| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
March 16th, 2010, 15:13
#1
What weight Flywheel are you using with South Bend Clutch?
Hi all,
I am looking to buy a South Bend Clutch soon, but would like to minimize the shudder coming from the clutch. Would 21lb do this, or is 17lb the best option?
Any advice welcome.
March 16th, 2010, 15:14
#2
Oil Wanker
I'm using the stock weight SMF.
March 16th, 2010, 15:22
#3
Thanks, so do you get any shudder?
March 16th, 2010, 15:24
#4
Fuel Economy: ohh...I'd say bout 42mpg
I am running that exact setup...........no chatter and stock pedal feel. you won't be sorry.
2004 Jetta PD-RC race, 17/22,stg.IIcoltcam PD150 Inj.,Rosten Rods, Ported head,PP DP, cat delete/2 1/2" piping/Magnaflo muffler, R32 airbox/snorkle,PD150 TIP, SB stg 3 ,NSboost/egt gauges, BBS RS II's, Koni FSD/Eibach Kit, M3 side skirts/ rearwindow spoiler,GLI F/R lips FK bumper scoops
March 16th, 2010, 15:29
#5
Does the kit have everything I would need to have it fitted?
March 16th, 2010, 15:41
#6
Oil Wanker
Shudder when?
March 16th, 2010, 15:47
#7
I have SB 20 lb fly wheel. Standard feel, slight judder when cold, but thats it.
Passat 2.0TDI PPD170 BMR
March 16th, 2010, 15:55
#8
Thanks guys
March 16th, 2010, 16:48
#9
+2
Stock re-surfaced flywheel. No shudder. Pedal pressure is near stock but pedal is closer to the floor and engages with less pedal travel. It is easy to get used to and fine for my daily driver.
1997 Passat TDi - daily driver with Sprint 520s, RC2, EGR delete, SB3 clutch.
1996 Impala SS - modified toy (500+ HP, 11 mpg)
2001 Dodge Ram 2500 Cummins - tow vehicle (350 HP, 800 ft-lbs.)
2005 Dodge Magnum RT - Momma's grocery getter
March 16th, 2010, 17:11
#10
run a stock oem flywheel G60 or 1z. Be careful of chinese knock offs that some vendors used to sell. unbalanced garbage. no timing mark...
these oems are aval. cheap, ask around.
2003 Bora Wagon TDI Bosio R520's,colt cam, VNT 17
q loader. no smoke
2001 Beetle TDI GLS Bosio 764 7 hole's, tune, VNT 15
2010 JSW wagon DSG loaded
2003 golf auto
March 16th, 2010, 17:23
#11
Stock G60 style from Dieselgeek, I recommend etching or centerpunching the TDC marks before install IF THEY ARE LASER ENGRAVED. This is due to the inability to see the marks when doing a timing belt at a later date due to rust... Trust me on this.... Running a SBC Stage 3, it chattered a bit louder as it got older but it could have been the clearances in my transmission going due to grenaded 5th gear particles... say 40k miles on the clutch plenty of meat on both sides though the clutch disc retainer started cutting into the clutch springs a little, not as bad as the OEM G60 setup when I removed it
March 16th, 2010, 17:48
#12
I'm running a stock weight SMF with an SBC #3. It feels like stock to me & there is no chatter.
'06 Golf GLS 5 speed, Evo skid plate, Koni FSD's with Shine RSS, SBC stage 3, SMF, KERMA custom tune, R 32 snorkel,PD 150 airbox,MAF,TIP & manifold, K3B,R 783's, Colt stage 2, EJ SMIC, piping by ID Parts, Whitbread 2.5" DP, Aero muffler, 3"KERMA SS pipes, Sigma 5 short shifter, .681 5th gear & Peloquin, Nicktane 1 um fuel filter & DG/Amsoil bypass filter.
March 16th, 2010, 18:11
#13
can you clarify "the not as bad as the G60 setup"?
nobody makes a better flywheel than using an OEM solid wheel, the clutch is your choice. These vendor "billet" deals are not made to the quality specs as the original...and guess what? the oems "used" can be found cheaper.. a 1z flywheel is the same, your just not paying the G60 price for the name!!
q loader. no smoke
2003 golf auto
March 16th, 2010, 20:11
#14
i have the 17lb flywheels that came with the sbc 3 kit . and there is more revs needed in forst to get moving and more chatter tahn stock when clutch is out . so its another vote for oem stock 20-lb g60 flywheel . honestly the difference in gear change and revability is not worth the trade off in my opinion . you do get used to what you drive but i would use a stock g60 one if i did it again
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
March 16th, 2010, 23:30
#15
Yeah, I was gonna get it from id parts, along with a short shifter, any thoughts on the short shifters?
Also this is for the UK guys - Would the flywheel be cheaper if i bought from the UK - from what you guys are saying it is just a standard G60 flywheel right?
