Old June 14th, 2010, 17:08   #1
T3-UN1
Default GTB Turbo with orig actuator on edc15/msa15?
Im wondering if one can use the gtb turbos with their original electric/mechanic actuators (eg 6NW 009 483 / 761963) in combination with msa15 edc15+ ecus.
I guess, the gtb1756 actuator is controlled by PWM. (some of them are CAN).
As you know, one can change frequency and duty cycle in edc/msa.
does anybody know what pwm frequency/voltage the hella actuator from garrett/vag are runnning with?
T3-UN1 is offline   Reply With Quote
Old June 16th, 2010, 10:39   #2
oldpoopie
oldpoopie's Avatar
If this could be done it would make things much easier than modding the actuator lever.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old June 16th, 2010, 12:38   #3
hatemi
I have the impression that you cant use the VW servo but you could use one from MB CDI.
www.tdituning.fi
hatemi is offline   Reply With Quote
Old June 16th, 2010, 12:41   #4
T3-UN1
it seems you know more about that?
I heard about different versions (can/pwm). what do you think, why is it not working?
Old June 16th, 2010, 12:46   #5
hatemi
VW uses can and MB uses PWM. The N75 solenoid uses PWM aswell. You might have to change the frequency of the signal to get it work properly, but that should be doable.
www.tdituning.fi
Old June 17th, 2010, 08:03   #6
TDIfreak
Yes VAG uses CAN and I can sell box to use between PWM signal and VAG servo.
Otherwise MB or BMW servo is the way to go, they use PWM at different frequencies. The servo itself is too high in resistance compared to N75 solenoid so some custom connections are needed .
TDIfreak is offline   Reply With Quote
Old June 17th, 2010, 09:30   #7
T3-UN1
so you have a Box that converts PWM to CAN? nothing else is needed?
How much is it?
For the MB actuator I need an amplifier to work on edc ecu?
Do you have some links or infos on the web or is it all based on your own studies?
Old June 17th, 2010, 10:00   #8
X@V
X@V's Avatar
Very interesting, for my PD150 GTB2260VK!
Jetta 1985 PD150, crazy QUATTRO!
Audi A4 B7 Quattro : V6 TDI project
Jetta 2009 TDI dsg, GTB1756VK + custom tune = fun!
X@V is offline   Reply With Quote
Old June 17th, 2010, 12:07   #9
TDIfreak
How much is it?
PM sent.
Old June 17th, 2010, 13:18   #10
hatemi
I think Ill need to call you tomorrow
www.tdituning.fi
Old June 17th, 2010, 13:53   #11
X@V
X@V's Avatar
PM sent!
Old June 17th, 2010, 15:28   #12
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
This is great! There are huge positive implications about this. Imagine doing away with the N75 completely and having full servo-electronic boost control, even for early engines. Plus with some signal wizardry you can customize the boost and response...
TDIfreak, you need to work on this!
Old June 17th, 2010, 15:46   #13
sid_bora_tdi
TDI(s): bora
im very interested in this could someone send me some info on this box
sid_bora_tdi is offline   Reply With Quote
Old July 8th, 2010, 00:26   #14
oldpoopie
oldpoopie's Avatar
Bump on this. Fedex delivered my gtb2260vk today!
Old July 11th, 2010, 14:58   #15
T3-UN1
VW Hella box is not working..
Got my GTB1756VK working wit VW/Garrett Actuator Mechanics and MB/Garrett Actuator Electronics. I controlled it with pwm generatpor at 12v amplitude pwm with 140 Hz.
The max. amperage what i measured was 10mA. I dont have a working edc15 over here, so i cant test. I'm also not sure what amperage is max for EDC, but i think we can solve that with an aditional or just changing mosfet in ecu!
Page generated in 0.18879 seconds with 9 queries
[Output: 120.40 Kb. compressed to 99.41 Kb. by saving 20.99 Kb. (17.43%)]
