Old May 19th, 2010, 19:28   #1
AARodriguez Corp.
AARodriguez Corp.'s Avatar
Default Removing a stuck injector
I was pulling the injectors from an alh head a few days ago and one of the was just cemented in there. It didn't matter what I did that thing wouldn't even rotate 1/16 of an inch. I soaked it in blaster for a few hrs, nothing, wouldn't budge at all.
The fix was I took a mini torch, put it inbetween the the block and the injector for about a minute, within 2 minutes I had the injector out without even using a slide hammer.
Just another idea for people who have one that is hopelessly stuck.
AARodriguez Corp. is offline   Reply With Quote
Old May 19th, 2010, 20:49   #2
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Here you go:
http://forums.tdiclub.com/showpost.p...2&postcount=11
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old May 20th, 2010, 02:26   #3
AARodriguez Corp.
maybe I'm wrong, but I wouldn't think that would work until you have the darn thing loose, I've never had to use a slide hammer on an injector so I wouldn't know if that would have been the correct application. I can definetly see it being useful when the injector is spinning a bit.
Old May 20th, 2010, 05:58   #4
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Originally Posted by Newzboys
maybe I'm wrong
You are...
I had a couple that wouldn't turn at all... even after days of PB-Blaster showers... I borrowed a MetalNerd injector slide hammer from Wingnut (who also has built his own) and they came out very easily...
Yuri
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Old May 20th, 2010, 06:54   #5
AARodriguez Corp.
nice, i'll remember that
Old May 20th, 2010, 09:54   #6
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Slide hammer is a must!
runonbeer is offline   Reply With Quote
Old May 20th, 2010, 11:16   #7
Shastapk
These will work on on all injectors from 1996-2003, won't they? I need to remove mine on my '96 passat with the 1Z.
1998 Jetta 254k
1994 Dodge 4x4 Cummins-105k
Shastapk is offline   Reply With Quote
Old May 20th, 2010, 11:22   #8
tydaddy
tydaddy's Avatar
I wrapped the threads in a bunch of shop towels and simply used plyers over the protected threads to pull and rotate them out. Not a scratch on them - didn't need to buy or make a slide hammer!
PT, DPT, MS, ATC, CSCS, PES
2003 Jetta TDI Wagon - sold
2010 JSW - Malone Stage 2, DPF, EGR, ASV deletes. Nicktane. 2microntech. Etc. - sold
2005 TDI Wagon, Malone 1.5, 2010 Touareg V6 TDI
Hex-Can USB owner
tydaddy is offline   Reply With Quote
Old May 20th, 2010, 11:42   #9
runonbeer
Yes. 1Z, AHU & ALH. Probably lots of other Euro models as well (ASV???)
If you're only going to remove TDI injectors once in your life, then yes you probably don't need this tool. But when you can substitute 10-20-30 minutes of wiggling, prying, cursing and sweating for two or three satisfying smacks, it really helps.
Thus concludes my salesmanship of the tool. I'm not out to make a ton of money on these. I just think they're cool.
Old May 20th, 2010, 11:43   #10
Honeydew
^^^, some are stuck more than others.
Check out the puller in runonbeer's sig. If I didn't already have the metalnerd I'd buy that because it's a great reuse of parts and the price is good too.
Edit: runonbeer slipped another post in there, my arrows reference tydaddy's post.
Honeydew is offline   Reply With Quote
Old May 20th, 2010, 13:01   #11
Herm TDI
Herm TDI's Avatar
There has been more than one occasion that I was glad to have an injector puller on-hand. Most of the time they come out without any problems then you get the one that just is bound into place. Then there is no tool as good as a slide hammer.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old December 7th, 2010, 15:19   #12
myke_w
myke_w's Avatar
Sorry to resurrect this thread.
So I have an injector that is way stuck
It doesn't turn.
I have used the metalnerd tool and this injector just laughs at it.
I added about 10 lbs of weight, still laughing..
I've used heat in combination, no luck.
Short of pulling the head and beating it out from the reverse.. does anybody have any other ideas?
I'm stumped.
myke_w is offline   Reply With Quote
Old December 7th, 2010, 19:32   #13
jetta ,97
jetta ,97's Avatar
Just keep banging slide hammer till it comes out. Some of that are really pain in neck.
HEX+CAN
Old December 7th, 2010, 21:17   #14
dieseljunkie
It doesn't turn.
I'm stumped.
My #2 injector was like that. Did you try alternating hammering down and up with the slide hammer? Keep doing that in conjunction with penetrating oil. May take a while but mine eventually showed a little movement and finally came out.
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old December 7th, 2010, 22:03   #15
Dodoma
The simple solution is shake and bake. The injector will come out. You may use a puller otherwise.
Dodoma is offline   Reply With Quote
Page generated in 0.16576 seconds with 9 queries
[Output: 123.71 Kb. compressed to 102.12 Kb. by saving 21.58 Kb. (17.45%)]
