Old May 7th, 2010, 18:10   #1
joetdi
Default New Recall for front sunroof drains
There is a new recall out for modifying the front sunroof drains. 2001 to 2007 cars Bug, Jetta, Golf, J/wagon and R32. Code 60A7/8. Be watching the mail for it. FYI only.
If you want to do it yourself just clip the drain ends and you're done. However the drain gets cleaned as well. Joe
joetdi is offline   Reply With Quote
Old May 7th, 2010, 18:43   #2
abranz
On my Beetle I cannot reach the sunroof drain ends. Any tips?
Tony
2000 Beetle, 5 speed
abranz is offline   Reply With Quote
Old May 7th, 2010, 18:59   #3
joetdi
You have to put the A pillar trims off.
Old May 7th, 2010, 19:32   #4
davebugs
Yea! I was able to open one a year or so ago with string trimmer line.
The other is still clogged and if I don't watch how I park I get wet.
Any mileage limitation? I'm at 190k in my 2001.
davebugs is offline   Reply With Quote
Old May 8th, 2010, 09:40   #5
abranz
Don't want to sound dense but are you referring to the outside or inside A piller covers? How do I remove without breaking something? Thanks Tony
Old May 9th, 2010, 08:09   #6
Aquaticmind
Aquaticmind's Avatar
Location: Wheeling, WV via Athens Georgia via, Bainbridge Is. Wa, via Carbondale IL, via Asheville NC
Fuel Economy: good
Since Im not the original owner, how would I get in on this recall?
2003 Wagen, 2" lift, auto front springs, panzer plate, pp520 injectors, RCII+, ASR
Aquaticmind is offline   Reply With Quote
Old May 9th, 2010, 17:03   #7
joetdi
Inside, carefully pull them off.
Old May 9th, 2010, 17:04   #8
joetdi
Have dealer input your VIN and see if your car applies.
Old May 10th, 2010, 13:21   #9
JC_1992
JC_1992's Avatar
Just recieved mine in the mail today.
2002 Jetta TDI GLS 190,000miles, 5-Speed
Mods/Upgrades: Snow Screen Delete, FrostHeater, 1.8t Pancake Pipe, RC Stage 3, Titan 520 nozzles, 17" Goal Wheels, Koni STR.T's, TT LCA's, SBC Stage 2 Endurance
In the process: Upgraded Upper IC Pipping, OMI, Exhaust
JC_1992 is offline   Reply With Quote
Old May 10th, 2010, 13:23   #10
VWBeamer
Fuel Economy: 42.79 mpg Woot!
Received my recall notice today, but I have already clipped the drain ends, so I don't think I'll waste my time.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old May 10th, 2010, 13:27   #11
RomanL
TDI(s): '10 GOLF TDI
does this include RABBIT as well?
'10 VW GOLF TDI 6MT
'07 VW Rabbit 5MT (g/f's)
'03 Chevy Impala (sold)
RomanL is offline   Reply With Quote
Old May 10th, 2010, 13:58   #12
Spike Strip
Spike Strip's Avatar
Received mine today ...
Inspect, clean (if necessary), and modify drains.
Anyone know what the modification will be ?
2005 Golf TDI GLS Auto (BEW)
Spike Strip is offline   Reply With Quote
Old May 10th, 2010, 15:04   #13
abranz
Thanks for the help. I'll get to it this week. Tony
Old May 10th, 2010, 15:19   #14
daedalus
daedalus's Avatar
Angry $30M+ for the lawyers - a new schedule for us
I am opting out. At most I would get reimbursed for work done because I didn't maintain my car. At least I get an additional page for the Owner's Manual. The lawyers need to get by somehow on a paltry $30,000,000 plus another $1,500,000 for their expenses.
If somebody could persuade VWOA to stand behind their customers for the Balance Shaft issue, the Glow Plug and fouled up ECU programming issue, and the decreased timing belt interval issue I would consider that of value.
This insanity has to stop!
2005 Passat TDI Wagon
RocketChip Stage 1 -- 5 Micron fuel filter - EVO Thor skidplate -- Huper-Optik 50 tint - FrostHeater Coolant Heater -- Ventectomy - Chain-free at 100K miles -- Bosch 5V steel GPs -- Torque Converter done at 127K miles
SOLD at 140,800 miles - Torque Converter again! Now pushing a B6 gasser wagon
daedalus is offline   Reply With Quote
Old May 10th, 2010, 15:27   #15
JC_1992
JC_1992's Avatar
I agree with you.
This does seem pretty rediculous, with all of the other problems out there that should be addressed and they chose to take on the faulty sunroof drains plus how much the lawyers want.
It's kind of pathetic
Page generated in 0.17079 seconds with 9 queries
[Output: 121.22 Kb. compressed to 100.04 Kb. by saving 21.18 Kb. (17.47%)]
