Old May 8th, 2010, 18:09   #1
eddie_1
eddie_1's Avatar
Default My >$200 ebay FMIC kit installed
Don't know how but I managed to get it in. ebay fmic kit, stock bumper and grill fogs. Of course there is bumper trimming involved. I did go with a slightly shorter FMIC. It is ~6" vs the 7". Thanks to TDIJetta99 and Got Bearings for some key tips. Well I went for a run and it didn't come off so far.
2008 A6 BPP 283kmh - 100-200 kmh 14 secs - 2003 Jetta Wagon ALH 150mph, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old May 9th, 2010, 07:19   #2
eddie_1
eddie_1's Avatar
As you can see I didn't have to cut the crash bumper if you find this cooler 27x6x2.5 with 2.5 inlet/outlet ebay:cxracing. (tdijetta99 mentioned height caused cutting and other cooler is ~7" tall). The key is to make tight turns into and out of cooler after positioning cooler inlet/outlet in lower orientation (inlet outlet is slightly off center). Input side is straight in with trimmed on one side 90 deg pipe. After using a U on outlet, you can use the 45 deg pipe with a short piece to get across a bit more and then go up at 45. I used a 45 coupler at the top (got bearings? idea)and then it is pretty much a straight shot into th 90 deg pipe. So far it seems to be running good, didn't come off and no rattles.
Old May 9th, 2010, 08:17   #3
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
So... you have done the "roto-rooter" plumbing hardware mod, too? How is that working? Does it keep the tree roots out of your crankcase? =)
manual_tranny is offline   Reply With Quote
Old May 9th, 2010, 09:07   #4
midntdi
Fuel Economy: 40-50 mpg
Do you have a skidplate?
Torden: http://forums.tdiclub.com/showthread.php?t=418613
Lyn:2015 Night Blue Golf TDI
midntdi is offline   Reply With Quote
Old May 9th, 2010, 10:31   #5
eddie_1
eddie_1's Avatar
Hey Manual Tranny thanks for asking. Yeah I got rid of the EGR path and CCV oil path that combine to clog the intake. The CCV filter is not elegant but does the job. I followed your timing belt issue and other great posts you've made. Hopefully we could meet up at some point. thanks! ~ed
Old May 9th, 2010, 10:34   #6
eddie_1
eddie_1's Avatar
The wagon's have a nice oil plan protection steel tub. So I've never seen the need plus I still like the plastic to keep out salt/snow/rain etc.
Old May 10th, 2010, 10:15   #7
manual_tranny
Ahh.. I must confess I didn't even know what it was! I'm impressed that you made it work! Cool!!
LOL! If I have any really good posts around here it's usually just repeating information I read on this site...
Next time I'm in NY or maybe I'll see ya at a GTG. I'm hoping I can get to the Ohio one!
Old May 11th, 2010, 08:42   #8
LiLredTDI
LiLredTDI's Avatar
Fuel Economy: ohh...I'd say bout 42mpg
Looks like you did a great job. How long did it take? I am being a bit of a sissy pulling the trigger on doing this mod. I was thinking along the same lines as you on going with the smaller coresize and taking it one step furthur by going with 2" piping. I have been reading FMIC threads on here by the dozen it is seems with the bigger cores/piping there are always some kind of issue wether it be grossly cutting the crashbar, bumper cover or having the suspension mash a pipe or assist in popping off a hose cause it is too big. The latter seemed to be a big issue long ago with the EUROJET kits. If I finaly decide to do this my thought was to install and label all parts and then remove and have a bead welded to the hose connection areas or find someplace to put a bead roll on and have the MAP sensor welded on. Hope you can answer some of my questions I have below it would be greatly appreciated.
Did you have to take off the crash bar to drill the holes to mount the core, or could you reach behind and install the bolts/washers?
Where did you get the MAP sensor and how did you mount it?
How were the quality of the silicone bits and t-bolts on that kit?
Did you have to cut the bumper cover or L/R bumper vent holes to get the 90's to fit?
Does any of the piping need some kind of a bracket added to eliminate wear/vibration issues?
2004 Jetta PD-RC race, 17/22,stg.IIcoltcam PD150 Inj.,Rosten Rods, Ported head,PP DP, cat delete/2 1/2" piping/Magnaflo muffler, R32 airbox/snorkle,PD150 TIP, SB stg 3 ,NSboost/egt gauges, BBS RS II's, Koni FSD/Eibach Kit, M3 side skirts/ rearwindow spoiler,GLI F/R lips FK bumper scoops
LiLredTDI is offline   Reply With Quote
Old May 11th, 2010, 14:03   #9
LiLredTDI
LiLredTDI's Avatar
up for
Old May 11th, 2010, 19:34   #10
eddie_1
eddie_1's Avatar
It' not that difficult really. I'm sure you can do it.
> I was thinking
I think what my attempt shows is that there is a path to go without having to cut the crash bar, still use 2.5" piping with this slightly shorter version of IC. I did use the custom lower IC pipes from idparts so that eliminated the suspension issue. That was a tip from Got Bearings? I guess in your case you can go the extra step and do beads. First time you could spend just cutting all the pipes to size. Then get the bead done and reinstall the next time.
>The
I just drilled into the crash bar. I drilled 2 holes side by side to make an oval shape opening for each of the 3 bolt on points on the top, so I could tilt the IC back a bit and snug it up at a slight angle. You can remove this center piece on the crash bar and get your hand in from above to place bolts through. You will need a good drill and high quality bits. They dont call it crash bar for nothing. I did not support from below but it is in there pretty much unmovable and the pipes and bumper are all holding it pretty good. I will check back in a few weeks though to see if bolts etc. are ok. I used some blue thread locker on bolts.
There is a guy on ebay selling a map sensor flange kit searchable as:
INTERCOOLER MAP SENSOR FLANGE KIT VW......
I tapped the screw holes with M6 tap and mounted. pitch is 36mm exactly. double check though. drill very precisely the locations.
The kit is not bad really. The pipes and bolts etc seem decent enough. However the IC that I bought separately from the CXracing ebay vendor seemed better built than the one in the kit. I don't know how the thing will hold up over time but I think several folks have 'em now without too many problems except for the odd location blowing off. Either the clamp was not tightened enough or they got a better clamp for that location.
> the 90's to fit?
I did a bit of trimming. I think you cannot get away with zero trimming whatever you do. But it was pretty minimal. It was mainly as you say at the inlet/outlet of the IC. Plus I have the grill fogs. But to answer your question - very slight bumper cover trimming where inlet/outlet of IC and some trimming of plastic vent holes at the fogs and along the bottom edge of IC.
So far I cannot see any issues with vibration of pipes. I will have to check back. Overall everywhere it is touching something it is on plastic or rubber and everything is tightly coupled. Nothing is moving around. If you follow similar routing you should be ok. One thing you might want to do is support the IC from bottom with one of the brackets provided. I ended up cutting off the IC mounting holes at the bottom to get more clearance at the bottom. But I may attach something there if i find the IC getting loose. But I doubt it.
The IATs do drop dramatically. Just driving around town I am seeing 90s F drop to 50s F.
Let me know if you have any more questions.
Old May 11th, 2010, 19:40   #11
eddie_1
eddie_1's Avatar
One more area of trimming I forgot to mention was the radiator support. It is a plastic housing and there is a ridge along its edge. I trimmed along the bottom and where the IC inlet/outlet line up. This allows the IC to go further back.
Old May 12th, 2010, 06:55   #12
LiLredTDI
LiLredTDI's Avatar
Eddie- Your awsome! Thanks for answering most of my questions. So you bought an entire fleabay IC kit, and additional smaller IC and pipes form ID parts? I have a PD so my install will,be a bit different I am hoping easier as I do not have the injector pump to contend with.
So start to finish how did this take you? I am wondering if any of the ID parts pipes will work on my car (ones on passenger side to turbo) The only stock E-Clip I plan to use will be on the antishudder valve. I "was" going to install a passenger performance intake but think I am now going to go with a SDI type with the AS or the PD 150 with the AS this way I do not have to eliminiate any wiring that will cause check engine lights or add resistors to fool them. I am considering taking my stock upper PD pipe that goes onto the AS and cutting off the end so I can insert one of the fleabay pipes inside and use a t-bolt clamp.
Old May 12th, 2010, 10:37   #13
eddie_1
eddie_1's Avatar
Unhappy
> contend with.
Yes I bought the ebay $200 kit everyone is getting plus an additional cooler which is not as tall as mentioned - 6". Earlier I got the idparts "Upgraded Lower Intercooler Pipe" - which replaces the pancake pipe at turbo outlet. You are right it is for ALH. Maybe your pipe is better than pancake already, I'm not familiar with PD lower IC pipe. You are right you dont have additional pulley of IP so it will give you a bit of area.
It took me the whole day. But then I work really slow to avoid mistakes. Time is a bit subjective. In fact it would have been a bit quicker but I lost a couple of hours trying to get the PD150 EGR hose on to 2.5" pipe it was not intended for!
Old May 13th, 2010, 13:35   #14
mrflashy
lmao eddie, i know exactly what you mean about stretching the OEM rubber hose onto a pipe, in the end we hot a heat gun to it and got it over a lip and whacked a strong hose clamp on it.
Mine survives 32psi of boost
Nice install, i will post some pictures up of my Ebay FMIC when i get chance, and some temp logs if people want any.
mrflashy is offline   Reply With Quote
Old May 13th, 2010, 13:52   #15
LiLredTDI
LiLredTDI's Avatar
How would the fit be if you used 2" pipe? I have found some kits that have 2" tubing which I "think" would be more than enough for our cars. I do not even know why some people run 3" seems over kill and may cause lag on a 17 series compressor.
My $200 ebay FMIC... TDIJetta99 TDI Power Enhancements 293 December 20th, 2013 15:17
Found the 200 Ebay FMIC for 155 shipped. VWBeamer TDI Power Enhancements 23 March 7th, 2011 17:56
My <$200 ebay fmic kit.. eurojulien TDI Power Enhancements 14 April 27th, 2010 12:47
FMIC Installed - now what? diesel4ever TDI 101 4 January 22nd, 2009 06:32
© 1996 - 2020, All Rights Reserved
Page generated in 0.19018 seconds with 10 queries
[Output: 150.07 Kb. compressed to 127.92 Kb. by saving 22.15 Kb. (14.76%)]
