Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old March 21st, 2010, 22:36   #1
windsolar
Default 12V/24V DC circulation pump for coolant
I am looking for a 12 v DC circulation pump for coolant to heat my converted TDI up quicker and use less diesel. Below is a description of one sold at Plantdrive for $200. Anyone know of another one like it or where else I can get it for less? Thanks, Chris
wear out, no shaft seals to leak. 50,000 hour rated. Used by the military as a booster pump to circulate coolant to the rear of Hummers.
Variable speed! Adjust the dial on the base to get the flow rate you need.
Very low power requirement: 1.9 amps: with a good battery (Optima yellow top combination deep cycle/starting battery for example), this means the pump can be run a number of hours after the engine is shut off and use residual heat to keep a system (in-tank heater, filter, fuel lines) warm!
If you plug in a 120V block heater for the engine, or use our 120V pad heater on a timer (and always use a heavy-duty irrigation timer - a cheap lamp timer won't handle the amp draw) and the pump will circulate heated coolant to entire system all night, for a fast switchover to heated SVO in the morning on the coldest nights; then run the pump as a booster pump to get maximum flow to the in-tank heater while driving.
Can be operated on 12 or 24V systems. Easy to change motor out to 120 VAC if desired, you do not even have to remove the pump from the coolant lines. Let us know if you need the 120 V AC version instead of this one! We can ship that way.
Can be mounted with brass housing up, or on side. Do not mount with brass housing down. Mounting bracket is not included.
1/2" NPT fittings. Brass housing withstands high temperatures.
Brushless motor.
1 year warranty.
windsolar is offline   Reply With Quote
Old March 22nd, 2010, 09:39   #2
bkrems12
try searching for an auxiliary water pump at thepartsbin.com - closer to $50 for a Mercedes Benz replacement pump
http://www.thepartsbin.com/catalog/?...+water&x=0&y=0
bkrems12 is offline   Reply With Quote
Old March 22nd, 2010, 10:38   #3
diy_fool
TDI(s): '00 NB
Many high end cars use a coolant pump for the heater core. It boosts heat while idling. My Lexus and Lincoln both use one.
A wrecker could set you up cheap, or look at the replacement market.
TDI Fest 2007 Je me souviens.
00 NB running biodiesel, PP502 and 11mm pump
diy_fool is offline   Reply With Quote
Old March 23rd, 2010, 15:33   #4
Todd B
Todd B's Avatar
This is the one I used, just because it came with wires that I could cut and wire into my 12v switched supply. Works great for getting the heat into the tank in the trunk fast, but on cold days (-10 deg C) it will take a lot longer to get the engine, interior and you up to temp.
List Price: $234.00
Our Price: $83.95
You Save: $150.05
Quantity:
Bosch Auxiliary Water Pump - Direct OE Replacement
1987-1993 Mercedes Benz 190E
Fits: Chas: -F845138, This unit has 12" lead wire. Bosch 0.130.002.070.
Type: Direct OE replacement
Warranty: 12-month or 12,000-mile warranty
Todd B is offline   Reply With Quote
Old March 24th, 2010, 19:19   #5
joeperry25
TDI(s): 2000 Jetta
The old Mercedes have them and they are 10-20 bucks at the junk yards. They work great.
joeperry25 is offline   Reply With Quote
Old April 4th, 2010, 19:52   #6
abakos
abakos's Avatar
TDI(s): -----
BMWs are the same...find an aux coolant pump w/valve assembly and have at it!
2004 M3 - Silver Grey on Blk, 6spd...I'm a traitor, yeah I know
SOLD - 2006 Jetta TDI/DSG Pkg 2
Silver on Black
abakos is offline   Reply With Quote
Old April 5th, 2010, 03:43   #7
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
I believe VR6s have them too, plus Webasto/Eberspacher sell them.
DPM is offline   Reply With Quote
Page generated in 0.11736 seconds with 9 queries
[Output: 75.89 Kb. compressed to 65.61 Kb. by saving 10.28 Kb. (13.55%)]
