Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+)
VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+) Discussions area for A6/MkVI (2010+) Golf and Golf Wagons (Jetta Sportwagon in the USA).
Old June 7th, 2010, 13:21   #1
oilhammer
oilhammer's Avatar
Default CR engine HPFP analysis
This is the sharing of info thread, to post pics and possible causes.
These are from a 2009 car, not my pics and if the sender wants to be identified it is up to him.
Here is the pump taken apart. Note the left end of the part labeled 'piston' is where the little tiny roller is located.
Closeup shot of that piston's roller:
Close up shot of the shaft cam that roller rides on:
I have another one here, looks pretty much the same EXCEPT it has no signs of the rusty residue on it. In fact, it is squeaky clean inside.
This is the shaft, you can clearly see how much is worn away at the apex of the cam lobes:
And here is the little roller piston:
Sorry for the crappy focus, my camera is old and my skills are even older. But the wear marks on the roller could very well have been caused by the little roller getting turned off-square from the shaft's cam lobes.
oilhammer
www.cardocautomotive.com
Help out the TDI club raffle car! :http://forums.tdiclub.com/showthread.php?t=362827
Old June 7th, 2010, 13:28   #2
Luv My 02 TDI
Fuel Economy: 52/48/44
Any doubt that the rust on the camshaft is rust? Could it be varnish or a protective coating from when it was made? It looks like that edge is beveled.
2010 Jetta TDI sedan White Gold Metalic / Titanum Black W/ underseat drawers and Dash cubby / 2002 Jetta TDI//1999 NB TDI SOLD ***Before you post ANYTHING .. CLICK HERE !!!***
Luv My 02 TDI is offline   Reply With Quote
Old June 7th, 2010, 13:50   #3
dieseldorf
top post dawg
dieseldorf's Avatar
Brian, is that rust or overheated (coked) fuel?
The cam surface looks rough... clearly lost the ground surface and was wearing out, which is a source of heating
Are you going to be able to pull that roller out of the piston and get more pics?
Old June 7th, 2010, 13:53   #4
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 40-47 mpg: 12 Touareg TDI, 36/31/29 mpg:
So to me it begs the question would a "lubricity agent" such as Power Service, etc have prevented the camshaft and roller it sits in from scoring?.
Keep in mind VW does NOT recommend lubricity agents such as Power Service, etc.
ruking is offline   Reply With Quote
Old June 7th, 2010, 14:49   #5
DoctorDawg
DoctorDawg's Avatar
Houston, we have data! Thank you, oilhammer and mystery donor! Keep it coming.
Can you share any metadata...how many miles on engine at failure, did the owner use an additive, failure mode, etc.?
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
DoctorDawg is offline   Reply With Quote
Old June 7th, 2010, 14:54   #6
oilhammer
oilhammer's Avatar
Just to clarify, the above pics were sent to me, they are not mine, this car is not in my shop, nor are any of those parts.
I do have another pump here, from another shop that was sent to me, that is apart and other than the rusty stuff, the wear looks pretty much exactly the same. The pump I have was off of a 31k mile 2009 car.
oilhammer
Old June 7th, 2010, 15:04   #7
dieseldorf
top post dawg
dieseldorf's Avatar
Did the car just die on the side of the road or was it a driveability issue?
Old June 7th, 2010, 16:55   #8
El Dobro
TDI(s): CR Free
Fuel Economy: 78 MPG Gas
What keeps the piston from turning in the bore? Is there a flat?
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
Now, I drive more, worry less.
El Dobro is offline   Reply With Quote
Old June 7th, 2010, 17:35   #9
Jim'stdi
Jim'stdi's Avatar
TDI(s): 2010 JSW
Where do the AA batteries go???
2010 TDI JSW |Reflex Silver|6M|Pano Roof|MDI |Goal Anthracite|Dieselgeek short shifter kit|Panzer plate|APR 28mm Rear Sway Bar
Jim'stdi is offline   Reply With Quote
Old June 7th, 2010, 23:51   #10
Rauss
Rauss's Avatar
Fuel Economy: Worst 38mpg \ Best 52mpg
That's pretty scary... time bomb!
.:Rauss
Rauss is offline   Reply With Quote
Old June 8th, 2010, 04:01   #11
740GLE
I'd agree that the rust doesn't look like rust, but I imagine oil hammer would know rust when he sees it. Very interesting.
Also was this pump pulled from a wrecked car or was there a failure in the fuel system?
His: 2010 Sedan, cog swapper, build date 07/09
Hers: 2012 Passat, Roof+Nav, build date 05/12
"Whole new generation Passat will work with you to create outstanding new classic, defining a new pattern!"
Old June 8th, 2010, 04:57   #12
oilhammer
oilhammer's Avatar
The above pics came from a 2009 car, it died shortly after refueling. Dealer found cloudy fuel in the car, and a low pressure DTC. They replaced the fuel and filter, sent it on its way, but warned the customer there may be a problem, even though the car at that point was running fine.
It came in the next day on a hook, with the fuel system full of metal. Again, the above pics are NOT mine.
oilhammer
Old June 8th, 2010, 06:11   #13
Pelican18TQA4
Subscribed!
"I interviewed the late Steve Yokich, then UAW president, almost ten years ago. When I suggested that Detriot might be putting too many eggs in one basket with its utter devotion to SUVs at the expense of passenger car development and asked if the union might take a position in favor of more economical cars, he started screaming at me." -Jamie Kitman, Automobile
Pelican18TQA4 is offline   Reply With Quote
Old June 8th, 2010, 07:17   #14
birkie
birkie's Avatar
Fascinating.
As I understand, the pump is supposed to have a Diamond-like carbon coating (DLC) somewhere on the piston as additional protection against our fuel here. I'm not sure if it is possible to tell with visual inspection - but do the sides of the piston look any different from the cam or roller as far as possible coatings/treatments? Is it possible that the cam and roller are not coated in this design? I'm no material scientist, so I don't know if that would even make sense.
'13 JSW TDI Tornado Red 6M
'98 Jetta TDI - In pieces
birkie is offline   Reply With Quote
Old June 8th, 2010, 08:17   #15
oilhammer
oilhammer's Avatar
The piston itself looks to have a gray finish, yes. And the one I have here has that finished galded completely off both ends of the piston.
But it is the piston's little roller that looks like it went from a roller bearing to a friction bearing....
oilhammer
Page generated in 0.13787 seconds with 9 queries
[Output: 124.68 Kb. compressed to 103.12 Kb. by saving 21.56 Kb. (17.29%)]
