Old June 18th, 2010, 09:12   #1
jettoturbo
jettoturbo's Avatar
Default Harmonic Balancer?
Anyone know where to get a cheaper harmonic balancer. The shop my jetta is at is saying $258 is this reasonable?
98' Jetta 1.9L TDI--bone stock except for the 14" alloy wheels
jettoturbo is offline   Reply With Quote
Old June 18th, 2010, 09:14   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
VW list price for that part is over $400, part number 028-105-243-T.
Places like www.IDparts.com www.worldimpex.com www.metalmanparts.com www.dieselgeek.com www.boraparts.com may sell one for less.
Make sure the crank snout is inspected by removal of the timing belt and sprocket too.
oilhammer
www.cardocautomotive.com
Old June 18th, 2010, 09:42   #3
jettoturbo
jettoturbo's Avatar
Wow thanks that just saved me a ton of money. Metal Man Parts had the same part for $80 and autozone quoted $418 the shop my car is at quoted $258. It's amazing how doing alittle research can save time and money.
Old June 18th, 2010, 09:48   #4
dslg60
dslg60's Avatar
Fuel Economy: 45
Got mine from AZautohaus. If memory servrs it was about $60.00.
dslg60 is offline   Reply With Quote
Old June 18th, 2010, 12:46   #5
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
And add in the cost to replace the one-time-only stretch bolt that holds that sprocket onto the crank.
Do NOT re-use the removed bolt. It will NOT hold the sprocket adequately if it is re-used. Within a few hundred miles of your inspection and re-installation of the used bolt, you will be in need of a new sprocket, maybe a new crank, or valves, or pistons, or rods...
Svante Arrhenius 1896
Old June 22nd, 2010, 15:18   #6
Radio Steve
Fuel Economy: Best 58mpg (UK gals)
Hi All,
What is a harmonic balancer and where is it??? (mk3 golf 1z eng 1995)
My car suffers from vibration through the bodyshell at certain revs, any ideas what it could be????????????
Thanks in advance of advice
Radio Steve is offline   Reply With Quote
Old March 15th, 2013, 04:37   #7
steadyhand
Fuel Economy: ~39 - 42 mpg
An old thread -sorry. I've purchased a new Harmonic Balancer (and serp belt, alt pulley) and I don't know the proper bolts to buy (for Balancer wheel)....??
This will go on the '05 BEW. Anyone know the size of those HB stretch bolts? (I just realized this is in the wrong section - will move).
steadyhand is offline   Reply With Quote
Page generated in 0.15632 seconds with 9 queries
[Output: 77.00 Kb. compressed to 66.16 Kb. by saving 10.83 Kb. (14.07%)]
