8" aluminum.
N75 mounted
Everything all tucked away
Don't worry, the one worm clamp is not permanent.
Not a necessity, but why not at this point?
Very minimal trimming. Can't even tell
02 Jetta TDI
Old June 22nd, 2010, 22:48   #3
Whitbread
Whitbread's Avatar
TDI(s): Several
Alritey, now for the technical details;
For the computer, that's all in your tuners magic so effort on your part is needed there.
If you can get the N75 out of a 99.5 mk4, it will plug right in. Otherwise just switch the connector for the later style one. Hook up the OUT line to the turbo, VACUUM to your vacuum source, and then ATMO to an atmospheric vent. In this application I'll be using a small fuel filter and a short piece of line instead of running a line all the way to the other side of the car to the airbox.
With the vacuum ball, just make sure the white end of the check valve faces the ball. And make sure you tap vacuum before the check valve for the brake booster.
That's all really. It was actually much easier than I was expecting. I don't know why every mk3 doesn't have at least a vnt15 on it .
02 Jetta TDI
Old June 23rd, 2010, 02:06   #4
Digital Corpus
Digital Corpus's Avatar
Did you make the 1/4" steel engine mount? If so, any plans on making it publicly available and for what cost?
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old June 23rd, 2010, 04:36   #5
VWannabe
I would also like to know about the mount. Somewhere I read that a possible OEM solution to the mount was to use the ABA 8-valve rear motor mount bracket. I cannot attest to the feasibility of this but I thought I would mention it.
Also, I have read about several conversions and none of them modified the actual motor mount. Is this due to the size of the VNT 17/22?
Is the exhaust manifold you are using the integrated one or is this a separate manifold and turbo? And what else is needed? Will a stock A4 downpipe work on the A3/B4 chassis or is this custom? Lots of questions I have!
VWannabe is offline   Reply With Quote
Old June 23rd, 2010, 06:46   #6
Whitbread
Whitbread's Avatar
TDI(s): Several
Yes, I made the mount. I could easily make some for sale but in all honesty I'm so busy I couldn't even think about making some till mid-late august at the soonest. However, Shortysclimbin is making them and has a post for up for them in the vendor section. Probably the best bet if you need one asap.
I don't know about the ABA mount working or not. I would be doubtful of it working with a 17/22, it's freakin huge and needs a crapload of clearance. Maybe a 15 or straight 17 though.
We're using a 17/22 from IDparts for a mk4 ALH. The OEM mk4 oil return line also works perfectly. Just make sure to order the fitting that screws in the block also. The oil feed will have to be custom SS braided hose though.
As for a dp, it's going to be custom SS since this car already had a custom full SS setup I did a while back. I don't have a OE mk4 dp laying around to test fit. I had 5 or 6 last week but I just took a load to the scrap yard haha.
02 Jetta TDI
Old June 23rd, 2010, 10:41   #7
Stealth TDI
Pre-Forum Veteran Member
Stealth TDI's Avatar
Nice project! I'm looking forward to reading details on how to switch from pressure-activated N75 to vacuum; plus other wiring updates. The availability of the modified engine mount makes this swap a tad more attractive. Will you be switching to a European ECU? Or can you make this work with the stock ECU and remap?
| .M y . S t a g e . 2 . G T I . |
| Facebook | YouTube | Fuelly |
Stealth TDI is offline   Reply With Quote
Old June 23rd, 2010, 10:43   #8
r90sKirk
r90sKirk's Avatar
Me too, Matt.Kirk
Honest TDI Enthusiast Performing Competent TDI Work
2013 Passat TDI SE 151k Opera Red, 2000 Golf TDI 461k Bright Green, 2015 GSW (6MT) Pure White 38k, 1977 BMW R100RS 166k Silver Ice,
r90sKirk is offline   Reply With Quote
Old June 23rd, 2010, 14:29   #9
Sprocket
Sprockette's hubby
Sprocket's Avatar
Subscribed! Sure is looking good so far
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old June 24th, 2010, 06:14   #10
G60ING
G60ING's Avatar
the aba mount is the same at the tdi's bracket
G60ING is offline   Reply With Quote
Old June 24th, 2010, 20:01   #12
Sprocket
Sprockette's hubby
Sprocket's Avatar
Originally Posted by kooyajerms View Post
Is that yours Jason?
Yes, it is buddy BTW, I was very sad to read about your turbo issue. I hope it gets resolved quickly & hopefully it's just isolated to the turbo
Stealth, it will still be the GQ ECU just flashed to the European AFN software for VNT. I'm still unsure at this point what stage of RC I'm getting from Jeff. I'm letting him decide what is best to go along with all of the other supporting hardware changes (PP520's, FMIC, 2.5" SS Turbo back exhaust)
Matt your doing a great job!!! I think I'll wait on the Colt Cam until I'm due for the next timing belt change.
1996
Old June 24th, 2010, 21:44   #13
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
Me too, Matt.Kirk
Easy... use N75 of MK4 ALH and same hose rooting of MK4, after, put AFN ECU chip. (for same connector, use N75 of 1999.5, more expensive than 2000-2003 N75!)
GTB2056VL work great on my 028906021JB ECU. (Jetta 98 AHU)
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old June 29th, 2010, 23:00   #14
Whitbread
Whitbread's Avatar
TDI(s): Several
Some new pics and a little bit of tech info updated .
Just have a build a dp tomorrow morning and it's test drive time!
02 Jetta TDI
Old June 30th, 2010, 08:34   #15
kooyajerms
grocery getter
kooyajerms's Avatar
Yeah we'll see Jason, even if it's just the turbo, it still means I may need to change over to a different vnt 20. You've got my fabricator in person, so you'll have better luck than I ever will. Glad to see you got an fmic too.
More fuel Jason, more fuel. Do it before you get retuned! That thing can take 764's for sure.
kooyajerms is offline   Reply With Quote
Page generated in 0.20721 seconds with 9 queries
[Output: 138.75 Kb. compressed to 116.15 Kb. by saving 22.60 Kb. (16.29%)]
