Old April 24th, 2010, 18:03   #1
eddie_1
eddie_1's Avatar
Default limp mode with 3 bar map - 16490
I just installed the 3 bar map and got CEL with DTC 16490 Manifold / Barometric Sensor (G71) / (F96) : Implausible Signal P0106 35 00. I had recently upgraded to 1722 turbo and pp764 everything was fine. Today as soon as I put in the 3bar map I lost all boost. The ECU is specifying different boost when I drive around, I logged some data group 10, 11 but the actual is always at atmos pressure. 999.6 mbar. Is this is a rc3 tune for 2.5bar sensor issue? i.e. is the voltage from the 3bar sensor much lower than the 2.5bar sensor and it is confused? Some folks were saying it would boost more with 3bar map, in my case it is the opposite. Unless it is connected properly, but i made sure it was ok and the wire is not damaged by the pulley or anything.
2008 A6 BPP 283kmh - 100-200 kmh 14 secs - 2003 Jetta Wagon ALH 150mph, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old April 24th, 2010, 19:16   #2
vwmikel
vwmikel's Avatar
When the key is turned on the ECU checks the correlation between the MAP sensor and the atmospheric pressure sensor in the ECU. If they are not saying the same thing then the ECU doesn't know what to believe and goes into limp mode as you're experiencing. For this not to happen the ECU needs to be reprogrammed with the correct linearization for the new MAP sensor.
vwmikel is offline   Reply With Quote
Old April 25th, 2010, 06:12   #3
eddie_1
eddie_1's Avatar
I had measured the MAP voltage from before with the 2.5bar stock map so I could compare with current 3 bar MAP.
Stock 2.5 bar MAP:
With Ignition on, Engine Off : 1.94V
With Ignition on, Engine Idle: 1.98V
3 bar MAP:
With Ignition on, Engine Off : 1.62V
With Ignition on, Engine Idle: 1.65V
It appears the ECU does not like the difference at engine turn on as you said.
Old April 25th, 2010, 07:58   #4
Jugghack2
could a person put a pull up resistor in the circuit to raise the voltage a little and sacrifice a little boost in the process maby control it as a temp fix till a chip is installed?
Brian
99.5 A4, Jetta, 5 speed, 1.9 Tdi ALH, .205 nozzels, 11mm pump (dead Timing belt)
00 A4 Jetta, 5 speed, 1.9Tdi ALH, .216 nozzels, 11mm pump, maf rotated
02 2500HD Duramax LB7 6.6l, 6 Speed Stick, Edge with Att. Pod/overhead, CP Mac's SMF/SDC, MBRP CD's, AFE II, 285 rubber, and more to come
Jugghack2 is offline   Reply With Quote
Old April 25th, 2010, 08:43   #5
eddie_1
eddie_1's Avatar
I think it is doable for sure. Since the MAP is just a variable resistor changing according to pressure difference. One could put a resistor on the ground side like a pull down which will bring the start voltage up to the 1.94V. One could measure the resistance across the map and size the pull down accordingly or use a pot and tweak it. Essentially it will end up looking similar to the 2.5bar map if I'm not mistaken. I guess it is the hassle of doing that vs putting the old map back in. Either way I have to remove the bumper again.
Old April 25th, 2010, 11:38   #6
Jugghack2
could use a hobbs to take it out of the circuit at a preset boost level
normaly closed contact(4-8psi)
Old April 25th, 2010, 13:17   #7
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
you don't have to pull the bumper off... just take the washer bottle out...
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old April 25th, 2010, 13:31   #8
eddie_1
eddie_1's Avatar
First time around the screws broke off prob because washer fluid ate them....had to drill em out. But you just gave me a good idea try to use bolts to replace them next time. Easier to get at with angled extensions and ratchet.
Old April 25th, 2010, 13:52   #9
TDIJetta99
TDIJetta99's Avatar
Usually I can get the MAP off without even taking the bottle out, but with it removed, you can get your whole arm in there to mess with the MAP sensor...
Page generated in 0.12990 seconds with 9 queries
[Output: 93.14 Kb. compressed to 79.54 Kb. by saving 13.60 Kb. (14.60%)]
