Old March 20th, 2010, 10:45   #1
ks-tdi
TDI(s): 2009 Jetta
Default Changing air filter in 2009 Jetta
Either I am blind or there is no mention in any of the VW manuals about when or how to change the engine air filter. Yea I don't have really a "how to question" but I thought I could check the service booklet to determine when the dealer should have done this during one of my 3 free oil changes. I know they did not make mention of changing it recently at 33K miles so I am assuming it never has been replaced. Any thoughts from someone who has better eyes than I have??
ks-tdi is offline   Reply With Quote
Old March 20th, 2010, 11:25   #2
dweisel
dweisel's Avatar
Fuel Economy: 09 MB R320 Bluetec and too many ALH Beetles!
The only thing I saw in the Warranty and Maintenance guide was a mention at 60k miles or one year after last change. I will probably change mine annually or with each oil change at 10k,20k,30k............ I'm thinking I read somewhere that it called to be changed every 20k.
Dweisel
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
dweisel is offline   Reply With Quote
Old March 20th, 2010, 12:46   #3
adjat84th
adjat84th's Avatar
6y/60k miles according to the bentley manual
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old March 20th, 2010, 14:40   #4
ks-tdi
TDI(s): 2009 Jetta
With your comment about 60K miles, I was able to find it in the actual owners manual. Thanks. That sure seems like a very long time. Since it has not been serviced yet I will be changing this weekend.
Old March 20th, 2010, 19:22   #5
tdiatlast
FYI, in suburban DC, at 21k, mine appeared to be rather dirty (can't say "clogged"), I guess from all the sooty salty dust from the heavy snows we had. The pre-filter looked pretty nasty, and I couldn't see a bright flashlight through it.
No noticeabl echange in performance or mileage after the change. I'l probably continue to change it every 20k miles.
Is it really true that the gasket on the air filter is a "one time compression" and shouldn't be opened up for inspection? I find that hard to believe.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old March 20th, 2010, 19:31   #6
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Prior to the 09 models it was 40,000 miles for the PD engined MKV cars. Comparing them to farm tractor filters it would seem like they could last a lot longer than the specified service interval.
That said, I change mine each 40,000 miles, just like the book says. YMMV.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old March 21st, 2010, 04:23   #7
dweisel
dweisel's Avatar
The service manual also states 1 year. Change intervals are also going to be determined by the conditions you run in. Dusty rural roads are going to make a filter dirtier quicker than most other conditions.
Dweisel
Old March 21st, 2010, 10:02   #8
El Dobro
El Dobro's Avatar
Fuel Economy: 115 MPGe
My maintenance manual says at 60,000mi and at every 6 years, regardless of miles driven.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old March 21st, 2010, 12:35   #9
dweisel
dweisel's Avatar
Question
Page 41 Service at 60,000 miles or one year after last service,whichever occurs first.
I guess that means the first air filter is good for 60,000 miles and then service annually after that. At least thats if its to be taken literally. I'll be doing mine once a year whether it needs it or not. Same on the fuel filter,once a year whether it needs it or not.
Old March 21st, 2010, 12:57   #10
ks-tdi
TDI(s): 2009 Jetta
Dweisel...
OK maybe this is not as easy as I thought. I have all the screws loosened up but the top lid does not want to break free. What am I missing??
Old March 21st, 2010, 13:14   #11
40X40
Experienced
You have 60,000 miles on your car already? Bring it to the GTG next month and someone will be glad to help you change it.
Look in the Mid-west forum for the DCOTC GTG.
Bill
Old March 21st, 2010, 13:20   #12
ks-tdi
TDI(s): 2009 Jetta
I guess that why real mechanics have good lighting in their garages. Didn't see those rear screws. With those out it does make a difference.
Old March 21st, 2010, 14:06   #13
dweisel
dweisel's Avatar
Don't feel bad I did the same thing the first and second time I checked it out. Only its not the light. There is something like 8+ screws holding it secure.
Dweisel
Old March 22nd, 2010, 08:25   #14
Jettawolfs98
Jettawolfs98's Avatar
Fuel Economy: 42/38/30
Same thing happened to me yesterday, when I was trying to take the cover off, those rear screws are hiding very well.
I got a new one after 12k miles, the old one was just dirty not bad but 60k miles is way too much I think.
Maybe every 20k miles is ok but after this long winter, no way.
Julio M.
No TDI's but who know this might change
Jettawolfs98 is offline   Reply With Quote
Old March 22nd, 2010, 08:49   #15
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
This might be counter intuitive, but with oem recommendations @ 40,000 miles, I have been changing air filters (MK IV) @ 60,000 miles
Actually a "used" oem air filter filters the air better than a new one. Obviously, you don't want the air filter to be jammed clogged. Another thing is since you have changed the air filter early (@33k) with latest oem recommendation of 60,000 miles, it would be best not to yield to temptation and unscrew the air box (to check) until the next time you decide to change the air filter ( again oem recommendation in another 60,000 miles) When you unseat and reseat the silicon air filter sealing material , you increase the chances of creating a leak. This of course allows more of LESS filtered air in, aka DIRT/silicon particles.
ruking is offline   Reply With Quote
Page generated in 0.15849 seconds with 9 queries
[Output: 123.89 Kb. compressed to 102.54 Kb. by saving 21.35 Kb. (17.23%)]
