AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
InterCooler fan
Item 8. Replaced the InterCooler blower fan with a bottom mounted puller fan.....Done!
Below, is a "before" pic showing the top mounted blower fan. The pic is from inside the engine bay looking toward the left rear corner of the Vanagon. The assembly is behind plexi-glass... You can see to the left that the tail light assembly has been removed.. (Check out the modified EGR assembly. I used the valve stem hole as a place to tap for boost gauge piping.) [this and simliar pics are in previous posts]
Below, is a pic of the same area after removing the blower fan.
Below, is a shot looking thru the left tail light hole. The four studs were fabricated from aluminum bolts and welded to the InterCooler. They were made extra long to mount the "blower" fan. The spacers are 1/2 copper plumbing pipe ...... just left it as is! The demensions of the IC are roughly the same as an OE IC on an ALH Jetta/Golf/NB. That info was posted much earlier in this Thread.
Below, is a pic of the bottom side "before" installing the puller fan.
Below, is a pic with the puller fan installed. This fan seems to "move" more air and is much quieter. Yeah, I used some silicone chalk to close any perimeter holes.
Below, is a pic of the puller fan without the shield installed.
There was a very small oil leak from the sensor. So, while I had the IC out, I gave it a good pressure wash, inside and out. I used new O-rings and oil pan glue to make sure that it doesn't leak.
EDIT: As you can see, the left rear corner of the Vanagon, down low, got whacked some time ago. The view is really not bad looking from a standing position.
