Old July 12th, 2010, 03:15   #16
T3-UN1
I ve got an edc15vm+ ecu (ALH). Does someone know if pin 62(N75) valve is pwm "-" or "+"? I think its PWM "-", but for box we need pwm "+"....
Does someone know or could maybe measure the amplitude(not the voltage, because it depends on duty cycle) of the signal? I think it should be 12V....
T3-UN1 is offline   Reply With Quote
Old July 12th, 2010, 10:19   #17
T3-UN1
This is what im gonn try, when the harness will be in the car(engine conversion ist still not done..)
I will report if it works or not...
Old July 14th, 2010, 10:20   #18
Rub87
KKK actuators also work with the pwm, as did the one I found on volvo 2056vl, but the vag don't even have the the power electronics inside the controller so it's alot more work if you want to use one like that
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old July 14th, 2010, 10:28   #19
T3-UN1
yes i know.. because of that i use the mercedes benz electronics with the vag e-motor and lever...but still not enough "power" from the mosfet inside the ecu... the way i go is more or less plug n play.. just put the extra little mosfet and resistor inside the ecu and i hope everything will be fine...
Old July 14th, 2010, 12:00   #20
T3-UN1
These are my actuators. Left side is MB, right side is VW.
At the last picture, the upper one is MB. You can see that the levers are different. so I took the MB electronics with the VW Mechanics to fit a workin actuator on my GTB1756vk on a 1.9 TDI VP 37 AFN 110 HP with ALH Harness and ECU....
Here is a vid of the moving Actuator:
http://www.youtube.com/watch?v=q0qEYEmnLvY
Old July 14th, 2010, 13:22   #21
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
That is very cool. subscribed
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Old July 17th, 2010, 00:43   #22
Rub87
so you just built a device with locked frequancy and are changing the duty.?
I also did that a long time ago for a bv-50, but the frequency wasn't stable enough.. I should just have triggered the singal on feedback signal of the actuator, (140-150Hz) IIRC and put the pwn signal on that, but my electronic skills are quite limited :/
Old July 17th, 2010, 04:25   #23
T3-UN1
I can adjust frequency and duty cycle... but if I put it to 140Hz, frequency is also changing whith different duty cycles... But it doesnt matter for me. I just used the device for testing that vag mechanics work with mb electronics.
By the way, I didnt build this controller... I just bought it for 20€ from www.elv.de . I dont have any electronic skills too
Old July 17th, 2010, 05:43   #24
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
You say the MB controler (left side, the white and blue board with big chip) run with PWM when you connect like your schematic (pin1 +, pin2 GND, pin 4 PWM input)?
I have this model found on GT2056 of Jeep Cherokee!
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old July 17th, 2010, 05:47   #25
T3-UN1
Dieseleux
YES, you are right.. MB works wit Pin 1,2,4 -> +vcc, gnd, pwm
good luck
Old July 17th, 2010, 09:09   #26
dieseleux
dieseleux's Avatar
Thanks!
I test and if it work like i think... i intall on my gtb2056vl
Dieseleux
Old November 22nd, 2010, 12:20   #27
T3-UN1
News... I just tried an output test on the bench(still dont have it installed in the car )
http://www.youtube.com/watch?v=NQ36-fiV3Vk
Old November 22nd, 2010, 13:21   #28
dieseleux
dieseleux's Avatar
Nice!
Dieseleux
Old November 23rd, 2010, 13:07   #29
Rub87
so you just conected the N75 output to the actuator input? did you use a resistor to replace the N75? otherwise I think the ecu will throw a dtc and shutoff the N75 signal?
Btw, turbo arrived today, looks good, thanks!
Now when I would find I car can easily swap between 1756vk and the 1749vk as HP
Old November 23rd, 2010, 13:16   #30
T3-UN1
I didnt use a resistor.
For the moment I have so many DTCs (working on bench) that I dont know which one I should take for real and which one not... Maybe I need to work on Hardwaredriver/DTC code in Soft, but that should not be so difficult. amperage should be lower on electronic actuator. maybe thats all...
Good to hear that everything went good with gtb1749vk... and yes, its interchangable with gtb1756vk exhaust side.....
Page generated in 0.18261 seconds with 9 queries
[Output: 123.23 Kb. compressed to 102.57 Kb. by saving 20.66 Kb. (16.76%)]
