Old June 5th, 2010, 17:16   #1
studhilo
Default Brake Light Flashing and 3 beeps at start
I have a golf TDi with 1700 miles. It has MT. Today the brake light started flashing. It stays flashing, while driving. The car also beeps three times at start up. This just started today. It is the warmest day of the year so far, about 107, not sure if this has anything to do with it.
What does this mean? Also, is it safe to drive over the weekend until I can get into the dealer?
Thanks for you help.
Russ in Arizona
studhilo is offline   Reply With Quote
Old June 5th, 2010, 17:26   #2
dweisel
dweisel's Avatar
Fuel Economy: 09 MB R320 Bluetec and too many ALH Beetles!
You will have to be a little more specific as there are several different brake warnings. First check your parking brake is fully released. If the parking brake lever is slighty applied. It will give you the "BRAKE" or(!) warning light and the chime will sound when you drive about 4 mph.
With a brake malfunction you should get the same as above and a warning message in the MFD
Look in your owners manual for a better discription.
Dweisel
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
dweisel is offline   Reply With Quote
Old June 5th, 2010, 20:34   #3
studhilo
More detail: The light with the word BRAKE flashes and there are 3 beeps. This happens a few seconds after starting to drive. The light continues to flash while driving.
Old June 5th, 2010, 20:46   #4
dweisel
dweisel's Avatar
Did you double check the parking brake lever?
Old June 5th, 2010, 23:48   #5
studhilo
Yes, I checked it. Seemed OK. Tried parking brake, seems to work. Regular brakes seem normal.
Old June 6th, 2010, 10:19   #6
DoctorDawg
DoctorDawg's Avatar
A sticky sensor switch on the e-brake persuading the ECU that the e-brake is on when it isn't?
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
DoctorDawg is offline   Reply With Quote
Old June 6th, 2010, 12:37   #7
Ol'Rattler
Ol'Rattler's Avatar
Brake fluid level low? There is a level sensor in the reservoir that turns on the same light as the e-brake.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old June 6th, 2010, 13:00   #8
JSWTDI09
JSWTDI09's Avatar
Another thing to check: Are your DRLs (Daytime Running Lights) on? Normally the DRLs turn themselves off when you pull up the parking brake lever. See if they go on and off when you pull up and down the lever - this might tell you if the parking brake switch is not working.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old June 7th, 2010, 00:07   #9
studhilo
Default Problem solved - bit of a surprise
Thanks for the advice to check the Brake fluid. I checked it today and there was a bit of a shocker - The cap of the plastic container that holds the brake fluid was off. Not just loose, but off. I admit, I never checked this when I bought the car about two months ago, assuming that a new VW came with such caps tightly in place. Once I replaced it, the light Brake light no longer flashed.
Old June 7th, 2010, 06:54   #10
Luv My 02 TDI
Fuel Economy: 52/48/44
Take the vehicle back to VW and have them flush your brake system. Brake fluid adsorbs moisture and will cause your brakes all sorts of issues.
2015 Jetta SE TDI | 2010 Jetta TDI sedan White Gold Metalic / Titanum Black W/ underseat drawers and Dash cubby | 2002 Jetta TDI//1999 NB TDI SOLD ***Before you post ANYTHING .. CLICK HERE !!!***
Luv My 02 TDI is offline   Reply With Quote
Old November 24th, 2013, 22:42   #11
usernamehere
TDI(s): 06 Jetta
Have Fun!
Don
Thanks, That must be it, I have one headlight on if I leave the lights on and turn it off. Plus I have the flashing brake light.
usernamehere is offline   Reply With Quote
Old September 5th, 2016, 15:10   #12
TJ01TDI
I know old thread, but I just had a similar issue.
ABS on solid, park brake light flashing and beeps, and no A/C.
Solution: connector on back of fuse pack on top of battery had come loose.
TJ01TDI is offline   Reply With Quote
Page generated in 0.17652 seconds with 9 queries
[Output: 103.18 Kb. compressed to 85.88 Kb. by saving 17.31 Kb. (16.77%)]
