Old April 27th, 2010, 17:52   #1
TDIEB
Fuel Economy: 53 / 46
Default Ball joint/control arm replacement
I have decide to change the lower control arms and ball joints . My 03 Golf has 251,000 miles and when I go in reverse and hit the brake a hear a small clunk in the front right.
How hard is it to remove the ball joint form it's socket?
thanks
TDIEB is offline   Reply With Quote
Old April 27th, 2010, 17:55   #2
roadhard1960
Fuel Economy: 48 mpg
Have you inspected the control arm bushings? I was getting some weird noises that went away with ne control arm bushings.
Removing ball joint is easy, I think but I live in the south where my car does not see salt.
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 505,000 miles and counting, original turbo. 2004 Dodge 2500 Cummins HO.
roadhard1960 is offline   Reply With Quote
Old April 27th, 2010, 18:40   #3
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
There is a nice how too on the ball joint. Leave the axle in and use the nut that holds it tight to force the ball joint out of the tapered spot. Don't forget the new bolts as they are stretch torque to yield (tty) bolts. I don't think you have to do the whole control arm. The ball joint and rear mount (converting to an audi TT rear bushing=solid rubber) is all that would be needed and it isn't that expensive either. Haven't done either but I have read up on them as I am planning on doing them latter this summer with shocks.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Page generated in 0.12311 seconds with 9 queries
[Output: 54.65 Kb. compressed to 49.35 Kb. by saving 5.30 Kb. (9.70%)]
