Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Quebec
Quebec Quebec, Canada Section. This area is for people in Quebec who wish to discuss things more local to them.
Old July 8th, 2010, 13:36   #46
J-O
TDI(s): GOLF 99.5
Fuel Economy: 4.8 L/100Km
D'après mes calculs, sur 2 pleins où j'ai noté à combien de KM la lumière allume et la consommation L/100 jusqu'au remplissage...
Sur un mk4 la lumière à fuel allume à environ 57 Litres (réservoir venté évidemment).
Voilà les chiffres pour mes 3 derniers:
km
1261.56 Litres:52.3 L/100km:4.1
km
1230.02 Litres:49.2 L/100km:4.0
km
1384.68 Litres:60.3 L/100km:4.4
Et mon record:
km
1559.29 Litres:60.1 L/100km:3.9
Je suis disons... assez relax
Golf GL TDI 99.5, .205
J-O is offline   Reply With Quote
Old July 8th, 2010, 15:17   #47
dieseleux
Théoricien
dieseleux's Avatar
TDI(s): Jetta TDI 98
Fuel Economy: 4.42L/100km
Pour ne pas dire tres slow!
Bon chiffre!
Dieseleux
Jetta 98 AHU, 515,000km, Door Hinge Mod, GTB2056VL, 0.216um, 11mm/DE143 MK4 OEM Pump, Custom Chip for VNT on AHU ecu, HID Carelo headlight, Trunk Bed Mod.
Best tank:1311.5km (814.92miles) with 53.687L (14.1826us gal) for 4.086L/100km (57.56us mpg)
And Jetta GLS 2002 ALH stock...
GTB1756VK in my hand, ready to install on ALH!
dieseleux is online now   Reply With Quote
Old July 8th, 2010, 15:21   #48
XaV_T
XaV_T's Avatar
Send a message via MSN to XaV_T
Comme 2M...
Selon vag-com, je tire 3.6L/h à 105km/h!!!
Jetta MK3 coupe TDI PD150, GTB2056VL, FMIC, PD220 nozzles, MAF cancel, MRTuning chip, 02M DRW 6-speed ... soon GTB2260VK
Jetta 1985 TDI AHU, GTB1756VK, 11mm OEM pump, MK4 ECU, .205x6 nozzles (en construction)
Originally Posted by cog View Post
last time i saw a crack that big i had visited the wrong website
XaV_T is offline   Reply With Quote
Old July 8th, 2010, 15:23   #49
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 L/100Km
mais té loin d'être stock sur le fuelling donc, ça vaut pu rien dire
Jetta TDI 2001 GL (~505 000 km) : GT-1749VB, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Scangauge II, Euroswitch, Rear fog, Wolfsburg's Heated Seats, Bilstein TC, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GLI VR6), DieselGeek Skid Plate, FX35 HID Projectors Retrofit
Torque_Delight is online now   Reply With Quote
Old July 8th, 2010, 15:25   #50
XaV_T
XaV_T's Avatar
Oui, j'ai juste des nozzles unt tite affaire plus gros... c'est moins que la différence entre stock vs 205 su un ALH.
Old July 9th, 2010, 05:54   #51
J-O
TDI(s): GOLF 99.5
Bon chiffre!
Dieseleux
Pas très rapide mais jamais en retard... il n'y a pas beaucoup de différence de temps à rouler 10 km/h de moins... mais 10% plus écono... la différence entre 1200 km et 1320 km sur un réservoir...
Par contre pendant le 1559 km, j'ai peut-être été en retard 1 fois ou 2...
Old July 9th, 2010, 10:01   #52
XaV_T
XaV_T's Avatar
Tu tiens une moyenne semblable à la mienne, d'après ce que je vois.
Old July 9th, 2010, 10:11   #53
dieseleux
Théoricien
dieseleux's Avatar
1109km 4.8L/100km ma deniere tank... la clim a 100% et vitesse du peuple!
Dieseleux
Old July 10th, 2010, 04:28   #54
Alain B.
Tu verifiras a 5000, 10,000 et 15,000km... pour voir!
Parfait, je vais vous faire ça.
Originally Posted by Blades View Post
178km avec 1/8eme !
J'ai un gros smile dans face !
Par contre, je suis parti de la demi
Gros merci a Alain pour la demi tank de fuel !
De rien pour la demi-tank de diesel.
As-tu des photos du produit fini?
Golf Familiale TDI DSG 2010.
Alain B. is offline   Reply With Quote
Old July 10th, 2010, 05:00   #55
Blades
Bientot. Reste a le laver et ajouter les mags de Passat VR6 96.
'92 Cabriolet Full ABA, CE1 digi-2, MFA, 178000km
'92 Gold 1.6D, en cure de rajeunissement, 267000km
'01 Jetta GLS TDI, 323000km, SMF VR6 clutch kit, 0.216, MR Tuning custom triple program chip
Blades is online now   Reply With Quote
Old July 12th, 2010, 07:51   #56
modele59commeneuf
Default Road trip de 5,600 KM
Nous revenons dèun voyage de presque 3 semaines qui nous a fait parcourir 11 états Américains du nord au sud et retour en passant par la magnifique région des Blue Ridge en Virginie avec des montées jusqu'a 4000 pieds d'altitude. Nous avons aussi eu de la grosse chaleur jusqu'a 103 F (40 C) dans les Carolines et en Virginie donc la clim était au MAX. Malgré toout nous avons eu une moyenne global autour de 5.5 Lt/ 100 Km et nos meilleurs résultats sur la 95 avec 4.9Lt/100 Km et un autre excellent résultat de Virginia Beach jusqu'au New-Jersey de 5.0LT/ 100 KM
Encore plus important le comfort, aucun maux de dos.
JETTA TDI 2.0 DSG SportWagon 2009
modele59commeneuf is offline   Reply With Quote
Old July 13th, 2010, 20:53   #57
Blades
J'ai fait 505km de la demi jusqu'a 3/16eme environ (avant la coche blanche en haut du rouge). La, je fais environ 170km par 8eme de tank !
C'est pas le produit fini mais ce sont des tweaks
Moteur laver
Headlight polish !
Old July 13th, 2010, 21:27   #58
loudog
TDI(s): 2002 jetta
Send a message via MSN to loudog
Vient de me trouver un defis...
Gaspe-Montreal sur 1 tank. quekpart au mois d'aout...
et btw... Y'a une belle petite pancarte 'contien jusqu'a 5% de biodiesel' au olco au coin de chez nous... jusqu'a...
loudog is offline   Reply With Quote
Old July 14th, 2010, 07:09   #59
dieseleux
Théoricien
dieseleux's Avatar
http://maps.google.ca/maps?f=d&sourc...4,2.035217&z=9
911km... si tu reussi pas ca en une seule trajet de une tank... ta un trouble avec ton char!
Dieseleux
Old July 14th, 2010, 07:29   #60
loudog
TDI(s): 2002 jetta
Oui je sais ben mais avec la blonde + les bagages + les cotes + faire le tour de la penisule au complet... ca va tirer proche du 1000km ben ben loader...
J'ai deja taper plus que 1000km avant la lumiere, mais pas avec mes 'habitudes' de conduite 'normale' :P
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.09712 seconds with 9 queries
[Output: 125.37 Kb. compressed to 103.50 Kb. by saving 21.86 Kb. (17.44%)]
