Old May 11th, 2010, 22:43   #1
alphaseinor
Default maxed out at 621358 miles, 1 gigameter limit?
Okay, here it is... quite possibly the highest mileage 2003 I've ever seen... and the odo is stuck here, trip still works... tracking mileage with the 2000 mile marks on the trip odo.
sorry for the large photo... hopefully it will show up correctly...
if not...
http://www.facebook.com/#!/photo.php?pid=4464978&id=520711361
Any ideas on making it move again? already tried vagtacho and vagcom methods...
oh and a gigameter is the getting close to the diameter of the sun... and a million kilometers or... 10^9
alphaseinor is offline   Reply With Quote
Old May 11th, 2010, 22:49   #2
biopete
Wow. That is pretty awesome. You should still have about 12 -13 miles left before the 1,000,000 km mark. How many miles of those are yours?
1998 Beetle tdi
biopete is offline   Reply With Quote
Old May 11th, 2010, 22:51   #3
alphaseinor
it's actually closer to 650,000 miles ( a little over...) the trip odo is mine since sunday.
Old May 11th, 2010, 22:53   #4
fase2000TDI
Fuel Economy: 52, 45 38
The coolest thing about that is over 600,000 miles it likely used less than 13,800 gallons of fuel. $40,000 of diesel at today price.
:P
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old May 11th, 2010, 22:54   #5
biopete
you should tell vw and maybe they'll put in in their museum one day. At least they may want to give you a better odometer that can count higher like this guys's 240D that got 4.6 million KM.
http://www.expatica.com/de/news/loca...ck--12033.html
1998 Beetle tdi
Old May 11th, 2010, 23:05   #6
biopete
I was just thinking a 1,000,000 KM = 621,371.192 miles so your odo should have gone a bit higher before it stopped at 999,999 km.
1998 Beetle tdi
Old May 11th, 2010, 23:11   #7
alphaseinor
I'll have to do a scan again and look at the actual value stored...
at least the trip odo works.
now does this constitute beyond mechanical limits?
Old May 11th, 2010, 23:30   #8
RomanL
TDI(s): '10 GOLF TDI
3 engine rebuilds plus original *(thats if it was still original when he got it at 500K) but even it was 4 engines thats still way impressive 1.15Million KM / engine
'10 VW GOLF TDI 6MT
'07 VW Rabbit 5MT (g/f's)
'03 Chevy Impala (sold)
RomanL is offline   Reply With Quote
Old May 12th, 2010, 00:03   #9
flatlanded
TDI(s): 2002 Jetta
Fuel Economy: 55ish US MPG
It's gotta be a VW thing, my 95 went from 299,999kms back to zero...
'02 Jetta TDI - 400,000 kms: Frostheater, boost/egt/oil-temp gauges, evolution skidplate, 5 brake light mod, 17/22, PP520, Malone Stage 5, 2.5" side-pipe, SBC Stage 2 Endurance
**Have VCDS**
flatlanded is offline   Reply With Quote
Old May 12th, 2010, 04:33   #10
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
That was an A3 thing, not a VW thi....ummm....idiosyncracy, that's a better word.
A VW Thing would be the Kubelwagen
The B4 of the same era don't revert back to zero after 300,000 units (miles in the USelessA, Km in Canukistan apparently) the way the A3 do.
Still, the coincidence of 621,000 miles being so close to a million Km is enough to make the association plausible.
Svante Arrhenius 1896
Old May 12th, 2010, 06:12   #11
belome
Fuel Economy: 47'ish
Originally Posted by Lug_Nut
USelessA
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old May 12th, 2010, 09:54   #12
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
I happen to own a 240D, and I can assure you the tachometer does not go to 4.6 million kilometers. As a matter of fact, the odometer/speedometer has broken two times. It fails far more often than the engine, which is still running strong. We have lost track of mileage though. It is somewhere between 400K-500K miles, I presume.
manual_tranny is offline   Reply With Quote
Old May 12th, 2010, 12:04   #13
740GLE
what about the P1800? now thats a great ride worth putting that many miles on
Old May 12th, 2010, 13:10   #14
manual_tranny
mmm... that would be nice
Old August 26th, 2010, 10:58   #15
alphaseinor
If I recode to read KM (canada) in the instrument cluster it reads all 9's (999,999)
Page generated in 0.18873 seconds with 9 queries
[Output: 127.17 Kb. compressed to 105.61 Kb. by saving 21.56 Kb. (16.95%)]
