Old May 8th, 2010, 14:39   #1
FranOhBaby
Fuel Economy: 43-50
Default Does my 2004 Jetta have an engine block heater?
Yes, I've owned this car for three years and have had cold weather starting issues. But I finally want to know since the car just sold to someone living in a far colder area. Does my 2004 Jetta have an engine block heater? What do I look for and where? Thanks!
FranOhBaby is offline   Reply With Quote
Old May 8th, 2010, 14:47   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Not from the factory it doesn't.
Someone may have installed an aftermarket inline heater. If you look below the battery just above the starter (provided there's one installed) you will see a cylindrcal unit wit a hose comoing from the oil cooler/filter and a 120V cord attached to it as well.
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old May 8th, 2010, 14:49   #3
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Nope.
They are about $100 aftermarket, TDI Heater being the most popular.
Hopefully the new owner can and will correct whatever issues are causing the cold start issue. I've started mine at the relatively warm -15*F with no heater. Others start theirs in much colder weather w/o issue.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old May 8th, 2010, 14:50   #4
T_D_I_POWER
T_D_I_POWER's Avatar
No your TDI doesn't have an engine block heater. You need to install a coolant heater which will help cold weather starting issues which is typical of any Diesel engines. You can either use the round or rectangular tanks zerostart coolant heater. The round is a better choice since it gives you more room
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old May 8th, 2010, 14:59   #5
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Cold weather starting issues typical of TDIs?
Old May 8th, 2010, 15:01   #6
Dodoma
To reduce cold start problems, have the car parked in a heated garage. The other option is to get rid of the diesel because cold whether and diesel are not friends.
Dodoma is offline   Reply With Quote
Old May 8th, 2010, 16:05   #7
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Sorry, but something is wrong with your motor if you have trouble starting it in the cold. The 99.5 will start all the way down to 0*F without a problem. Colder than than that, it will struggle a little, but still always start.
Since the OP has a PD, I wonder if he had the glow plug recall done? If so, that is why it has cold weather starting problems.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old May 9th, 2010, 08:53   #8
FranOhBaby
Fuel Economy: 43-50
didn't see a plug coming out of that area. the car has always been in arkansas; can't see the first owner installing a heater. the vw delearship did some recall work during an oil change about this time last year. will call them tomorrow to see if it was glow plugs. thanks!
Old May 9th, 2010, 15:17   #9
turbocharged798
The reason I mentioned it is because VW completely messed up the glow plug recall. These cars originally came with ceramic glow plugs that would break off in the cylinder and cause major issues. They recalled them and replaced them with steel glow plugs which requires a ECU re flash. VW messed up the tune and cars would have a hard time starting in the cold. There is a whole thread on it. If you do a search, you will probably find it.
Old May 10th, 2010, 07:47   #10
flyingmikey
flyingmikey's Avatar
Fuel Economy: ~900 kms
Look under the oil pan, if you see a plate glued to it with wires coming out of it, you have a heater . Follow the wires to the plud, and ta-da !!!
As for cold-weather ... you need additive in the winter, i use clean-flo, otherwise the diesel gels up. Also, my beetle wont start if its below -15C !! so you NEED a heater.
flyingmikey is offline   Reply With Quote
Old May 10th, 2010, 07:57   #11
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
That's an oil pan heater, not a block heater. Both are ideal (we needed both in Alaska, along with a battery heater).
That being said, I've found my block heater will also heat the transmission and oil via conduction.
There is something wrong causing your NB to not start below -15C. People often start their TDIs at -30C without external aides.
Page generated in 0.12750 seconds with 9 queries
[Output: 102.78 Kb. compressed to 86.63 Kb. by saving 16.15 Kb. (15.71%)]
