Old April 8th, 2010, 18:35   #1
TheKid7
Default Battery Changeout-Computer Memory Saver
I am planning to change out my battery myself on my 2003 Jetta TDI in the near future. The changeout is going to be done for preventative maintenance (before the battery fails). I do not want to be stranded somewhere. I did not know until today that you need to keep voltage on the computer during the changeout process. I have located an inexpensive 9 volt computer memory saver that I can purchase.
Questions:
1. What happens to the computer if power is totally lost? Will the car not start at all with the new battery?
2. How many other makes/models of vehicles require a computer memory saver hookup for a battery changeout? I never had any known problems with my battery changeouts of my previous vehicles (1993 Mercury Sable & 1995 Chevrolet P/U).
Thanks in Advance.
TheKid7 is offline   Reply With Quote
Old April 8th, 2010, 19:52   #2
Vince Waldon
Vince Waldon's Avatar
I think you've been misinformed. Unless you are worried about losing your radio presets and clock time there's no reason to maintain battery voltage... the car and ECU will be fine. Kinda makes sense...how long would a car design last where the car was toast if you ever left your headlights on?!
For safety sake it's a good idea on any car equipped with airbags to make sure there's no one in the car when you reconnect the battery, and you may need run the power windows up and down a couple of times to initialize the controller module, but other than that swap away.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old April 9th, 2010, 06:41   #3
jettawreck
jettawreck's Avatar
X2 as above. You have been BS'ed.
The only other thing I would add is to be very careful not to let the battery cables touch/ground out to anything and place them onto the respective PROPER connectors (+/-) correctly and firmly. Don't just lay them there until you tighten them up. I have found out (the hard way) that the radio/stereo head unit can be rather sensitive to this sort of thing.
The only thing lost the last couple times I've changed batteries was the clock time, radio presets and antitheft recovered themselves.
2004 Cadillac SLS (wife's)
Old January 31st, 2012, 13:23   #4
CFIMuncie
TDI(s): 2000 Jetta
Fuel Economy: 40
Just want to confirm that you do not need a memory saver. The repair manual that I have states that you will have problems if you do not use a memory saver. Says that you will have to have a scan tool to reset several values in the ECM if you do not use a memory saver. I have a 2000 TDI Jetta that needs some stater work and I would rather not weld my wrench to the frame.
CFIMuncie is offline   Reply With Quote
Old January 31st, 2012, 13:48   #5
JB05
Fuel Economy: 43/41/40
All you may need to worry about is the radio code which should be in the owner's manual. You will have to reset the clock and your radio stations, and you will lose your current trip OD reading.
JB05 is offline   Reply With Quote
Old January 31st, 2012, 14:11   #6
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Questions:
Thanks in Advance.
No "memory saver" required for a TDI.
IIRC, some gasser models might need to go through a throttle body calibration procedure after connecting up the the new battery but this procedure is N/A for diesels including TDIs.
If the radio head unit is the original, no radio code should be needed because the car and radio should recognize each other as belonging together. If the head unit has been swapped, the radio code might be needed. If the head unit is an aftermarket system, all bets are off.
In your case the most you should need to do is reset the clock on the instrument cluster after the swap.
My 02 Golf TDI (don't have it anymore, sold it a while ago) has sat parked for 2 weeks without a battery in it and without any ill effects afterwards. The most I had to do after reinstalling the battery and getting the car back on the road was reset the clock.
Good luck.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old January 31st, 2012, 16:06   #7
Vince Waldon
Yup some gassers benefit from a throttle-body adaptation after a long power loss but on our TDIs no worries... I've had batteries in and out of my two 2001 Jettas repeatedly over the years without issue.
Old February 1st, 2012, 10:41   #8
> Luke <
Default We continue to learn
Fm > n1das
Thank you for the input..
As of 3/2/17: Latest 10 Fill-up Moving Average = 51.5 MPG. at 260,417 miles. Zero Oil usage. Only Chevron Fuel. I also carry a 6 gallon reserve container, used weekly: Thus allowing me to fill every Sunday. Latest fuel use average from purchase date = 50.4 ^ MPG & still Very happy with my vehicle.
> Luke < is offline   Reply With Quote
Old June 22nd, 2013, 00:14   #9
TDI in MT
TDI in MT's Avatar
An old thread, but I wonder how can I prevent having to reset the time & anti-pinch on the windows (and keep the trip odometer) when the battery is disconnected?
My radio didn't lose anything, but I had to reset the time, anti-pinch and lost the trip odo when I disconnected the battery today. Irritating, especially the trip odo since I'm trying to record MPG.
TDI in MT is offline   Reply With Quote
Old June 23rd, 2013, 05:04   #10
Powder Hound
Powder Hound's Avatar
Well, if you are that worried about those few things, then a memory saver that connects through the power port in the dash will have to do. Another possibility (although I've never tried either) would be to plug a solar cell into the OBD port and do the swap in the sun.
cheers, PH
Old June 23rd, 2013, 18:49   #11
Strykeviper
Fuel Economy: '01 33-39; '00 40-53
Snapping a pic of the trip odometer works well too but it won't help with the clock and radio presets.
'15 Passat TDI SEL 37k
'00 Jetta TDI, 226k, Atlas skid plate, 3 Pedal Mod, DG short shifter
'01 Jetta TDI, 188k, Atlas skid plate, 3 Pedal Mod
Strykeviper is offline   Reply With Quote
Old June 23rd, 2013, 19:25   #12
Scoutx
One last piece of advice.
Remove the negative lead first...and install it last.
Helps avoid inadvertent grounding of the positive to the frame with your metal wrench. :-)
2012 - No mods. First Mk6 in 800 mile club & 1000 mile club (Totaled and retired)
2015 - No Mods.
Scoutx is offline   Reply With Quote
Page generated in 0.16073 seconds with 9 queries
[Output: 109.66 Kb. compressed to 92.34 Kb. by saving 17.32 Kb. (15.80%)]
