Old May 29th, 2010, 08:24   #1
john2123
Default CV Axle
My Axle has been starting to clunk around turns sounding like it is going out, its not very often but every once in a while. The boot is starting to tear so I'm pretty sure i need to replace the whole axle. Is my assumption right and if so where is the best place to purchase an axle.
john2123 is offline   Reply With Quote
Old May 29th, 2010, 19:00   #2
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Year model, drivers side or not, trans type..Are all parameters required to make a suggestion to where to get which assembly.
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old May 29th, 2010, 19:05   #3
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
From his profile, it looks like he has a 2005.5 Jetta.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old May 29th, 2010, 22:07   #4
john2123
yup i have a 2005.5 jetta, its the passanger side, manual transmission.
Old May 30th, 2010, 08:41   #5
aja8888
aja8888's Avatar
http://www.raxles.com/default.aspx
Page generated in 0.11138 seconds with 9 queries
[Output: 64.28 Kb. compressed to 56.34 Kb. by saving 7.94 Kb. (12.35%)]
