VW Passat Family (NMS and B7) TDIs (2012+) Discussion area for the 2012+ Passat TDI (North American and rest of world versions versions). The North American model was previously codenamed NMS (New Midsize Sedan) and the version the rest of the world gets is sometimes referred to as B7. |
August 19th, 2011, 10:01
#1171
Well, a lot of people don't live in places where that's an issue. In Canada, the Passat comes with a block heater. For people living in places like North Dakota, the lack of a block heater is a problem.
Heated lenses is another layer of complexity, like so many other things including sunroofs, navigation, backup cameras, airbags, seat belts, CD changers, ad infinitum.
LED lighting is more efficient than incandescent, unless the waste heat from incandescent bulbs is needed for heating purposes. So, for those who don't live in cold climates, LED is more attractive -- just like not having to pay for a block heater.
August 19th, 2011, 10:08
#1172
Is this true? I saw this posted about the '11 Jetta in Canada, too. Thought it was another myth like the glow plugs that come on when you open the driver's door. Remember that?
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
August 19th, 2011, 10:30
#1173
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Or the fuel pump starting when you hit the unlock button?
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
August 19th, 2011, 11:17
#1174
I read somewhere that a block heater is standard for the Canadian 2012 Passat. What people in North Dakota are supposed to do remains to be seen, because I haven't seen any evidence that VW is allowing buyers to add this as an option.
Edit: This is odd. A listing in Texas shows a block heater.
Originally Posted by myturbodiesel
The VW Passat TDI SE ($25,995) comes with:
-17" "Sonoma" alloy wheels
-6 speed manual transmission
-fog lamps
-8 way driver power seat with power lumbar function (front-back only, not up-down) and 6 way manual passenger seat
-leatherette (vinyl) interior
-leather steering wheel, shift knob, and parking brake handle
-full multifunction steering wheel and display
-rear multilink suspension
-electric power assist steering (saves energy)
-premium 8 RCD 510 touchscreen 6cd changer radio
-bluetooth
-dual zone auto climate control
-cold weather pack (heated front seats and windshield washer nozzles)
-soft touch dashboard (higher quality plastic)
-engine block heater (standard in Canada)
-auto headlights / wipers and auto dimming interior rear mirror
-diversity antenna (gives a stronger radio signal)
-3 years/ 36,000 miles free scheduled service
If those specs are correct, it looks like all the TDIs have a block heater. Hmm...
link
Here is a Canadian specs listing.
FSF: Fuel System Failure. "Since the CR fuel system failure is so expensive, ... " — eddif
August 19th, 2011, 13:46
#1175
I wonder where myturbodiesel.com got that list. If it's from a VW web site I'd call it suspect. Lots of misinformation there. Also, this may be early data that doesn't play out in production. I'm betting there won't be a factory-installed block heater. To my knowledge no VW diesel car has had one.
August 19th, 2011, 15:27
#1176
Can't speak for the TDI models, but the 2006 Jetta 2.5 I just traded in would power the fuel pump when the driver's door was unlocked and opened. The sound was pretty obvious. Only ran for a second or so to pressurize the lines.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan: other daughter has 3 kids
August 19th, 2011, 15:41
#1177
I've been wrong before, but I'm fairly certain the CRs are block heater equipped in Canuck land.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
August 19th, 2011, 17:33
#1178
Fuel Economy: Check my Fuelly
Correct
Here's one in Manitoba.
See: http://forums.tdiclub.com/member.php?u=70344
Unless Jack had it added as an option?
D
August 19th, 2011, 18:34
#1179
I can definitely confirm that my Golf TDI came with a factory block heater, and an extension cord that plugs into a receptacle in the lower grille.
You can see the cord in my trunk just to the lower left in this picture, I keep it in the little storage cubbyhole there:
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
August 19th, 2011, 18:37
#1180
Is it a block heater or a coolant heater? Where does it live? Curious because since the days of my '78 Rabbit VW has been reluctant to say they would provide or approve of block heaters. If they now have them that's great. But it seems to be a significant change in direction. I'm also wondering why they think the common rail cars need them.
August 19th, 2011, 18:38
#1181
Oh. It may be a coolant heater, probably is in fact, I just went generic with block heater.
August 20th, 2011, 04:30
#1182
TDIClub Enthusiast ToofTek Inventor
It's a coolant heater, along the lines of a Frostheater, although ETKA uses the terms interchangeably.
The hose between the thermostat-oil cooler-heater core pipe and the oil cooler is replaced by the heater hardware.
Originally Posted by Lug_Nut
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
August 20th, 2011, 06:34
#1183
I haven't a clue what it heats, but the VW.ca website says this on its Golf TDI specifications page:
2.0 TDI, 140 horsepower engine with 6-speed manual
2.0 TDI, 140 horsepower, 6-speed DSG automatic engine with Tiptronic®
16” alloy wheels
Heatable front seats and washer nozzles
Electronic Stability Control (ESC)
Fog Lights
Engine block heater
Golf TDI Features & Specs
I had a look under the hood but with all the shrouds, wiring harnesses and equipment I can't see where the power line goes to.
On the grille though, this is where it plugs in, under a little spring loaded cover near the left foglight.
Cover closed:
Cover opened:
Mike
August 20th, 2011, 07:59
#1184
Fuel Economy: 41 Winter | 45 Summer
That is cool - I want that!! The fogs would be nice too while I am at it. Can we order the heater, harness & plug here in US??
I did not have issues last winter which was cold, but insurance never hurts....
2012 JSW | 6MT | Candy White | Cornsilk | Pano Roof | Huper Optik ESC 45 | Sport Protection Kit | Panzer Plate | VCDS
^^~^^ Mambo | X-Ice Xi2 ^^~^^ Goal | Pilot Super Sport FOR SALE: '12 Jetta Sportwagen 6MT
August 20th, 2011, 10:37
#1185
As far as the VW parts distribution network is concerned, the US and Canada are the same region, so yes.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
New Polo confirmed for the USA, with TDI
characterzero |
TDI News/Tech |
516 |
May 21st, 2012 18:40 |
Rabbit GT TDI confirmed at Dealer Meeting
twigless |
General VW Discussion |
45 |
February 25th, 2011 05:16 |
2010 TDI golf confirmed for North America
winterlocked |
VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) |
956 |
May 29th, 2010 19:16 |
Possible fuel pump "confirmed kill" with a 96 tdi
ybiofuels |
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) |
5 |
August 17th, 2004 09:04 |
Confirmed: Not all MkIV's have immobilizers!
TDIBri |
VW MKIV-A4 TDIs (VE and PD) |
22 |
April 8th, 2004 12:10 |
