Old March 27th, 2010, 12:17   #1
JM Popaleetus
JM Popaleetus's Avatar
Default Found this interesting: "VW Approved Diesel Fuel Additive"
Saw this in the parts department at my local dealership today.
2013 VW Passat TDI SEL Premium (Candy White/Cornsilk, Lip Spoiler, 17" Salamancas)
2010 VW Jetta TDI Sedan (DSG, White Gold/Cornsilk, Sunroof) RIP
2007 GMC Sierra 2500HD Duramax (Classic, Extended Cab, Summit White/Ebony)
JM Popaleetus is offline   Reply With Quote
Old March 27th, 2010, 12:24   #2
danham
TDI(s): 2010 JSW
That is indeed very interesting. But now the question is, approved for which engines? If they are relying on the old service bulletin, it may mean approved for pre-common rail engines only.
-dan
2010 Jetta TDI SportWagen, black/black, stick, pano roof, Porto 17" wheels, iPod, protection & luggage Legos, nuvi 760 GPS, V1 radar, DRLs disabled, iPhone "GasBook" app as fuel finder.
Previous rides: '06 Audi A3 2.0T (traded for JSW); '98 Audi A4 1.8TQ chipped; '92 Corrado VR6; '90 Corrado G-60; '87 GTI 16v; '83 GTI; '77 Diesel Rabbit; '71 Porsche 914-4; '67 Volvo 122S; '66 Porsche 912.
danham is offline   Reply With Quote
Old March 27th, 2010, 12:31   #3
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
That brand has for a long time been "sanctioned/ sold, etc. " by VWA/local VW dealers. As of the 2009 TDI MY oem owners manual says NO additive is needed and/or recommended. The unofficial issue being low saps. I have heard nor seen no update in the 2010 MY owners manual or web thread.
ruking is offline   Reply With Quote
Old March 28th, 2010, 08:25   #4
DEZLBOY
DEZLBOY's Avatar
Originally Posted by ruking
.. As of the 2009 TDI MY oem owners manual says NO additive is needed and/or recommended. The unofficial issue being low saps. I have heard nor seen no update in the 2010 MY owners manual or web thread.
The unofficial issue being low saps... ? Can you explain, thanks?
And...I use Standyne in my 2000 TDI all the time. Good or Bad?
162K miles as of July 2015
DEZLBOY is offline   Reply With Quote
Old March 28th, 2010, 08:56   #5
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Low SAPS-
low sulfated ash, phosphorus-sulfur. usually associated with engine oil- not fuel.
the issue with fuel additive is sulfur content. It needs to be <16ppm sulfur content to work with a DPF equipped vehicle.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old March 28th, 2010, 16:50   #6
T_D_I_POWER
T_D_I_POWER's Avatar
Good stuff use it all the time w/o any issues what so ever
http://www.stanadyne.com/docs/puba/9...v%209%2008.pdf
http://www.stanadyne.com/docs/puba/9...cts%201109.pdf
http://www.stanadyne.com/docs/puba/99835%20PF%20907.pdf
http://www.stanadyne.com/docs/puba/9...F%20poster.pdf
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old March 29th, 2010, 06:23   #7
20IndigoBlue02
20IndigoBlue02's Avatar
-dan
It's nothing new. VW released a TSB many years ago, probably starting around the Pumpe-Duse days in regards to using the Stanadyne All-Season formula to reduce the likelihood of of fuel gelling in the winter.
Just search and you'll find the TSB.
my old 02 manual also said, fuel additives are not necessary.
P.S. If VW printed in the owner's manual to only use the Stanadyne stuff, it actually violates the magnuson-moss act, which is why it is safer for them to write additives are not necessary
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old March 29th, 2010, 06:32   #8
dpg
the same one my dealer has at their shop. I bought the big jug of it when I first bought my car and have been using it since my first fill up.
dpg is offline   Reply With Quote
Old April 4th, 2010, 08:34   #9
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
I use both Stanadyne Performance Formula and PowerService- both with no issues at all. Knowing that a VW dealer is selling Stanadyne opens them up to all sorts of issues. Or the dealer could end up in the hot seat. Since the manual in the 09/10's stated "no additive", what happens when Mr. and Mrs. NewVWtdiowner stop in and buy this for their new 09/10, but the dealer failed to inform them NOT to use it in their 09/10?? The sign doesn't specify which car it can be used for does it? I would bet the parts guy doesn't know either.
Use a good additive- your fuel system will thank you for it.
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old April 4th, 2010, 09:44   #10
thegrinch911
Fuel Economy: 62/55/48
Used Stanadyne after a gel up of the fuel system. Worked great but there are more lubricating additives than it. Now using Optilube, best non-biodiesel additive out there. http://www.opti-lube.com/XPD.htm
2001 Blacked out Jetta TDI 5 Speed, 241,000 Miles, Dieselgeek Panzer Plate, tinted windows, 55+mpg average at 60mph, stock 15 inch alloys (blacked out)/Goodyear Eagle GT tires and 15 inch Steels with Bridgestone Blizzaks for the winter
thegrinch911 is offline   Reply With Quote
Old April 4th, 2010, 09:59   #11
It's approved for the PD cars only, AFAIK. They never approved an additive that I'm aware of for the rotary cars, nor have they for the '09 and '10s.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old April 4th, 2010, 10:23   #12
spence
TDI(s): '06 Golf
Hi there.
I just picked up my first TDI -- an 06 Golf (and I LOVE it).
When I picked it up, the sales guy gave me 4 bottles of this stuff and said that I should put 1/3 a bottle per fillup, every time. I was told that this was because of the high sulfur content in Canadian fuels. I have been wondering though, Shell V-Power is advertised as low (ultra low?) diesel, so is this still required?
Either way, I am thrilled to be driving such an efficient car -- I am sitting at about 505KM and the needle is just now hitting the mid-way point
spence is offline   Reply With Quote
Old April 4th, 2010, 13:29   #13
DEZLBOY
DEZLBOY's Avatar
Originally Posted by spence
Hi there.
sales guy...gave me 4 bottles...was told that this was because of the high sulfur content in Canadian fuels. )
Salesguy wrong!
All diesel sold in Canada is low sulfur, 15 ppm, same as US. From Canada's version of the USA's EPA. "Environment Canada’s approach on the Sulphur in Diesel Fuel Regulations is to align with the requirements (timing and level) of the U.S. federal regulations. "
See question five http://www.believeinit.ca/userfiles/pdf/ULSD_Q&A_e.pdf
That being said, I used Standyne Power Formula every fuel up - according to directions on label.
Old April 4th, 2010, 17:07   #14
Your sales guy was right if you replace the word high with low. ULSD is low on lubricity and the stanadyne helps.
Old April 5th, 2010, 06:18   #15
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Woa nOOB alert
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Page generated in 0.10361 seconds with 9 queries
[Output: 127.27 Kb. compressed to 105.72 Kb. by saving 21.55 Kb. (16.93%)]
