Old May 14th, 2010, 10:44   #1
TdiJettaSport
Fuel Economy: 1100 km tank
Default What size socket for oil filter?
I want to remove the oil filter cap on my 2004 1.9 L jetta tdi.
What socket size do I need, thanks.
TdiJettaSport is offline   Reply With Quote
Old May 14th, 2010, 10:49   #2
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
Should be 74mm though many would say 76mm.
http://www.zdmak.com/wbstore/main.as...CTMP=1&LowCt=0
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old May 14th, 2010, 10:51   #3
ninedee_golf_tdi
If you folks have Wal Mart up there, they might carry a plastic version for $8.00 usd. At least down here they do.
ninedee_golf_tdi is offline   Reply With Quote
Old May 14th, 2010, 12:07   #4
d2305
Don't put it on so tight.
d2305 is offline   Reply With Quote
Old May 14th, 2010, 12:12   #5
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Most use a 76 mm, 14 flute oil filter wrench... If you ever get down to the U.S., an AutoZone "B" cap wrench is about $5... If there's a Lordco store near you, it's p/n 70783... about C$8...
Yuri
PS: as far as putting it on too tight... I could swear that the squirrels sneak in there when I'm not looking and tighten it down...
ymz is offline   Reply With Quote
Old May 14th, 2010, 12:40   #6
cdods
TDI(s): 2004 Golf
I just use a cheap strap wrench, available at crappy tire amongst many other places. Even though I tighten by hand, I can never get it off without the strap wrench.
cdods is offline   Reply With Quote
Old May 14th, 2010, 12:44   #7
FlyTDI Guy
FlyTDI Guy's Avatar
I've had problems with the plastic ones (especially the loose fitting 76mm) getting half cocked on the flats when you put any force on them. They end up sticking in the socket and can be a bear to dislodge. I just do mine hand tight now when re-installing and make sure it's seated 100%. Even then, by oil change time, I may have to crack it w/the wrench. Getting the 'real deal' Assenmacher metal wrench solved all the plastic o-sized wrench problems. Specs are 74.5mm x 14 flats and it was only about $15. Money well spent in my book...
Old May 14th, 2010, 13:38   #8
anahata
anahata's Avatar
Fuel Economy: 60/44/37
Yuri
This one is steel and will likely never fail me. I actually use a torque wrench to be sure I don't over tighten it. (my hand can provide more than enough force!)
'01 Golf TDI GLS 5sp, 4d, reflex silver, Monsoon, CD, tape, 110,000 mi. Old Navy CCV, 2016 Bilstein TC's, VR6 springs, TT bushings, HD upper strut mounts, 10mm front lift spacers, Panzer plate, Ventectomy, coolant migration mod. MN mag oil plug, 5 brake light mod. B5 or less only, Delvac ESP - (the basics)
anahata is offline   Reply With Quote
Page generated in 0.16368 seconds with 9 queries
[Output: 79.90 Kb. compressed to 68.25 Kb. by saving 11.65 Kb. (14.59%)]
