Old June 7th, 2010, 09:51   #1
bruce846
bruce846's Avatar
TDI(s): No TDI's
Default Garmin EcoRoute HD and the TDI
Bottom line first, don't waste your money!
The information available is quite different than the you tube stuff that I saw in April. If you are interested in Mass A/F in Oz/S then maybe you will want this... not sure what that means, unless you are a MAF. Other than that battery voltage would be the only thing you get that would be of interest, all other possibilities, 5 in all are on the MFD screen on the dash.
He who laughs last, has the last laugh!
bruce846 is offline   Reply With Quote
Old June 7th, 2010, 13:05   #2
masterflex164
TDI(s): ...
I have EcoRoute on my 255WT. I tried using the 'best fuel economy,' and it does work to improve mpg, but it takes so much longer
masterflex164 is offline   Reply With Quote
Old June 7th, 2010, 13:19   #3
bruce846
bruce846's Avatar
TDI(s): No TDI's
Yup, that's the software, In this instance I am talking about the "HD" which is an OBDII interface (hardware) that gives you live engine data... entirely different animal.
Old June 7th, 2010, 13:24   #4
danham
TDI(s): 2010 JSW
When I first saw it I was so hoping for boost. But no such. I agree it is one of Garmin's "bells-n-whistles" moves which do not add to their otherwise excellent navigators.
-dan
2010 Jetta TDI SportWagen, black/black, stick, pano roof, Porto 17" wheels, iPod, protection & luggage Legos, nuvi 760 GPS, V1 radar, DRLs disabled, iPhone "GasBook" app as fuel finder.
Previous rides: '06 Audi A3 2.0T (traded for JSW); '98 Audi A4 1.8TQ chipped; '92 Corrado VR6; '90 Corrado G-60; '87 GTI 16v; '83 GTI; '77 Diesel Rabbit; '71 Porsche 914-4; '67 Volvo 122S; '66 Porsche 912.
danham is offline   Reply With Quote
Old June 7th, 2010, 14:03   #5
shoE30
TDI(s): 2010 JSW
bruce846, have you seen the HD in person? Did you buy one? Have they started shipping the units? Last time i checked they were only taking pre-orders(or something to that effect)
I know this is out of my league, but can it be hacked to show what we want to see?
2010 Candy White TDI JSW | Corn Silk | Pano Roof | DSG | Ipod | Mat Pkg
2014 Focus ST
1987 BMW 325iS
shoE30 is offline   Reply With Quote
Old June 7th, 2010, 14:12   #6
bruce846
bruce846's Avatar
TDI(s): No TDI's
Unfortunately, my comments are based on "hands on" experience, have it for 3 days, very disappointed and glad I got a deal or I would be very pi$$ed!
Not sure about hacking, (way out of my league) but it seems to work differently in my BMW X5 gasser, 9 possible options vs. 5 in the TDI.
Old June 9th, 2010, 14:46   #7
BlackSunshine
TDI(s): Tdi 1.9L ALH
Fuel Economy: 5L/100KM
I have the Ecoroute HD and the 1490T - have only had the Ecoruote HD for a couple of days, so am still playing with the options and such.
So far I am impressed with it - lots of data to chew on for the auto-geeks like me...
Is it better than dedicated gauges? No.
It is quick and convenient to move from vehicle-to-vehicle, and is very inexpensive in my opinion. I will reserve decision until I have used it a bit more...
'01 Golf TDi
'95 Cummins TD
www.nwfuel.ca
BlackSunshine is offline   Reply With Quote
Old June 10th, 2010, 07:39   #8
bruce846
bruce846's Avatar
TDI(s): No TDI's
After some investigation, I found that the info that each Mfg. spits out of the OBDII port is entirely up to them and not Garmin... VW is responsible for the limited gauge suport.
Anyone know if VAG-Com can alter these settings?
Old June 10th, 2010, 07:46   #9
BlackSunshine
'...limited gauge support...'
What data are you trying to view that you cannot access?
'01 Golf TDi
'95 Cummins TD
www.nwfuel.ca
Old June 10th, 2010, 07:51   #10
bruce846
bruce846's Avatar
TDI(s): No TDI's
Only 5 gauges are available on my "10 JSW, RPM, volts, Mass A/F, engine load, and Speed. In my estimation fairly useless!
Old June 10th, 2010, 08:08   #11
BlackSunshine
Maybe I didn't word the question correctly.
I'll try again -
What specific OBD-II engine feedback data do you wish to view on the EcoRoute HD that you cannot view?
'01 Golf TDi
'95 Cummins TD
www.nwfuel.ca
Old June 10th, 2010, 08:14   #12
JSWTDI09
JSWTDI09's Avatar
I'm (obviously) not the OP, but for me I would say Boost and EGT above all. Actually the choice of several EGTs (before and after DPF) would be nice. Also the pressure differential across the DPF would be nice. All of this can easily be viewed with VCDS. There is probably more, but this is what I thought of on the spur of the moment. Why can't it be made programmable so that ANY measuring block can be read and plotted?
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old June 10th, 2010, 08:33   #13
bruce846
bruce846's Avatar
TDI(s): No TDI's
Thanks Don, you are correct, however what I would like and what appears to be availalable with the HD are not the same... unless this info can be coded with VAG-COM to be read from the OBDII port.
BlackSunshine, what gauges are available in your TDI?
Old June 10th, 2010, 08:37   #14
BlackSunshine
I have no doubt that it is quite possible to monitor the data you desire, but let's be realistic about the capabilities of a $149 consumer product - I think it is a neat 'toy' but you are looking for data that the average consumer wouldn't necessarily use or understand. Garmin is not designing these products to satisfy the elite 1%, they are trying to build products to satisfy the other 99%.
It meets the expectations I have for what is for all intents and purposes a fun toy to play with.
'01 Golf TDi
'95 Cummins TD
www.nwfuel.ca
Old June 10th, 2010, 08:43   #15
BlackSunshine
From the menu it allows me to monitor:
Intake air temperature
Coolant temperature
Throttle position
Engine load
Intake manifold pressure
Charging Voltage
Mass airflow rate
Timing advance
RPM
Speed
I can agree that these are not the utmost important measurements to monitor, but it certainly provides some entertainment while commuting 100+ miles per day....
'01 Golf TDi
'95 Cummins TD
www.nwfuel.ca
Page generated in 0.16607 seconds with 9 queries
[Output: 124.22 Kb. compressed to 102.38 Kb. by saving 21.84 Kb. (17.58%)]
