Old March 23rd, 2010, 11:19   #1
oshaggy
TDI(s): 2000 VW Golf
Default P0380 - Glow plug replacement
Hi All,
I have a '01 Golf 1.9L TDI that threw a P0380 code two days ago. Upon diagnosing the glow plugs, I found the left most glowplug blown as the ohms resistance was infinte, where all of my other glow plugs ( including the coolant plugs ) measure between .5 to .7 ohms.
My question is about the replacement of the burnt glow plug. Some people are telling me to replace all 4 engine glow plugs, others tell me that replacing just the one glow plug is alright, so long as I have the same brand.
I find the dealer here in Maple Ridge, BC wants $46.82/each, and Lordco wants $32.59 for Bosch, and $31.00 for Autolite brands. Another shop only sells BRU for approx $20/ea. Is there a recommended brand?
Is there a rule of thumb to replacing burnt out glow plugs that I should be following here?
Thanks for your assistance, and the code from the VAG-COM is pasted below.
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller: 038 906 012 CP
Component: 1,9l R4 EDC G500SG 2839
Coding: 00002
Shop #: WSC 00000
1 Fault Found:
16764 - Glow Plug/Heater (Q6) Circuit Malfunction
P0380 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00000
No fault code found.
oshaggy is offline   Reply With Quote
Old March 23rd, 2010, 11:47   #2
BobnOH
Fuel Economy: 50/45/35
there's no rule of thumb. if you replace it with proper plug, you'll be fine. IDParts has Bosch for $19+ship. other good vendors recommended on this site. personally, I would replace all 4 if they're more than 4 or 5 years old. soak the old ones with penetrant before removing, use a light coating of anti-seize on install
Old March 25th, 2010, 04:48   #3
vwpei
vwpei's Avatar
TDI(s): 2001 Jetta
Default Glow Plug Replacement
Hi
I cheaped out last year and only replaced one plug. If I remember correctly I was given two options for plugs. I went with an aftermarket plug, and my MIL was off for maybe a week, before it threw another P0380 code again. The time before that I replaced a plug I bought from VW dealer, and the difference in resistance was throwing the code. Sometimes cheaping out seems like a good idea, but it usually bites you in the end. So I don't think you necessarly have to replace all 4 plugs at once, but remember what type of plug you bought, and stay with that brand.
vwpei is offline   Reply With Quote
Old March 25th, 2010, 05:15   #4
Quanger
TDI(s): Mk4 ALH TDi
I would just go ahead and replace all 4. They're not that expensive if you buy from the right source.
01 Golf 2dr GL TDI MT
Quanger is offline   Reply With Quote
Old March 25th, 2010, 12:13   #5
VW Petrolero
Replace all 4 use the Beru brand they are good quality parts.
Regards
VW Petrolero
Andes Auto is back in Richmond B.C.
(604) 401-2130
TDI Friendly Repairs.TBs & Vag-Com .
VW Petrolero is online now   Reply With Quote
Old March 25th, 2010, 12:43   #6
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Bosch or Beru will do... I believe that one of them licenses the design from the other. http://www3.ns.sympatico.ca/roseland/VWPartsA4.htm
http://www.precisiontuning.ca/catalo....php?cPath=187
Yuri
ymz is online now   Reply With Quote
Page generated in 0.14619 seconds with 9 queries
[Output: 69.08 Kb. compressed to 59.88 Kb. by saving 9.20 Kb. (13.31%)]
