Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old April 7th, 2010, 17:58   #1
yhmtdi
Fuel Economy: ~5.8l/100km
Default Cannot shift into 5th gear
***Update*** See end of thread
Had a wierd problem come up suddenly yesterday. I cannot get the transmission into 5th. Gears 1 to 4 work fine, but not 5th. Can't seem to move the shift lever past the 3-4 gate. Popped the shifter boot off inside to see if there was anything binding in there, but nothing obvious. Tried it by hand under the hood, and can pull the relay lever up a little bit, but can't get engage it. It's like the clutch gear is stuck on something.
Anyone ever had a problem like this? Any suggestions? I'm guessing the transmission will need to be opened to fix it, so may as well look for another one, and just change it out. Anyone have one they're will to part with for a reasonable price?
Oh, btw, car is a 2001 Golf, 264,000km. I've had it since 144,000km, so I don't know what might have happened to it before then. The shifter has never seemed as smooth as the one on my '90 GTI, or '82 Jetta, but I just figured it was because of the cable shifter linkage.
Anyways, any help would be appreciated.
Thanks,
Mark
'01 Golf TDI
475,000km
yhmtdi is offline   Reply With Quote
Old April 7th, 2010, 19:11   #2
Sebpt
Sebpt's Avatar
I would suggest to take the transmission cover off and see if your synchro engages on the 5th gear splines. Have someone in the car while you are checking it. VW trannies are usually very reliable...You may have something broken, no need to replace the transmission if just a part and tranny oil
My 2 cents suggestion before spending a lot of $$'s
Sebpt is offline   Reply With Quote
Old April 7th, 2010, 20:22   #3
bbarbulo
have you seen all the threads with people having issues with shifting/engaging a gear. i've noticed, cuz i'm one of the ppl having problems so i searched the forum. so very far from reliable
FOR SALE!!00 TDI Golf 5spd, satin silver GTI tails w/ 5 light brake mod 20AE springs Bilstein SS shocks 17 Long Beach Altas skid plate clear repeaters short antenna Clarion deck G60/VR6 clutch
bbarbulo is offline   Reply With Quote
Old April 7th, 2010, 22:32   #4
yhmtdi
To which cover are you referring? I noticed that the Bentley manual does not cover transmission disassembly anymore (the older manuals did). Are there any pictorial guides for transmission disassembly?
Thanks,
Mark
'01 Golf TDI
475,000km
Old April 7th, 2010, 23:45   #5
blizzak
Dieselgeek has an adjustment video that might help you, supposed to return everything to normal:
http://forums.tdiclub.com/showthread.php?t=259787
Hope this helps.
Blake | Custom alignments available in Southwest GTA
2004 Grey TDI Sport Edition | 270,000 km | Grey | 6 speed ERF transmission with upgraded shifter fork & LSD | R32 18 Aristos | PP Downpipe, 2.5 SS exhaust with Magnaflow muffler, rest of mods in profile
Whitedog's no start thread - very useful!
blizzak is offline   Reply With Quote
Old April 8th, 2010, 05:36   #6
kack
kack's Avatar
Fuel Economy: 56/48/43
Try the above posts adjustment techinque I have helped many people with shifting issues using that.
I figure its due to the plastic end connectors vs the metal cables
04 Forester STi
90 Legacy RS-RA
no tdi for now
kack is offline   Reply With Quote
Old April 8th, 2010, 14:27   #7
yhmtdi
Thanks for your responses. I will try the linkage adjustment as per the video - very good how to, btw.
But I'm not sure if that will do it, because I can't even find 5th to shift into when I do it by hand under the hood on the lever on the transmission. I can get reverse, and 1..4, but can't pull it up to get 5th.
Are there any other manual transmission videos around? - disassembly, removal & install, etc. would be helpful in diagnosing and fixing the problem.
Thanks,
Mark
'01 Golf TDI
475,000km
Old April 8th, 2010, 15:18   #8
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Check the transmission fluid level... Historically, VW transmissions "lose" 5th gear first due to lack of lubrication... If that doesn't get fixed, you'll lose the rest of the gears...
Yuri
ymz is offline   Reply With Quote
Old April 8th, 2010, 15:29   #9
BleachedBora
BleachedBora's Avatar
x2 on Yuri's statement. I just sold my 3rd transmission since Friday, a very common failure is 5th going out, usually from low fluid.
-BB
BleachedBora is offline   Reply With Quote
Old April 8th, 2010, 15:35   #10
VDUB TECH
VDUB TECH's Avatar
especially commuter cars that are in 5th most of the time.
VDUB TECH is offline   Reply With Quote
Old April 8th, 2010, 15:53   #11
yhmtdi
Thanks, I was planning to check the oil level too, although there have been no noticable leaks, except a little wetness around the drive flange seals. But I haven't had a VW yet (this is my 5th VW) that didn't have some seepage there, and have never had a problem with 5th.
Mark
'01 Golf TDI
475,000km
Old April 8th, 2010, 17:32   #12
Savageman69
Savageman69's Avatar
How do you check the oil on a 5spd???
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap
Savageman69 is offline   Reply With Quote
Old April 8th, 2010, 17:35   #13
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
On the 02J trans, there is a 17mm plug on the side of the trans that you take out and the level should be near or at that plug level. It holds 1.9 liter or so.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old April 9th, 2010, 06:33   #14
VDUB TECH
VDUB TECH's Avatar
wrong, the proper fluid level will actually cover the 17mm hole.your thinking mk3.
Old April 9th, 2010, 07:38   #15
aja8888
aja8888's Avatar
Well, that is how we just filled our 2001 Jetta, from the side-located 17 mm plug hole. Am I wrong (MKIV), and if so, tell me the correct procedure please.
Page generated in 0.15326 seconds with 9 queries
[Output: 125.66 Kb. compressed to 104.03 Kb. by saving 21.63 Kb. (17.21%)]
