Old November 23rd, 2012, 07:53   #46
Libang
Libang's Avatar
TDI(s): TDI power :)
If you connect only +12 V Pin1, Pin2 GND and PWM PIN4 so that made this
Servo VW , el. MB
http://www.youtube.com/watch?v=k7vEurZ36WE
Fabia RS ASZ
Transporter T4 AHU
Golf 2 AGU
Libang is offline   Reply With Quote
Old November 24th, 2012, 04:04   #47
Rub87
seems to hold its postion, but doesnt do the actuator test..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old November 25th, 2012, 12:31   #48
netopier
Fuel Economy: 7,0 L/100 km
thats because of incorrect freq i think , we will test it wirh libang when we find how to change PWM freq correctly
netopier is offline   Reply With Quote
Old June 18th, 2013, 22:56   #49
Libang
Libang's Avatar
Any news?
Fabia RS ASZ
Transporter T4 AHU
Golf 2 AGU
Old March 7th, 2014, 17:29   #50
Demon Diesel
Any updates on this. I've made some progress on the software side but need the actual MB servo to test. What is the part number for the MB servo?
Demon Diesel is offline   Reply With Quote
Old February 5th, 2015, 13:45   #51
GOFAST
GOFAST's Avatar
TDI(s): vento afn
I think this is a very interesting mod on a old diesel like my VP.
is there anyone how can confirm that this has actually worked successfully on a daily car.
I've got most of the components.
GOFAST is offline   Reply With Quote
Old February 11th, 2015, 06:10   #52
GOFAST
GOFAST's Avatar
TDI(s): vento afn
anyone ??
Old March 24th, 2015, 02:44   #53
ivohi
TDI(s): AVG B5
If anyone interested then I got gtb turbo hella actuator working on my car. It is direct fit because takes pwm with frequency 300Hz like EDC15 outputs.
Hella part number 6NW 009 228
https://www.youtube.com/watch?v=9pZFT1GeIY4
No mods, no hassle
ivohi is offline   Reply With Quote
Old March 24th, 2015, 06:39   #54
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
That's great news!
Old March 24th, 2015, 12:51   #55
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
Nice work ivohi
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old March 24th, 2015, 13:35   #56
cycleracer88
No mods, no hassle
Which pins do you connect? ....great if it will work on VKLR's
cycleracer88 is offline   Reply With Quote
Old March 25th, 2015, 01:55   #57
ivohi
TDI(s): AVG B5
Pin1 - +12V
Pin2 - Ground
Pin4 - Pwm
Old January 26th, 2016, 08:00   #58
arazvan2002
arazvan2002's Avatar
Originally Posted by dieseleux View Post
Thanks!
I test and if it work like i think... i intall on my gtb2056vl
Dieseleux
I know that you didn't installed the VL with this electronic actuator. Why? Did you tried ?
Sent from my HTC One_M8 using Tapatalk
A4 B6 1.9 TDi AVF quattro - development in progress: remaped, GTB2056VL. ARL inj, FMIC, 320/288mm B7 brakes, OEM Sport suspension, B7 Steering wheel MFSW.
arazvan2002 is offline   Reply With Quote
Old January 26th, 2016, 08:32   #59
Rub87
big problem with elec actuator is that its bolted to compressor housing and makes it really a pain if you need to reclock the comp housing with respect to the center section. it can be done but its not as straightforward as vacuum conversion.
Old October 6th, 2016, 14:42   #60
Byd1380
I bought this model of actuator but it won't work with the N75 signal. mine is the G35 version. Any ideas?
Ivan
Byd1380 is offline   Reply With Quote
Page generated in 0.16711 seconds with 9 queries
[Output: 120.93 Kb. compressed to 99.83 Kb. by saving 21.10 Kb. (17.45%)]
