Old July 21st, 2017, 12:27   #106
Rub87
Originally Posted by Libang View Post
There is no problem to change frequency in SW ...
5min job with osciloscope .
says 833 Hz, sounds a bit much.. or you do /64? then its 14 Hz, sounds bit low
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old January 24th, 2018, 17:24   #107
senso
How did this end?
Interested in this
senso is offline   Reply With Quote
Old January 27th, 2018, 23:58   #108
Booxter
TDI(s): 1.9TDI AVB
Fuel Economy: 4.8l/100Km
Passat b5 AVF 1.9TDI GTB1756VK
The mechanism of the actuator GTB1756VK, electronics Mercedes
Works very fast, but you have to adjust the N75 map
Booxter is offline   Reply With Quote
Old July 6th, 2018, 03:14   #109
Booxter
TDI(s): 1.9TDI AVB
Audi 1.9tdi AFN GTB2056VL
Old July 6th, 2018, 05:58   #110
bhodgkiss
Is the AFN standard internals please?
What power/torque now?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old July 10th, 2018, 12:20   #111
Booxter
TDI(s): 1.9TDI AVB
0.260 nozzles + 10mm pomp
Standard internals, strong clutch, audi a6 2.5tdi intercooler, I think about 200+ hp
Old November 10th, 2018, 09:50   #112
shanky887614
TDI(s): vw caddy arl
would someone on here be able to tell me what to buy and be able to adjust my map etc for this on a gtb2260?
on an edc16 ecu with an n75 valve pd1.9
Sent from my ASUS_X00ID using Tapatalk
shanky887614 is offline   Reply With Quote
Old November 11th, 2018, 20:22   #113
travis45
travis45's Avatar
There was a a guy with an Audi who had a GTB2260VK, Darkside piping, WM kit who ended up doing the buy back about 2 years ago. He claimed to be using the electronic actuator successfully.
Can't remember his name.
14 Sportwagen GTB2260vklr Turbo, Rawtek turbo back exhaust, Malone custom tune, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, KW V3 Coilovers, H&R 22mm rear sway bar, PolarFIS, Darkside intercooler and piping, Wavetrac LSD. Soon to install Colt billet stage 3 cams w/upgraded springs, ARP Headstuds.
travis45 is offline   Reply With Quote
Old November 14th, 2018, 17:07   #114
adamss24
Fuel Economy: 35-45mpg
Couple of people have done it in Europe, either using a piggyback box to modify the signals from edc so that the actuator works properly, others have created a Frankenstein type of actuator with Mercedes/Audi guts and modified n75 map and a lot more to make it work. Personally, on a car that old I would just use vacuum converted turbocharger- less hassle to tune...with decent results !
adamss24 is offline   Reply With Quote
Old November 16th, 2018, 03:16   #115
Byd1380
If you use the correct actuator it works with the same PWM signal from EDC15. I ran it for a while just playing about. You can also adjust the range of the N75 map to move the end stops etc.
I still have an actuator and connector here, if someone wants to play, I made up my own M6 rod aswell.
Ivan
Byd1380 is offline   Reply With Quote
Old Yesterday, 16:20   #116
ErackTDI
i have a bew with gt2056v working with the electric actuator on edc16
both wires from n75 and a ground and some software changes is all it takes
then a tune to match everything and your all set
ErackTDI is offline   Reply With Quote
Page generated in 0.16586 seconds with 9 queries
[Output: 98.65 Kb. compressed to 83.24 Kb. by saving 15.40 Kb. (15.61%)]
