hid3 said:
GoFaster, one of the reasons you don't have a cam failure might be the fact that you live in Canada: better quality diesel fuel, lower ambient temps there.
eddif, why do you still think someone would bother using mixed sets of followers during the replacement? Also, the chrome ones are not obtainable (by the dealership) anymore
I really have developed a theory about our area and cam failure. I have not shared it with anyone yet. I could spend hours trying to make it sound better but that would just be for my ego. Where I live there are probably only 50 days during the year when you can not apply almost the maximum HP the VW PD will make. After about 9:00 AM the roads are dry and you are in 2nd or above you can give the car all the pedal the electronics can supply. You can max out the RPM over and over with WOT. You probably have to back off 20 % of the time from tire spin. You cam gp just as fast as you can pay tickets for. Here you can do max pedal, RPM and WOT most of the time. That is when you are making 26.000 psi in the injection system. The cam is slammed into the bearings the temps are up in the cam due to cam bearing friction, and the 5W-30 oil is tried to its maximum.
By contrast the North is frozen a lot of the year and the roads will not allow maximum WOT high RPM runs 80% of the time. Stop screaming. You can do a lot of high RPM runs. but ice will not allow the WOT 26,000 psi runs till the roads thaw and dry for a precious 3 hour period during the day (?). Yes you are in a car with high RPMs but you are featherijng the throttle a large portion of the time (compared with the South). Although you are up to operating temperature you have much more opportunity to cool the engine. Do some folks run studs in the ice and hook up? Yes.
I stated the extremes of both areas. There are times in the South when just after a shower the road is so slick you can use only part throttle. There are times during thaw, in the North, when you can flog away. Total WOT is different from area to area and driver use of that WOT differs. WOT, tires hooked up, 26,000 psi injection for 25 seconds times are rare for some folks, but then where you are plays a part in this story, and the final mileage you are able to have.
Why would you use a mixed follower set? Well VW did it! If VW did it it must be right. Why would you question the stock use of mixed lifters. You know if VW did it it must be right LOL. VW had us all running around using their oil for a long time too. Another LOL.
Seriously the plain silver original PD follower seems the best for drag raing situations (with cam bearing work). The black followers seem the best for just the right no valve float person.
Who knows if the silver top follower you get today is the same ones you got in the original BEW? It may only be aftermarket and not be the same composition. I haven't tried to get any silver ones from VW.
Who knows if the black followers you get today are the same brittle composition you got when they first came out?
eddif
