Old May 25th, 2010, 18:34   #1
gioTDI
gioTDI's Avatar
Default Hard shift 3rd gear, any suggestion?
Well its a 2003 Jetta TDI, the problem is not always there some times it shifts fine, and some times it is hard to engage the 3rd gear. And I know its not the clutch, so my question is there any way to grease the part where the linker cables go in, i noticed there is a black cap and beneath the cap there is a small hole, so im not sure if i can put grease there
Please help me out with a solution , and here is the pics of what i am talking about.
Thank you
gioTDI is offline   Reply With Quote
Old May 25th, 2010, 19:15   #2
09R/T
I have the same problem....hopefully someone will chime in here.
2006 Jetta 5M, stock for now
09R/T is offline   Reply With Quote
Old May 25th, 2010, 19:27   #3
gioTDI
gioTDI's Avatar
Someone suggested changing transmission oil, i think i just might do that, and see what is going to happen after that
But i am still open to suggestions
Old May 25th, 2010, 20:35   #4
MotorCityMadman
sounds like a linkage problem
MotorCityMadman is offline   Reply With Quote
Old May 25th, 2010, 20:59   #5
motorinar
motorinar's Avatar
you need to realign the linkage, search on google how to do it. I had the same problem after I presure washed my engine. I also replaced the tranny fluid. Problem free ever since.
2004 Jetta TDI Wagon, 2009 JSW TDI
motorinar is offline   Reply With Quote
Old May 25th, 2010, 21:05   #6
motorinar
motorinar's Avatar
Default here you go
Borrowing form DieselGeek :
1. Lock the transmission into its "home" position. Right now, your black L-shaped locking lever is in the ”rest position” and should point to the left, just like in the picture. In the engine bay, make sure that the transmission is in neutral (in neutral the bronze front/back shift bracket is free to move up and down). With your right thumb, push down on the crescent-shaped part of the bronze lever approximately 1/3 of an inch and then with your forefinger turn the small black L-shaped locking lever on the transmission's shift tower clockwise while pushing it in. The tip of this black locking lever will end up pointing straight up when the shift mechanism is successfully placed in the locked or “home” position. You will also not be able to move the bronze front/back lever up and down if the transmission is locked into the “home” position.
2. Expose the shift linkage inside the car. On New Beetle, grab the rectangular "ring" at the base perimeter of the shift boot and pull it upward. It will unsnap from the center console. Then lift the rubber sound deadening boot from the shifter aperture.
3. Lock the mechanism inside the car into its “Home” position. Do this by inserting the expensive and rare special toolwe supplied with the kit into the hole at the lower left of the shift lever and push it through and into the corresponding hole in the shifter base until it bottoms out. This will give the appearance that the shifter is in second gear which is exactly correct. Also, the shift lever inside the car WILL NOT MOVE if you have successfully put the nail through both holes. If you don’t have the nail tool we provide with our kits, the special tool was made from a 4 inch long, 20d Bright Common nail with a 5 mm or .195” shank diameter and a 30 degree bend 2.5" from the tip of the nail to clear the shift knob.
4. Once you have locked the transmission into its “Home” position (Step 1) and also installed the adjustment nail through both holes inside the car (Step 3), Where you clamp the cable has everything to do with the proper adjustment of the shifter. Unlike the front to back cable end, SOME THREADS WILL BE SHOWING on the side to side cable end! If you are confident that you followed all of the steps before this one then you can finish the adjustment procedure by simply twisting the aluminum cable end to make it perpendicular to its mounting pin on the black bracket (its top slot will face straight up).
5. Unlock the transmission from its “Home” position. While pushing down slightly on the bronze front/back bracket, pull the transmission’s L-shaped locking pin to the left and rotate it counter-clockwise until it comes back out to its “rest position” stop. It will move toward the right side (engine side) of the car by approximately ˝ inch. (You are not removing the pin completely.) It is very important that you pull this pin back to the normal “rest position” since your shifter will not work with the pin pushed into the transmission’s “home” position! Furthermore, you will permanently damage the pin if you forcefully try to shift the mechanism with the pin pushed in! Please don’t forget to release the pin after adjustment. The mechanism will still function if you damage the plastic pin. The part number for the locking pin is 02J 301 358C and is available at your dealer for about $5.00. It is a pain to install, however.
6. Unlock the mechanism inside the car from its “Home” position. Go back inside the car and remove completely the special bent nail tool from the shifter mechanism. Save the adjustment nail with your stock shifter parts.
7. Check the shifter action by cycling through the gears. Make sure that first and second gear engage smoothly without too much effort. Also, make sure that reverse gear is easy to engage. (Make note that the shifter will always work its best with the engine running and the clutch pushed in.)
8. If all is smooth, reinstall the shift boot onto the shift boot frame ring inside the car. The New Beetle’s shift boot just pushes straight down into the aperture.
9. Reinstall the air box. Reattach the flexible duct to the mass airflow sensor with the screw clamp (1.8T) or spring-type hose clamp (all other engines). Plug the electrical connector for the mass airflow sensor back in until it clicks. Reattach the engine side vacuum line for the air box (TDI) or reinstall the flexible air injection feed hose for all other engines. A positive air hose connection results in a little “click”.
10. Start the engine and go for a ride
Old May 26th, 2010, 05:16   #7
gioTDI
gioTDI's Avatar
U know that is a good idea, i did wash my engine, however i did not notice the problem before that, so thank you for the suggestion
Another question, trans fluid does it have to be Genuine Fluid? My friend replaced his transfluid on 2001 Echo but he used Shell Synthetic Trans Fluid from Walmart, can i do that to ?
I knew that i've seen this somewhere but here we go
http://www.youtube.com/watch?v=tp9ggefOjAE
Old May 26th, 2010, 05:29   #8
gioTDI
gioTDI's Avatar
Well adjusting the linkage cable did the trick for me, did it this morning took for a spin no problems at all
Thank you everyone for the suggestion
Old May 26th, 2010, 07:19   #9
motorinar
motorinar's Avatar
I used the one from Chevy dealer, I belive it's called Syncro Mesh, I am not sure. That's what was sugested by people that had problems with their syncros.
Old May 26th, 2010, 11:25   #10
fase2000TDI
Fuel Economy: 52, 45 38
Redline MT90 75/90 or OEM from the dealership is 12.50 a quart. You'll need 2 quarts. If you have over 100K on your car, I highly recommend this.
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old May 26th, 2010, 12:08   #11
gioTDI
gioTDI's Avatar
Thank you ill take your advice and do that, yes my car has 131k right now
Old June 6th, 2010, 17:18   #12
gioTDI
gioTDI's Avatar
Any one has a DIY on how to change the transfluid in A4?
Old January 12th, 2013, 06:48   #13
BrianCT
TDI(s): TDI
http://youtu.be/gNUvPB1CiY0
BrianCT is offline   Reply With Quote
Page generated in 0.16252 seconds with 9 queries
[Output: 111.97 Kb. compressed to 93.34 Kb. by saving 18.62 Kb. (16.63%)]
