Old April 24th, 2010, 19:19   #1
Shawn_alh
TDI(s): ALH
Default 3 bar map sensor ~ confused
Hello,
So everything in my car is stock except diesel powerbox. 1.9 alh 00 TDI car running at 13psi stock
I changes the map Sensor today part number #038 906 051c, I had the big hole map sensor so i made a sleeve that is tapered and fits very snug.
this is where the confusion starts
I went for a drive got no boost? i stopped fueled up and took off, now i got high boost spikes at 21-22psi and holds at 18psi
got home and had to go out to pick someone up got no boost again?
shut the car off, started back up boost was back? and ideas guys
Thanks in advance,
Shawn
Shawn_alh is offline   Reply With Quote
Old April 24th, 2010, 19:23   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
3 bar MAPs are for cars with bigger turbos and boost over 21 PSI.
If you want more boost, you need either a "boost fooler" or a chip/tune/remap.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old April 24th, 2010, 19:26   #3
eddie_1
eddie_1's Avatar
I put one in today and lost boost too, although I am running rc3. See my post from a few mins ago.
http://forums.tdiclub.com/showthread.php?t=280386
2008 A6 BPP 283kmh - 100-200 kmh 14 secs - 2003 Jetta Wagon ALH 150mph, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old April 24th, 2010, 19:27   #4
Shawn_alh
TDI(s): ALH
thanks but that does not answer my question
it works i am getting more boost.
only when i start the car shut it off then turn it on again <-- thats the problem
Old April 24th, 2010, 19:28   #5
Shawn_alh
TDI(s): ALH
does yours work again when you shut the car off then turn it back on?
Old April 24th, 2010, 19:31   #6
eddie_1
eddie_1's Avatar
no. I get the CEL and error code constantly.
Old April 24th, 2010, 19:53   #7
Shawn_alh
TDI(s): ALH
being i have the glow plug engine code all the time i decided after you said that i should check
here is what i got
Old April 24th, 2010, 19:59   #8
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
One question... how did you come to choose a 3 Bar MAP as compliment to your box? Your car is going into limp mode. Throwing a 3 bar map on a stock ECU is going to make it not happy. You are misreporting boost to the ECU now and it knows something's wrong. Turning the key off/on resets the ECU and it gives your not-so-happy mod combo another chance at redemption.
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old April 24th, 2010, 20:05   #9
Shawn_alh
TDI(s): ALH
my map sensor was broken and i decided i would install this because i plan to add a vnt17 later this year
I have not lost boost while driving (limp mode?)
anyway can i fix this without going to a different map sensor?
Old April 24th, 2010, 20:11   #10
eddie_1
eddie_1's Avatar
My take is that the voltage range from the map sensor between 2.5bar and 3bar is different and the 3bar is lower starting voltage. This is confusing the ECU. In some cases people are getting overboost other cases the ECU is choosing limp mode.
Old April 24th, 2010, 20:20   #11
FlyTDI Guy
FlyTDI Guy's Avatar
The voltage range is the same but... they represent different ranges. In other words, with the OEM 1.5 bar might return 3v to the ECU. With the 3 bar map, the same 1.5 bar only returns 2.5v. At idle, your ECU knows ambient, say 1000 mbar. Your map sensor, however, is returning lower than expected and they don't match. Some people can run a 3 bar map and not have any bad symptoms, most need to update the maps in their ECU to truly make it work right. Short answer, if you're going to run a 3 bar map, you need to tune for it. That means re-mapping the ECU.
Old April 24th, 2010, 20:24   #12
Shawn_alh
TDI(s): ALH
thank you for the answer
am i going to wreck/hurt anything from now till i do the turbo 3-4 months
Old April 24th, 2010, 20:34   #13
eddie_1
eddie_1's Avatar
Your 3bar is bringing the boost up to levels that are around the upper limit of the stock turbo, so you should be ok.
Old April 24th, 2010, 20:43   #14
FlyTDI Guy
FlyTDI Guy's Avatar
When boost is on, you're running your turbo hotter and somewhat unregulated. As the map only returns 2.5v and the ECU is expecting 3v for X boost, it's going to increase duty cycle to the N75 and turbo upping boost until the request is matched. Take it easy, watch your boost gauge (you'd better have one) and don't spike the dickens out of your turbo. Many before you have done it. All TDI's seem to respond a bit differently. Some will tolerate it without going limp, others not so much. Do some searching as I was going to do the same thing a few years ago but held off based on other info in threads here. There used to be a guy over on Geocities called tech4tdi that had charted the voltages of the 2 and explained things pretty well. If you're boosting under 18 psi and not spiking like crazy and can live with the side-effects...
Old April 25th, 2010, 06:17   #15
eddie_1
eddie_1's Avatar
right, i realized that after I posted. Your 18 PSI that you see on guage, vagcom or wherever will be under-reporting actual boost.
Page generated in 0.11886 seconds with 9 queries
[Output: 129.03 Kb. compressed to 107.53 Kb. by saving 21.50 Kb. (16.67%)]
