Old April 19th, 2010, 14:11   #1
Rowan
Rowan's Avatar
Default '98 Jetta Engine Diagram?
I've done a lot of searches and can't find anything. I just need a simple diagram of labeled parts for reference on my '98 Jetta Engine (everything under the hood).
Anyone know of such a thing?
Rowan is offline   Reply With Quote
Old April 20th, 2010, 16:09   #2
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
Do some reading in the TDI Conversions forum. There are a few links posted in guy's swaps.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old April 21st, 2010, 19:11   #3
Rowan
Rowan's Avatar
Did some reading. Couldn't find much.
Old April 21st, 2010, 21:26   #4
Duster408
Duster408's Avatar
TDI(s): 1998 Jetta
Do you have a the Bentley Manual for your car? I believe there are pictures/diagrams in the first chapter showing the parts of the engine.
1998 Jetta TDI Porcelain Blue Metallic, PDR .216 Nozzles, InMotion Stage 2, PD130 Intake (EGR and Cooler delete), Converterectomy, VAG-Com Tool
2007 Honda CRF450X
Exploring anthracite coal mines in the northern field - www.UndergroundMiners.com
Eat more Tastykakes
Duster408 is offline   Reply With Quote
Old April 22nd, 2010, 13:04   #5
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
That's the oil dipstick. Pull it out to see how much oil is in the engine.
That's the oil fill cap. If you need oil add it there.
That's the windshield washer jug. ........
What are you trying to identify?
That is the N18, it's used in conjunction with the VE I-Ps and gets command signals from the ECU.
Something in between those scenarios?
Svante Arrhenius 1896
Old April 24th, 2010, 10:28   #6
Uberhare
Uberhare's Avatar
Sorry, must have been tired when I read your original post...I thought you were looking for wiring diagrams, not component location.
Old April 24th, 2010, 10:33   #7
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Here you go:
http://forums.tdiclub.com/showpost.p...7&postcount=19
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old April 24th, 2010, 15:55   #8
Stealth TDI
Stealth TDI's Avatar
He's looking for a road map. These are a bit big for forums; but they'll do:
European 1Z intake manifold... but the location is the same...
Have Fun!
Stealth TDI is offline   Reply With Quote
Old May 19th, 2010, 09:07   #9
Rowan
Rowan's Avatar
thank you!
Old April 20th, 2016, 08:18   #10
dlasala
Can anyone point me in the right direction to find the part numbers for each of these parts in the diagram above?
I am looking to replace my turbo and want to buy replacement gaskets and fasteners before hand.
I have a 1998 Jetta AHU engine.
Thank you
Don
dlasala is offline   Reply With Quote
Page generated in 0.13313 seconds with 9 queries
[Output: 92.82 Kb. compressed to 78.16 Kb. by saving 14.66 Kb. (15.80%)]
