Old March 19th, 2010, 09:24   #1
Nickspera
TDI(s): 03 jetta
Default Blower motor resistor???
Gentlemen,
I have a 02 jetta TDI. i recnelty went to use my A/c and noticed that setting 1, 2, and 3 blow no air and setting 4 blows fine. whats weird is the a/c light only stays on from setting one through 3 and goes off on 4. so basically i am stuck with warm air. is this a blower motor resistor problem?? because the blower seems to work fine..
any help would be appreciated...
Nickspera is offline   Reply With Quote
Old March 19th, 2010, 13:08   #2
david_594
david_594's Avatar
Fuel Economy: 51.7/48.2/40.7
Originally Posted by Nickspera
Gentlemen,
The AC issue sounds like a bit of an oddball, but the fan only working on 4 is pretty typical for a failed resistor. Personally I would start by replacing the resistor and see if that resolves everything. At the very least it should get the fan working right, and then you can troubleshoot the AC.
david_594 is offline   Reply With Quote
Old March 22nd, 2010, 18:14   #3
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
__. Hey, David, congrats on Vet school - good luck with that. The symptoms he's described are typical of the failed resister pack. On 1-3 you get cold air (although the fan doesn't run and it's hard to tell) and the light is on, then on 4 the light goes off, the cold air turns warm, and the fan runs (DAMHIK). A new resister pack usually fixes it -- unfortunately, there is often a problem (like a fan that's pulling too much juice) that blew the resister pack in the first place and the other problem needs to be traced down and fixed (DAMHIK).
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Old July 30th, 2011, 20:06   #4
Herk
Default Fixed this problem for $2
Had similar issue, exact same symptom. Blower resistor failure, actually thermal fuse, resistor was fine. A few salient points I'd like to pass on:
1st: Although the FSM directs you to remove the glove box, although not difficult, this is unnecessary. The blower resistor is easily accessed by peeling a bit of insulation away above the passenger footwell. Once I had the glove box out, this became apparent (you would have to remove the glove box to replace the blower motor).
2nd: The resistor can be repaired. There is an integral "thermal fuse" which was the failure point in my case. There is a DIY on the Vortex that pretty much sums up the repair http://forums.vwvortex.com/showthread.php?2665283
On my 03, it worked YMMV
Herk is offline   Reply With Quote
Old July 30th, 2011, 20:30   #5
Shouse
Shouse's Avatar
Fuel Economy: 50mpg
Thanks for the Info. You don't have to pull the glovebox to replace the resistor but you do have to pull the glovebox (think I've seen a thread w/ a way around this but not sure if I recommend it) to access the blower. Seems that sometimes the resistor blowing is a cause of a blower malfunctioning so they would both have to be replaced in that circumstance.
-Pete
Project Commuter
Audio upgrade --- Sprint 520's
Ventectomy --- Panzer skidplate
Koni Yellows -- SBC Endurance Clutch
Shouse is offline   Reply With Quote
Old July 31st, 2011, 06:26   #6
jettawreck
jettawreck's Avatar
As mentioned, it usually just the thermal fuse on the resistor pack that goes. Its there to protect the resistor.
I've repaired two resistor packs by just replacing the fuse soldered across the terminals with a new one. You can get a new thermal fuse from Radio Shack for $1.75. Check the cabin air filter for clogging to make sure you are getting good air flow. The resistor pack gets hot. There is a thread written up with all the details. I think DanG144 posted the steps to fix. He helped steer me into diagnosing my failed fuse. The AC button will light in fan selector positions 1,2,3 but the fan will not run. Position 4, the fan runs but no AC button light.
Remove the glove box if you replace the blower fan motor, but you don't need to if you're just doing the resistor pack.
2004 Cadillac SLS (wife's)
Old January 24th, 2012, 10:15   #7
bjrpkr
TDI(s): 2004 Jetta
On 2004 Jetta, not necessary to remove glove box to get access to resistor pack.
bjrpkr is offline   Reply With Quote
Old January 24th, 2012, 12:00   #8
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
It is common. Normally the slow speed resistor goes, and then one at a time the others will go until the owner replaces them or you run out of resistors to replace.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 24th, 2012, 12:51   #9
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Back when the Golf was new, the stealer replaced the resistor pack three times. On the way home from work one day, there was smoke coming out of the vents, so I shut the ac down. I pulled the glove box out and started looking around to see if I could find something charred under there. At first, nothing, so I turned the AC back on and saw the source of the smoke. The harness had chafed through on one of the dash supports. Either the wiring harness was poorly routed at the factory, or the stealer had toofed it replacing the resistors. I think that it was the former, because I replaced the charred wires, taped it all back up, moved the harness out of harm's way and haven't had another problem with it in 11 years.
-George Bernard Shaw
Old June 25th, 2014, 14:48   #10
kretzs
TDI(s): jetta
Fuel Economy: avg around 56 mpg
Default Blower resistor
Thanks so much. Was able to replace the resistor without removing the glove box.
kretzs is offline   Reply With Quote
Old October 2nd, 2014, 19:00   #11
mjnsn1999
Fuel Economy: mid-upper 40's mpg
Thumbs up Thanks Herk
I was also having similar problems with the fan blower motor. After speaking with the dealer, I decided to do some research. Your thread helped me solve my lack of A/C and fan with the simple replacement of the thermal fuse and the cab filter (seriously required changing). The only difficulty I had was soldering the thermal fuse onto the resistor contacts. The soldering was extremely sloppy (I rarely solder). After multiple attempts the fuse was soldered. It is working like a champ but, my only concern is the soldering. How likely is solder failure?
Again thanks for the helping hand.
mjnsn1999 is offline   Reply With Quote
Page generated in 0.14020 seconds with 9 queries
[Output: 102.49 Kb. compressed to 86.56 Kb. by saving 15.93 Kb. (15.54%)]
