Old March 18th, 2010, 12:59   #1
russ_tdi
TDI(s): pd130
Default PD Melted piston
hello all
Iv got a pd130 with 17/22 turbo WI and all the norm bits to go with it. Was making 268bhp and 412lbft for over 2 years (22k miles) up untill a couple of weeks ago. Was going along at 85mph when it started running on three. so did the norm compression check and no4 was down, so thort head gaskit. when i ripped the head off i found that no4 piston has what i can only describe as melted the top on one side it has got very hot and saged. found no damage to rings or bore
Anyone had this or any ideas what it could be corsed by? was thinking if my injectors spray pattern was very bad it would only cool some parts of the piston with the fuel duse this sound right?
thanks
russ_tdi is offline   Reply With Quote
Old March 18th, 2010, 13:10   #2
vwmikel
vwmikel's Avatar
Originally Posted by russ_tdi
hello all
thanks
Perhaps it was a leaky injector causing preignition or it streamed...
vwmikel is offline   Reply With Quote
Old March 18th, 2010, 13:29   #3
silver_tdi
silver_tdi's Avatar
I would guess it would be your injector spray pattern. They operate at extremely high pressure. I have seen diesel injectors on C15 Cat's blow a hole right through a piston. Your PD injector runs at a higher psi than the Caterpillar engine does about 2050 bar or 29 750 PSI according to this source. http://www.langleyvw.ca/tech/pd.html
So even if your spray pattern was off just a bit it would make the top of the piston look almost melted. Is the point completely gone off of the top of the piston where the injector sprays if it is, that would be a good sign of improper spray pattern.
silver_tdi is offline   Reply With Quote
Old March 18th, 2010, 14:08   #4
hatemi
I just wonder it lasted so long with the claimed turbo and powerlevel. EMP->EGT->Molten engine.
www.tdituning.fi
hatemi is offline   Reply With Quote
Old March 18th, 2010, 14:13   #5
tdi_davy
Fuel Economy: 6/7.5/9
With this turbo i would not go higher then 215hp....
tdi_davy is offline   Reply With Quote
Old March 18th, 2010, 14:53   #6
vwmikel
vwmikel's Avatar
I don't even think that power level is even remotely possible with the hardware given, but with all of the dynos out there that defy logic and mathmatics you just have to give up.
Old March 18th, 2010, 15:09   #7
ArturCosta
Fuel Economy: (7.5L/100)(5.5L/100)(4.9L/100)
x2
Maybe it was never pushed hard for a long time... and when it was cabum.
I also own a melted piston in my garage
Back to topic , maybe the high PCP and EGTs where the reason the piston melted.
Artur Costa
Audi A4 1.9TDi(110bhp) 1996
GT1852vb , PP764+T4 Injectors+hammer mod ,260 dbilas cam, 450nm kevlar clutch , 5speed TDI115 gearbox, 60mm inox exhaust pipe , fuel cooler,oil cooler , 5L FMIC
ArturCosta is offline   Reply With Quote
Old March 18th, 2010, 16:55   #8
russ_tdi
TDI(s): pd130
cheers for the quick replys and input
I did find it wird that it was making that much power. I just thort it was a fluke as i was told the turbo had bin built a wee bit difrontly from the norm
iv had it on 4 diffront rolling roads came out as 259.8, 262.3, 265.1 and 268.2 so just went with it
Running at such a push i always thort something was going to give but i thort it would be the turbo 1st
now im re building it and going a step up with head work, race injectors and a bigger turbo i would love to get to the bottom of the problem so i can stop it from going agen
will try and get pics up asap. Think it will help a lot more than me trying to explane
Old March 18th, 2010, 17:01   #9
DanG144
Verify that your piston oil squirters are all good and clear, and aimed correctly.
This sounds as if it could be a contributor.
Dan
DanG144 is online now   Reply With Quote
Old March 18th, 2010, 17:09   #10
russ_tdi
TDI(s): pd130
one of the good pistons looks very sooted up
the bad one no4
Old March 18th, 2010, 19:16   #11
The Shootist
Be sure to check that injector. The melted spots match the spray pattern.
The sooted piston has a pattern that stretches a ways out onto the piston crown. I'm not that familiar with what that pattern normally looks like, but a deviation in timing could be an issue too.
2002 NB known as "Stitch" (small, round, blue, kinda cute...may bite if agitated). PP520s, RC3, EGR delete, turbo back 2.25" open exhaust, cat delete, Koni struts & springs Neuspeed bars, slotted rotors, 245-45-17 Sumitomo's. Things to do: H2O intercooler, VNT-2256, lift pump, bigger IP.
The Shootist is offline   Reply With Quote
Old March 18th, 2010, 21:08   #12
ocshaman
TDI(s): none
Fuel Economy: 14 kmpl
In your first post you mention WI, would that be water injection?
ocshaman is offline   Reply With Quote
Old March 19th, 2010, 00:28   #13
russ_tdi
TDI(s): pd130
yes running a water injection as well
Old March 19th, 2010, 09:54   #14
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
Was/is that water only or W/M mix?
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old March 19th, 2010, 11:58   #15
russ_tdi
TDI(s): pd130
water meth with a 40-60 mix. 40 meth 60 water
Page generated in 0.18142 seconds with 9 queries
[Output: 119.19 Kb. compressed to 98.60 Kb. by saving 20.58 Kb. (17.27%)]
