Whitbread
Vendor , w/Business number
The planets finally aligned and was able to get back on the dyno to play around . This is the same car that backfired and blew the intake open a little while back.
Run with no nos
.020" jet
.030" jet
.040" jet
.050" jet
.060" jet. Don't knot what exactly happened here.... Maybe dyno shock? Either way, out of diesel.
All runs were made on the same conservative superflow dyno as before with runs going from 35mph to 115mph taking 15 seconds in 4th gear. Tried to hit the nitrous switch at ~3700rpm each time. Only one run was made for each all back to back. To further advocate how vital head porting a cam is on a tdi, notice how these dyno plots actually cross at 5252rpm while still making power .
On a side note, car is running the new ARP tdi specific head studs. Seem to be doing the job great. Coolant bottle was checked for pressurization after each run with none found.
Run with no nos
.020" jet
.030" jet
.040" jet
.050" jet
