Old November 23rd, 2010, 23:57   #31
CERBER
Banned
TDI(s): AAZ
great things I've read here, got to turn new page and forget the vacuum control...
CERBER is offline   Reply With Quote
Old November 24th, 2010, 02:15   #32
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
Fuel Economy: approx 50
Don't want to sound daft but is it possible to retrofit these to standard 'v' (not gtb) turbos?
looks like a very fast and precise system to me!
Dakta is offline   Reply With Quote
Old November 24th, 2010, 03:53   #33
Rub87
should be possible, but these electronic controlled turbos use a longer lever, in theory you could just limit the duty cycle range in the software to overcome this..
also remeber you don't have a stopscrew, to you need to limit maximum vane closure precisely also in the software..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old November 24th, 2010, 10:08   #34
T3-UN1
Everything is possible! But the benefit is not that much... A faster closed loop is a nice feature but not so important.. also because its not that much faster . OEMs also use this type of actuator because of more precise feedback and temperature/error return.
And of course, if you use it on old EDC its only plug n play with hardware..
There is a lot to do with software! Rub already mentioned the missing stop screw thing and there is also precontrol/PID Maps of governor that must get adjusted heavily...
Normally, on newer EDCs you have a special map for max duty cycles in relation to rpm and mg/str.. this is more or less stop screw map...
dont know how to fix it in EDC15 for now .....
T3-UN1 is offline   Reply With Quote
Old November 24th, 2010, 10:28   #35
Rub87
you can do it maybe with the 16x1 limiter map?
Old November 24th, 2010, 10:50   #36
T3-UN1
Give me a hint? Lable name from A4 ols Project
Old November 24th, 2010, 11:11   #37
Rub87
don't know the name, but you usually find them slightly above the boostmap(s), rpm vs duty.. you have 2 of them, one is min duty, set a 5% (95% in vagcom) everywhere, the other starts around 75-80% and tapers down at higher rpm to prevent excessive van closure at igh rpm..
but you are right, I also do prefer the 3d maps as in edc16
Old November 24th, 2010, 11:41   #38
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
Thanks for the friendly responses!
Software isn't such an issue as I'm using an ancient ecu - it'l end up being a homemade controller just like this lads mosfet setup except with the control routines and sensors too - just wondered if it could be bolted on as I have limited space for an actuator, it fits but it's too close to my car's driveshaft for comfort.
Might be something to look at good stuff keep researching
Old November 24th, 2010, 12:09   #39
T3-UN1
Ah... 72E18 and 72E5C n Audi A4 ols... Didnt know about that...
But a limiter which depends on load would be better as an over all limiter...
i have to measure duty cycle for a minimum vane gap. and set it as max limit.. but why to liit in the other direction?
Old November 24th, 2010, 12:22   #40
Rub87
not real use in other direction unless you want to keep vanes closed for what reaosn so ever
Old November 24th, 2010, 12:28   #41
T3-UN1
Yeah, thats what I thought...
Old December 22nd, 2011, 04:28   #42
Rub87
Does anyone know the function of the 2 remaining pins of the hella actuator? My scope died so I cant verify it.. 3 or 5 must be feedback or? 0-5v or pwm or..?
Old June 27th, 2012, 16:42   #43
netopier
Fuel Economy: 7,0 L/100 km
is this thread dead?
or is there another which solved the electronic actuator issues for edc15?
cheers
netopier is offline   Reply With Quote
Old November 22nd, 2012, 17:44   #44
Libang
Libang's Avatar
TDI(s): TDI power :)
Originally Posted by T3-UN1 View Post
News... I just tried an output test on the bench(still dont have it installed in the car )
http://www.youtube.com/watch?v=NQ36-fiV3Vk
Did you use this wiring ?
thanks for reply
Fabia RS ASZ
Transporter T4 AHU
Golf 2 AGU
Libang is offline   Reply With Quote
Old November 23rd, 2012, 06:36   #45
Rub87
why does there need to be a mosfet? i would just run a prarallel resitor with comapreable resistance to the N75 coil, and then feed it direct to the actuator
Page generated in 0.14792 seconds with 9 queries
[Output: 122.72 Kb. compressed to 102.08 Kb. by saving 20.64 Kb. (16.82%)]
