Old May 13th, 2010, 17:29   #1
AlcoC420
AlcoC420's Avatar
TDI(s): .
Default CBEA or CJAA?
This may have been asked before, but is there any difference in the CBEA and CJAA engines? Which is in our 2010 JSW (U.S.)? Thank you.
2010 Jetta Sportwagen TDI 6M
AlcoC420 is offline   Reply With Quote
Old May 13th, 2010, 20:45   #2
S_Sanders
Fuel Economy: 41 AVG
I'm sure there is a difference, if not, why would they have bothered with different engine codes.
Anyway, my local dealer told me that my 2010 Golf coupe (built in Germany) has the CJAA engine, but they had to look it up on the computer system using the VIN#. He also gave me the build date, Trans Code, Sales Model and Color Codes. Perhaps someone in your dealer's service department can do the same for you.
2010 Golf TDI Coupe, 6 Spd Manual, Sunroof, Gray
2012 JSW, DSG, Black
S_Sanders is offline   Reply With Quote
Old May 13th, 2010, 21:25   #3
JSWTDI09
JSWTDI09's Avatar
I have the service manual and the two engines are treated together and no differences between them are shown or mentioned. I agree that there must be some differences, but they are obviously pretty minor. From what I can tell the biggest difference between them is probably in their ECU programming. The '09s can be "flashed" through the OBDII port whereas the 2010 ECUs have built-in encryption which makes in-the-car flashing impossible (at least so far). I have heard of no other differences. Different ECU programming could also mean some minor differences in engine control such as fueling and emissions system timing (who knows?).
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old May 14th, 2010, 03:58   #4
740GLE
Some differences listed in various threads
CJAA 6MT has higher gearing than the CBEA, DSG doens't seem to have any change.
Some CJAAs have a different fuel filter than the CBEA.
Many CJAA owners have reported needing 4.5L for an oil change (My self noted as well).
ECU 17 VS 16 if I'm correct
I'm sure there are more but these are the ones that first pop in my head
Old May 14th, 2010, 06:26   #5
Pelican18TQA4
I suspect an engine identifier change to coincide with other '10 VW engines. That's just a speculation though and I too am curious why the change.
740GLE, both the '09 and '10 U.S. TDIs have EDC17.
"I interviewed the late Steve Yokich, then UAW president, almost ten years ago. When I suggested that Detriot might be putting too many eggs in one basket with its utter devotion to SUVs at the expense of passenger car development and asked if the union might take a position in favor of more economical cars, he started screaming at me." -Jamie Kitman, Automobile
Pelican18TQA4 is offline   Reply With Quote
Old May 14th, 2010, 08:10   #6
gpshumway
TDI(s): 2000 Jetta
I thought I read somewhere that the exhaust emissions setup was slightly different, with the CJAA cars having a more easily replaced NOx catalyst or DPF.
It's a bit fuzzy, JSWTDI09 could you check your manual?
gpshumway is offline   Reply With Quote
Old May 14th, 2010, 08:15   #7
JSWTDI09
JSWTDI09's Avatar
It is not mentioned, but that does not mean it is untrue. Therefore, I don't know.
Old May 14th, 2010, 08:26   #8
gpshumway
TDI(s): 2000 Jetta
Found it! Post #3 from the following thread.
http://forums.tdiclub.com/showthread.php?t=272370
Originally Posted by jcrews
Here's a little extra information to reinforce:
CJAA 2010 parts (Auburn prices):
1K0254706LX filter/downpipe $865
1K0254401TX catalyst $1037 (looks like a NOx for the price)
1K0254401RX catalyst $865 (new part is $475 )
If you look at the 2009 CBEA the filter and NOx are fused whereas the new system has the two broken up, which is brilliant.
CBEA 2009 parts:
1K0254705G particulate filter/catalyst $2686
1K0254401N catalyst $475
Edit: Hmm, I wonder how the change to separate DPF & catalyst affects the DPF's coverage under the 8/80 emissions warranty.
From VW's official response this thread it looks like the 8/80 warranty covers "...Engine Control Module, On-Board Diagnostics II, and Catalytic Converter..." and only covers the DPF on a CBEA because it's integrated into the catalytic converter.
Boo VW if the change effectively shortens the DPF warranty. At least the parts are cheaper.
Old May 14th, 2010, 08:27   #9
dpg
i heard this too. they separated one of the cats from the DPF
dpg is offline   Reply With Quote
Old May 14th, 2010, 08:39   #10
740GLE
then is it just a new encryption on the 2010's that prevent the tuners from offering a chip? I thought the reason no 2010's have been chipped by main stream tuners was because of the new encryption of the ECU 17. I could be wrong, as many times I am.
Old May 14th, 2010, 13:07   #11
JSWTDI09
JSWTDI09's Avatar
The way I understand it, 2010s can be chipped - you just can't do it through the OBDII port. You must do it on a bench. Therefore with a 2010, you must send your ECU to the tuner, they modify it and send it back to you. F1 Tuning and this company will both tune 2010 TDIs, but you have to ship them your ECU.
http://www.stratmosphere.com/oct_vw.htm
Have Fun!
Don
Old May 14th, 2010, 17:17   #12
AlcoC420
AlcoC420's Avatar
TDI(s): .
So then the 2009s are often CBEAs and the 2010s are probably CJAAs? Ours is a March 2010 build.
Old May 14th, 2010, 18:18   #13
Plus 3 Golfer
Plus 3 Golfer's Avatar
Post #3 is not a definitive answer to the coverage of the DFP as the Federal Emissions Warranty covers emissions stuff for either 2 years / 24k miles and the ECM, Catalyst, and OBDII for 8 years / 80k miles.
I forgot to update my thread as I asked a followup question on the DFP coverage. This is the response from VW customer care in Jan. 2010 for my 2009. Maybe someone with a 2010 should send an inquiry to VW customer care in light of the fact that the DFP appears to be a seperate part from the catalyst on MY 2010.
Thank you for your reply e-mail. I understand you have additional questions in regard to the coverage of the Diesel Particulate Filter under the Federal Emissions Warranty. I am happy to follow up with your inquiry.
Based on the information available here in the CARE Center, the Diesel Particulate Filter is covered for manufacturing shortcomings under the Federal Emissions Warranty for a period of eight years or 80,000 miles, whichever occurs first, from your carís in-service date of September 30, 2008. I hope this information was helpful.
Thank you for being a member of the Volkswagen family. I may be of further assistance regarding this, or any other matter, please donít hesitate to contact me again by e-mail at www.vw.com or through our Customer CARE Center at (800) 822-8987. If I am not available, one of my colleagues will be able to assist you.
Plus 3 Golfer is offline   Reply With Quote
Old May 15th, 2010, 17:21   #14
AlcoC420
AlcoC420's Avatar
TDI(s): .
I think I figured out what engine I have. In the spare tire compartment there's a factory production sticker tag that's chock full of information. It reads that my Engine Code is CJA.
So, I'm thinking that our 2010 has a CJAA.
Old May 15th, 2010, 19:09   #15
Pelican18TQA4
2009 = Cbea
2010 = Cjaa
Page generated in 0.17613 seconds with 9 queries
[Output: 126.50 Kb. compressed to 104.73 Kb. by saving 21.77 Kb. (17.21%)]
